Old 06-06-2010, 08:35 AM
Seemer Seemer is offline
Hood Flew Open - Brackets now bent
Cruising along and approaching 50 mph and all the sudden the hood flies open. Long story short, the bracket/brace that seats right up against the underside of the hood now has a 2" + gap on one side and 1" + gap on the other. Both basically inverted in. The hood will not close. I'M SCREWED!! It's true right....I need a new hood and brackets...yes? I can't imagine trying to bend everything back... UGH.
Old 06-06-2010, 12:00 PM
Wayne's Avatar
Wayne Wayne is offline
New hood and brackets would be easist.
78 Wagoneer 401/T400/bw/44F&R DD 4in lift
Old 06-06-2010, 12:23 PM
Got and pics of the damage?
-Jon Barstow
1979 Cherokee Golden Eagle
360/TH400/D20
5" lift/33x12.5R15
Old 06-06-2010, 07:26 PM
Pics below
The top of the hinges bolt onto brackets/braces that fit the underside contour of the hood. You can see that when the hood flew open, the pressure completely separated and then bent in/inverted the brackets.
Left side (looking from grill towards windshield
http://xa.yimg.com/kq/groups/7738407...name/hood2.jpg
Right side
http://xa.yimg.com/kq/groups/7738407...name/hood1.jpg
Old 06-06-2010, 09:23 PM
myndcrym's Avatar
myndcrym myndcrym is offline
Is that you Tommy boy?? Sorry......Had too!!!
Jeremy "The cable guy"
ki4pks
http://gfsj.org
http://www.cfsjc.com/
The Dragin Wagon
1987 Grand Wagoneer
TFI upgrade
BJ's Dozer bumpers
Tads rack
Rustys 4 inch lift
np208
more to come
Old 06-06-2010, 09:45 PM
JeepMods JeepMods is offline
Dude that sucks!...
Old 06-07-2010, 04:14 AM
threepiece188 threepiece188 is offline
Those brackets are part of the hood assembly.
I blow my horn before it happens, not after.
A good mechanic can fix their own mistakes.
Waste not war not.
Ignorant is blist.
When you're in a hurry... slow down.
Measure once... cut twice.
Old 06-07-2010, 06:07 AM
leostevo's Avatar
leostevo leostevo is offline
When you are ready for them, I have the hinges pulled and ready for shipping. Also have the latch bar and springed pins.
PM me when you get to that point.
1990 Grand Wagoneer "Daddy Wagon"
AMC360/TF727/NP229
Edelbrock Performer Intake, Headers, Cam, 1406 Carb, Mallory HEI. No smog. Rusty's 4" all springs. '89 GW wheels, custom painted and wrapped in Maxxis Big Horn 31x10.50, dual 2.25" exhaust outside the frame rails.
Old 06-07-2010, 06:54 AM
Frank's Avatar
Frank Frank is offline
I've an '88 Wag hood and all the fixin's if you're interested. Straight and clean and works like a charm. Just let me know...
Frank
'88 Grand Wagoneer, "Sluggo II"; Found Box Stock and is currently being 're-birthed' to its former glory!
...slowly bringing the creature comforts of the new millenium to a 25+ year-old Grand Wagoneer...
Old 06-07-2010, 07:29 AM
Thanks guys. I do have access to an 87 with all the necessary parts. Here's my question though....there are a series of components that connect the hood to the car:
1. hinges, which are bolted into the firewall sheet metal
2. the top of the hinges bolt into these corner brackets (the ones that are bent inward) which are attached to the hood.
3. the two corner brackets are connected to eachother via a metal support that spans from one side to the other...at the very back end of the hood. This piece also separated from the hood by ~1/4 to 1/2".
4. then there are connecting rods that run at an angle to the front of the hood.
I know the hinges can be swapped out, but are these corner brackets welded into the underside of the hood? Meaning I need a new hood with the brackets attached? Or, can I rob those brackets from another hood and swap them out? I have not gotten too deep into yet, but intial look suggests those brackets are not comming off. The hood itself is not damaged at all and it was recently repainted so I would like to keep it if possible.
Thanks.
Old 06-08-2010, 05:38 AM
Thanks.
The answer to both of your questions is both yes and no. Those brackets are welded to the hood as part of the assembly. You could detach and swap the brackets but I would only consider this if the doner hood was otherwise damaged and there was no other hood available.
I suspect you are trying to get out of painting the hood but cutting out four brackets and welding them in would be a considerable amount of work and you would likely end up having to paint afterward anyways.
Dan
Waste not war not.
Ignorant is blist.
Old 06-08-2010, 09:17 AM
710 Burner's Avatar
I'm just trying to figure out why the meathook didn't stop it. You musta bent it with your head.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Old 06-08-2010, 09:53 AM
joe joe is online now
On the bright side keep the old hood for winter. I had the same mishap hitting some RR tracks too fast and had the hood fold up on the roof on a 49 Ford. Destroyed the roof and windshield but the hood made a great sled, Only rule was "you ride it down, you help pull back up"
-Geoff Hill
Old 06-12-2010, 04:30 PM
Update
Quick update. I took the hood off, jumped (literally) on each of the brackets and bent them back most of the way. I then robbed one hinge from another FSJ. I noticed that the firewall was also bent (where the hinge bolts in), so I grabbed a bunch of washers to fill the gap so to speak. Put everything back together and the hood is working. Still not lined up completely, but with some tinkering I think I'll be able to get it darn close.
Thanks for the help.
Hood won't open PSAR3000 General FSJ Tech 4 12-27-2004 08:31 PM
can't open hood!!!! Zorm General FSJ Tech 8 03-20-2004 06:46 AM
Hood Won't Open FratWagon86 General FSJ Tech 3 06-26-2003 07:24 AM
can't open my hood kreb General FSJ Tech 2 05-11-2002 02:40 PM
Help! My hood won't open! orangeplay General FSJ Tech 3 10-14-2000 07:10 PM
