Old 06-13-2010, 02:46 PM
Maryland Rick's Avatar
Maryland Rick Maryland Rick is offline
'87 GW emissions vacuum sticker under hood
I need someone to please take a close-up photo, in focus, of the emissions vacuum sticker that is on the radiator support under their hood on their 1987 GW.
It seems that the only diagram of a 1987 is for California version. I have seen that one and need the one with the "SE" letter designation on the sticker.
Once I get a clear image, I will have the data to make a clean and large diagram that I will post here in the Tech Library.
You can email me the photos. Please make sure they are focused and closeup.
Thanks...Rick
rwiner@frederickcountymd.gov
Old 06-13-2010, 08:20 PM
bowtieman55 bowtieman55 is offline
'88
reference is http://oljeep.com/gw/vac/GW_vacuum.html
Old 06-14-2010, 04:52 PM
Thanks Earl, but.....................I needed
1987
Thanks anyway....Rick
Old 06-14-2010, 08:10 PM
cavicatz24's Avatar
cavicatz24 cavicatz24 is offline
Hello!
What is the specific reason you need the emissions sticker? I can supply both versions of the vac routing from Alldata if that would suffice.
"Bessie" 1982 Wagoneer Limited
http://www.ifsja.org/forums/vb/showthread.php?t=120964
Old 06-15-2010, 05:19 AM
If it is for a 1987 GW, that would be GREAT!!
Thanks...Rick
NOx Questions - Failed Emissions Kevin718 General FSJ Tech 13 01-13-2007 10:22 PM
Ping, but only when hot, still need help JeepsAndGuns General FSJ Tech 26 12-17-2006 09:51 AM
Holley Truck Avenger Secondary Springs funwheeling General FSJ Tech 5 11-29-2006 08:44 AM
Vacuum Advance and starting problems JohnIL General FSJ Tech 0 09-28-2006 07:42 AM
quick question on vaccum stuff related to egr and dist vacuum advance...(bit long)... DanHS General FSJ Tech 24 01-13-2006 12:10 AM
