Old 07-15-2010, 01:14 PM
Bill Moore's Avatar
Bill Moore Bill Moore is offline
2wd J trucks
I know Jeep phased these out for FSJs in the 60s. I have never seen one personally, but have heard of a few around. I was talking to a FSJ enthusiast from Argentina yesterday, and he mentioned ~90 percent of the FSJs there were 2wd. Cost cutting measure evidently. Here, a 2wd jeep is the kiss of death for resale, it seems odd they were so popular when you could buy 2wd other types of trucks. Anyone know if the Argentine Jeeps were just cheaper than the other truck makes?
DDs
78 J20 Chevy 305 nv4500 np205
67 KJ715 4bt AA OD 465 np205 j20 axles
Projects
73 J2000 4bt NV4500 np205 Dana 60/70 Tow Rig/tremors truck
Starting Sons Build, 1980 short bed J10, to get j20 axles, 4bt, nv4500, np205, M715 bed and fenders
Freedom is not Free, it is paid for with Blood
Old 07-15-2010, 01:26 PM
I've only seen one 2WD JTruck in my life, late HS years so about 1974-5. Yellow Gladiator a friend of mine had with a straight 6, 3 speed which I assume was a T90 and 5 on 5.5 lug pattern is about all I can recall.
He eventually converted it to 4WD, moved to AK and I never saw it or him again.
68_Gladiator's Avatar
68_Gladiator 68_Gladiator is offline
if i could have a 67' 2wd Gladiator id take it, ive wanted a 2wd street rod and think a gladiator with a hot motor would be cool. would be a lot different then all the lowered short box chevy street rods you see.
"Go Brow or go home"
67' Gladiator, 383/SM465/NP205, Open Dual Exhaust, Dana 60 Front, 14 bolt rear(disc brakes), 52/56 spring swap, hydro boost, 4" lift, AKA "Dr. Pepper"
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=122737
Old 07-15-2010, 01:52 PM
mud89's Avatar
mud89 mud89 is offline
IIRC the 2WD J-trucks were only from 63 to 65
They didn't last long, as the wagoneer 2 doors
Old 07-15-2010, 01:53 PM
joe joe is online now
X2
I've been looking for a 2WD J-truck here for a long time. Someday I may just have go back to South America to snag one. I've worked in S Am and don't recall ever seeing a 4WD J-truck. But there some really nice 2WD ones though especially in Argentina.
-Geoff Hill
Old 07-15-2010, 02:11 PM
Originally Posted by joe
X2
Be sure to snag me one too. ive thought about just getting a 4x4 and converting the front to 2wd. or just swap the body onto a shortened C20 frame
Old 07-15-2010, 02:16 PM
Tonka J200's Avatar
My '63 J200 (the Tonka Truck) is a 2WD. (Model 2306F - 4000 GVW, 2WD)
I'm not sure of the exact date that they phased out the 2 wheelers, but I think they were available until mid '67 or so.
They were available with either independent front suspension or a solid "tube" axle like mine. It's a 230 Tornado six with a three speed T-86E transmission. It also has a 4.10 geared Dana 44 rear with a PowerLoc diff.
It uses the same front hubs, etc. as a 4WD, they just have a steel cover plate bolted on in place of the drive flange.
Mine's the only 2WD J-truck I've seen in person, and I know the production numbers were pretty low.
I don't know what to tell you about the Argentine Jeeps. Were there other makes that were actually produced in Argentina? If not, I'm sure the locally produced Jeep trucks were quite a bit cheaper than other makes that had to be imported. Just guessing...
-Frank
'63 J200 2WD
'63 J100 Panel Delivery
Old 07-15-2010, 02:51 PM
Gambler68's Avatar
Rabble Rouser
Shoot, get yourself a length of axle tube, some spring pads and shock hangers, cut off the knuckles from any crap front D44 and you have yourself a straight tube axle for the price of welding and a little bit for the steel.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 07-15-2010, 03:00 PM
chrisnsarah's Avatar
I believe the majority of Wagoneer Panels were 2wd.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 07-15-2010, 03:30 PM
Tonka J200's Avatar
From what I've been able to find, the Panel Delivery Wagoneers were split pretty evenly - about half 2WD, half 4WD.
-Frank
'63 J200 2WD
Old 07-15-2010, 04:13 PM
And a most beautiful truck it is Frank!
-Geoff Hill
Old 07-15-2010, 04:14 PM
I've seen one 60's 2 door wagoneer (not a panel) in a Picknpull yard that was an ex-military vehicle. Had the brass plate on the dash. I was surprised to see it was only 2wd.
I have yet to see a 2wd J-truck in person.
'64 J200 thriftside
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
Old 07-15-2010, 05:10 PM
Tonka J200's Avatar
Wow, joe, I was the recipient of your 15,000th post! Do I win a prize?
-Frank
'63 J200 2WD
Old 07-16-2010, 05:31 AM
Bill Moore's Avatar
is this the only 2wd on the board?
DDs
Projects
Old 07-16-2010, 08:16 AM
mud89's Avatar
That's very interesting, you certainly saw more Gladiators than me..
By the way I think you are right and i am wrong for the phase out of the 2WD J-truck
It's not the end of 65 but rather the beginning of 67 : i found an AMA spec for the 66 models were the 2Wd trucks were mentioned, but in a price list from the end of january 67, i found only the 4WD trucks (here is the J2000's page)
80 CJ7 Laredo V8
81 J10 sportside I6
77 J10 Golden Eagle V8
80 Cherokee Golden Eagle with a 401, for parts
63 wagoneer for resto or parts ?
98 Grand Cherokee 5.9L
Old 07-16-2010, 08:34 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
I know of one 2wd Jtruck, had a 230 w/2bbl, small back window.
Old 07-16-2010, 10:29 AM
Member Daniel Fischer in Buenos Aires has one but if I remember correctly he's converted it to 4WD.
-Geoff Hill
Old 07-16-2010, 10:33 AM
Bill Moore's Avatar
I guess I should of said is Tonka the only one in the US on the Board
DDs
Projects
Old 07-17-2010, 04:35 PM
Tonka J200's Avatar
Hmmmm....Kinda looks that way!
-Frank
'63 J200 2WD
Old 07-17-2010, 04:56 PM
Elliott's Avatar
Cowboy Up
Nope, I know of one, a 1963 J300 3306E and 5000GVWR. I was mistaken about the small back window though, it's got the large one. I used to know a guy who had a 2wd Willys truck in WA also.
Does anyone know which wheels & center caps went on which trucks? (pic) blueteej General FSJ Discussion 2 03-20-2009 08:16 PM
looking for info on the gladiator trucks. Tex62 General FSJ Discussion 7 03-02-2009 08:03 PM
Pic Request Golden Eagle Trucks grand_wag_85 General FSJ Discussion 15 12-05-2007 04:56 AM
Willy's Trucks and Wagons The PIG Smith General FSJ Discussion 25 02-14-2007 05:58 PM
Which F*rd trucks have the T18/NP208 combo? Sycho15 Off-Road FSJ Tech 12 12-15-2003 05:42 AM
