Old 07-02-2010, 05:17 PM
badaboom's Avatar
badaboom badaboom is offline
Question Emission tube bolts, Question
What is the reasoning behind the emisson tube mounting bolts.
The Hollow mounting bolts with the side hole.
Whats the deal?
What is the diff if you mount the emissions tube with a standard style bolt or the correct mounting bolts with the hollow shaft and side hole?
1981 Jeep J10 Laredo, 401-V8, 625 Carter Comp Series, Lunati Cam 262/268, Edelbrock Performer, MSD Ignition, Flow Cooler, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, EXTREME MAKEOVER - IN PROCESS Bling Bling Cha-Ching
Old 07-02-2010, 05:37 PM
Thomas792's Avatar
Thomas792 Thomas792 is offline
I believe that without the hollow bolt and the hole in the side of the bolt, the fresh air will never get through the tube. It is very much like the set up on your brake lines. I've heard it called a banjo bolt in the past on morotcycles.
1974 J10 (401, Th400, Q-Trac, D44s, 28" tires)
Mrs Tickity - 1988 GW (360, 727, 229, D44s, 32" tires)
Old 07-02-2010, 11:33 PM
Smiff's Avatar
Smiff Smiff is offline
Banjo bolt is the correct terminology for any fitting like that, and they are used in a lot of different pneumatic applications. In this case, it's a fastener that connects the air injection manifold to the exhaust manifold, and also provides access to the exhaust stream for the air injection system.
A standard bolt would actually close the air injection passageway, which could be advantageous if you want to delete your emissions equipment.... Hope this helps.
86 GW, stock 360/trans "Frank"
Edelbrock carb on Offy intake
Some kind of spring lift (BJs 6 maybe)
Desert faded paint/body work courtesy AZ trails
USAF: Dropping Bombs and Hauling Grunts Since 1947
Old 07-03-2010, 12:24 AM
kennewick's Avatar
kennewick kennewick is offline
Fine thread bolts and short. I think they were 9/16 but can't remember for sure. I couldn't find ones short enough so I had to skinny wheel the excess off each one and clean up the threads. Sure cleans up the engine bay. Toss the pump too as it will just freeze up from non use anyway. Of course all this only if you are dumping the air injection.
Live Free Or Die!!
76 Wag, Quad w/low, 401, TH400, Dana 44 3.54/1 non LS, stock manis w/short 2.5" duals glass packs w/H pipe. 2" lift. air shocks rear, gas front. Superwinch locking hubs. Shift kit.
gas tank relocate
intake, oil pump, carb, HEI
alt upgrade
air injection tube bolts 78 blu ox General FSJ Tech 9 04-25-2010 09:16 PM
Good Bolts..... xupe45tgp General FSJ Discussion 5 01-15-2008 11:37 AM
air tube / banjo bolt damage (pics -trying to repair air check valve) TimK General FSJ Tech 10 08-08-2005 04:08 AM
th400 question 72wag General FSJ Tech 2 06-02-2004 10:14 PM
ARP Head Bolts Frank in Norway General FSJ Tech 2 03-05-2003 06:13 AM
