Old 06-16-2010, 09:34 PM
Jeebes Jeebes is offline
Dash/Dash Pad???
Has anyone just got rid of there dash pad and patched the holes? Or whats the best way to repair a badly weathered dash pad?
Old 06-16-2010, 09:47 PM
TexTJ209's Avatar
TexTJ209 TexTJ209 is offline
Somebody (cu4wheelin maybe) had their dash pad recovered in leather.
But yeah, the holes in the dash are patchable, as the original contoured metal dash is still basically unchanged underneath the dash pad.
'10 Chevy Silverado 5.3L - The DD.
'81 Jeep CJ-7 Laredo
Texas A&M Offroad
Old 06-16-2010, 10:20 PM
halftrac's Avatar
halftrac halftrac is offline
I believe it was Sportside Dan who did his dash pad in leather.
Jackie Jacob
1977 J20, 360 4bbl, 4 spd, utility bed
1978 J 10 258, 4 spd, 3" liftDD,
1988 Wagoneer Limited XJ
and a junkyard full of FSJ parts
Jake's Full Size Jeep Junkyard
www.militaryjeepers.com
Carolina Full Size Jeep Club
http://s255.photobucket.com/albums/h...eeps%20Galore/
Old 06-16-2010, 10:42 PM
TexTJ209's Avatar
That's the one!
Texas A&M Offroad
Old 06-17-2010, 12:32 AM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
I was thinking of having mine covered with vinyl or leather as well is ther any pics?
Pierce,
77 J10 360 4bbl, TH400, D20, HEI, Holley carb, Performer intake, Thumpr Cam, Hedman headers, dual exhaust, Auburn limited slip, hydroboost.
Old 06-17-2010, 06:01 PM
Thanks for the replies
I was thinkin the same thing
Old 06-17-2010, 06:12 PM
If you hand carry the pad into an auto upholstery place shouldn't be too expensive. .Last one I had done a few years ago was $75, done w/vinyl not leather.It's a real easy piece to recover. If I were to do it again I'd buy the material do it myself.
Old 06-18-2010, 02:19 PM
suzq044's Avatar
suzq044 suzq044 is offline
I am planning to use a '60s dash in Levi; no need to worry about the dash pad. Got it free. I figure, why not? lol
Max˛: 1964 Jeep Panel Wagoneer
Planning Stages
2018 Wagoneer Rendering if you're interested.
Old 06-18-2010, 02:26 PM
krek's Avatar
krek krek is offline
Perpetually Perplexed
I modified the early dash (inspired by a member named Towtruck who did similar) for the SuperChief.
http://www.ifsja.org/forums/vb/showt...t=79036&page=8
Old 06-18-2010, 02:30 PM
Billygoat's Avatar
I think somebody removed there pad and put led lights in the holes.
"Thumper" - 1981 J-20 Extended Cab/sportside - REBOOTING.....
Old 06-18-2010, 02:36 PM
SEdmonds's Avatar
SEdmonds SEdmonds is offline
Our dash pad is in really good shape, except it sags in the front so the ash tray on the driver's side won't open. It doesn't easily push out of the way - anyone else have this happen?
Old 06-18-2010, 05:00 PM
ABN82MP ABN82MP is offline
Here's mine, sans pad and all smoothed out:
Old 06-18-2010, 05:47 PM
seamus's Avatar
seamus seamus is offline
That is very clean.
Nice work.
Old 06-18-2010, 11:39 PM
Locked and Loaded's Avatar
Locked and Loaded Locked and Loaded is offline
I like that. What did it look like before you cleaned it up?
Drink more water.
"Nothin' ain't worth nothin'.
But it's free"
Kris Kristofferson 1970
1981 J10, 258, T176, NP208
Old 06-18-2010, 11:52 PM
suzq044's Avatar
^ this shot, for some reason makes me think of a '60-66 Chevy C10 hood..
Planning Stages
Old 06-19-2010, 05:04 PM
Just your standard dash. 6x9 hole in the top for a speaker. Holes all around the edges for the dash pad bolts, etc... A year later and I still need to install the radio and fix the glove box latch!
Old 11-05-2010, 12:34 AM
superman0094's Avatar
superman0094 superman0094 is offline
Where'd you get the handle from?
Where did you get that awsome handle? I must have onel
Old 11-05-2010, 07:59 AM
Towtruck's Avatar
Towtruck Towtruck is offline
Here's an old, in process photo of a late model dash (left half) welded to to an early model version. The stamping on the early dash is much nicer and it doesn't have the speaker hole. Splice line sort of zigzags in the vicinity of the left ash tray. Saves filling the speaker hole and changes the look of the dash. The right side defroster vent must be swapped (cut out and the later version welded in) if the vehicle has air conditioning. Allows you to keep the original instrument cluster, wiring, and steering column mount. If you decide to pull the dash to weld up the holes, you might as well get creative...
___________________________
J10 - Body channel (3 inch drop @ front); dechromed; shaved side parking lights, antenna, and hood trim bar. Ford mirrors, roll pans, side exhaust, 16 inch wheels, custom dash, new interior, Edelbrocked 360, HEI, T18/208 (J20), rear disk brakes, fifth wheel and bumper hitches.
Old 11-05-2010, 08:32 AM
Dr Teeth on this board put green LEDs in the holes in his dash. I haven't decided which way to go, yet. For sure I'm better at bolting stuff in than meticulous body work.
Old 11-09-2010, 10:35 AM
Gymmie J10's Avatar
Gymmie J10 Gymmie J10 is offline
I'm am so interested in what had to be done for each of your dash pad replacement projects. I'm in the same boat. My pad has cracked at the speaker grill (which is totally gone) and it is now curling upwards and cracking into little pieces. Would love to find a pad and just do a swap out but now I'm thinking of doing something more custom if possible.
It's a '77 J10 and originally a blue interior, but the truck will most likely be repainted to White, with flat black trim. So the interior can be basically any color other than black (Summers are just way too hot out here for black and no A/C.
Can you guys explain more or give options? Thanks
I can do anything, the impossible just takes a little longer.
1977 J10 - Winter Driver (restore in progress)
1946 Willy's (Parade toy - Restore coming)
1985 Mazda RX-7 GL
2005 BMW Z4 Roadster
