Old 05-31-2010, 02:23 PM
jump jump is offline
ammeter question
Looking at the wiring on my 82 wag today. I want to get rid of the ammeter, mine doesnt have a fuse any where, and found some of the yellow wire from the starter solenoid to the ammeter was fried. I have read some articles about how you can just connect both wires at the back of the ammeter on the same terminal. I was wondering if I can just eliminate the yellow wire altogether? Or should I fix the wire and connect them together at the back of the ammeter?
Thanks
Old 05-31-2010, 03:40 PM
caionneach's Avatar
caionneach caionneach is offline
Definitely fix it
Yes, fix it. The wire is part of the charging system. You can eliminate part of the red/yellow wire system coming from the alternator, but that is your primary charging circuit, and the process is quite complicated.
The easy way is to fix the part that is fried, and go ahead and do the ammeter bypass and put both wires on one post of the ammeter. Especially since your wire has a bad place on it, your ammeter is the weak link in the circuit, and putting both wires on one terminal will prevent the ammeter from grounding out on you and frying your wag.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 05-31-2010, 04:23 PM
instead of putting both wires on one terminal, can I just connect them together?
Old 05-31-2010, 04:31 PM
I disagree. Ammeters have been used safely forever and even the jeep ones are fine for the size alternator it was designed for.The ammeter won't ground itself out and burn down your jeep. Fires that folks blame on bad ammeters are caused by loose or corroded connections at the gauge (both creating excesive heat). Loose/dirty connections are the owners fault(lack of maint) not the ammeters fault.
Old 05-31-2010, 04:37 PM
crazyspoons's Avatar
crazyspoons crazyspoons is offline
true, I burned out my electrical system after i put a new alternator in. You should probably fix that wire and bypass the ammeter.
I always read posts about bypassing the ammeter and didn't do it until it fried my newly replaced electrical system.
The best route is to install a voltmeter and put in a fusable link. I still have yet to put in the link, but, again, I'll probably fry my electrical again before I realize I should fix it right.
1997 Jeep TJ AMC 150 2.5L, AX-5, NV-231 Status: ALIVE
1983 Jeep J-10 AMC 258 4.2L, Holley 2bbl, HEI, T-177, NP-208, 4" Rusty's Spring Lift, CherryBomb haha Status: ALIVE
1976 Jeep J-10 AMC 360 5.9L, TH400, Quadra-Trac Status: SOLD! to The Dude
Durham, CT
Originally Posted by Julep4000
Kudos, sir... I didn't plan on coffee coming out of my nose today.
Old 05-31-2010, 06:43 PM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
heres the write up I used works great and the circuit protector is good for extra insurance. http://www.ifsja.org/forums/vb/showthread.php?t=105253
Pierce,
77 J10 360 4bbl, TH400, D20, HEI, Holley carb, Performer intake, Thumpr Cam, Hedman headers, dual exhaust, Auburn limited slip, hydroboost.
Old 05-31-2010, 06:49 PM
littlebuck23's Avatar
littlebuck23 littlebuck23 is offline
I agree x 100
Terry
1970 Kaiser Wagoneer -SOLD (currently getting built by new owner)
Build thread-http://www.ifsja.org/forums/vb/showthread.php?t=103447
1979 Cherokee Chief WT 360. SOLD
1977 Cherokee Chief WT Sport 401. SOLD
1975 International Scout II (My DD)
Old 05-31-2010, 07:20 PM
Geminiroq Geminiroq is online now
Hey guys,
I have been sweating this thing for a while.
Would upgrading the wires leading to the anmeeter be considered a good upgrade?
Any and all advise is appreciated.
Thank you,
Old 05-31-2010, 09:52 PM
gto_ron's Avatar
gto_ron gto_ron is offline
All the ammeter does is display the current flowing between the battery and the alternator. It can flow both ways, thus negative and positive current. That's why it pegs negative when you crank the engine; all the current is flowing from the battery and none from the alternator. Unless there's something wrong(frayed, nicked, broken strands) with the original wire there's no reason to replace it with a heavier gauge wire.
Ron
87 GW
79 CJ7
64 GTO conv
Old 05-31-2010, 10:05 PM
caionneach's Avatar
Yes, but....
Originally Posted by Geminiroq
Hey guys,
Thank you,
Yes you can do that, but upgrading both wires is going to be a real pain unless you are prepared to tackle THE BIG SPLICE that the red wire leads to which powers everything inside the vehicle. I think replacing the yellow wire is a simple replacement. The red one however, has that splice that leads to other critical systems, like the starting circuit.
Connecting the red and yellow wires together beneath the dash is what many do when a voltmeter is put in place of the ammeter AND the voltmeter is connected to a power source on the fuse block that has power when the key in the "ON" position.
1982 Cherokee
Old 06-01-2010, 07:08 AM
biotex's Avatar
biotex biotex is offline
What I'm going to do, is to run an extra wire from the alternator (B+) to the battery. What this will do is to decrease the amps running through the ammeter. I will still get needle deflection, just not as much swing.
1986 CJ7, AMC 304/ T-176
1968 Scout 800, 152/T-18
1971 Scout 800B, 345/727
CJ10-A Tug,Waggy axles, Sd33, 727
Old 06-01-2010, 08:01 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Running another wire won't decrease the amount of amperage in the ammeter. What it will do is increase the current capability from the alternator to the battery by virtue of another wire.
Increasing the wire size from/to the ammeter would be a good thing only in the sense that it will get rid of old wire (with old insulation).
The "BIG SPLICE" that has been mentioned before it the real problem child. Jeep did little to prevent corrosion there. There are a lot of solutions to this particular problem, most involve getting rid of the splice itself and using a terminal block of some sort.
Getting rid of the ammeter can be done, although I prefer an ammeter. Jeep would've been a lot better off to use an inductive ammeter as opposed to a series connected ammeter, but they didn't. You can get a voltmeter and do the ammeter bypass, then you'll still have something to tell you what your charging system is up to.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Another Ammeter Question crazyspoons General FSJ Tech 2 04-24-2010 09:50 AM
Best way to prevent ammeter fire? tj10 General FSJ Tech 8 02-06-2010 01:03 PM
Quick 85 Grand Wagoneer Question WagoneerMan General FSJ Tech 3 01-31-2010 11:06 PM
thermostat tech question roadgrime General FSJ Tech 11 06-12-2004 04:30 PM
Ammeter bypass questions... PlasticBoob General FSJ Tech 7 07-27-2003 02:21 PM
