Old 06-16-2010, 12:12 PM
Willy Schneider's Avatar
Willy Schneider Willy Schneider is offline
T-90 Transmission w/Dana 20 Tfr case
'62 flat-fender PU w/Tornado engine.
Tranny was getting hard to shift, so I opened it up - lots of metal shavings
Need advice - would a rebuild be cheaper/better than just replacing the whole thing. I see a T-90 near here (Seattle area) for $265 and thinking hard about just saving myself some work and getting that.
My having the time and space to work on this is an issue also - no garage.
I put new oil in and I am able to drive, but I want to be ahead of this, and I use it quite a bit for hauling trash, yard waste, etc...
ThanQ..
"Just because Chrysler calls it a Jeep, don't make it so..."
Old 06-16-2010, 12:17 PM
biotex's Avatar
biotex biotex is offline
I rebuilt mine, and although it is not that hard, the snap rings are a PITA. By the time you purchase the parts, and good snap ring pliers, you spent a couple of bills anyway.
Save yourself the aggrivation, and purchase the one mentioned. Now you have spare parts...
1986 CJ7, AMC 304/ T-176
1968 Scout 800, 152/T-18
1971 Scout 800B, 345/727
CJ10-A Tug,Waggy axles, Sd33, 727
Old 06-16-2010, 12:31 PM
joe joe is online now
If that T90 has been rebuilt(not just re-sealed) it's a fair price but if it hasn't been it just another old worthless T90.
-Geoff Hill
Old 06-16-2010, 12:32 PM
Thanks, I'm leaning toward doing just that...
Old 06-16-2010, 12:33 PM
I will check that before buying! Thanks...
Old 06-16-2010, 12:40 PM
mdill's Avatar
mdill mdill is offline
Anyone still swap in the muncie four speeds for the T-90's
Use to be the hot ticket, the T-90 is not a very good tranny behind
a the 6 in a truck.
(I had a lot of fun in my 4 popper t-90 wagon way back, but the tranny is a pretty weak unit and you have to get the
touch (double clutch) just right to do the down shift into first)
Mike D.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Sealant between transmission and transfer case? iroc86 General FSJ Tech 2 10-07-2009 07:23 AM
A500 TRANSMISSION ? key General FSJ Tech 7 03-18-2008 12:52 PM
Transfer Case Questions Thomas792 General FSJ Tech 10 12-20-2007 04:27 PM
transmission / transfer case ?? johnypreflt General FSJ Tech 6 01-24-2003 02:02 PM
