Old 05-28-2010, 11:06 AM
rmorit01's Avatar
rmorit01 rmorit01 is offline
How difficult is it to remove and replace a TH400?
Need some advice on how difficult it is to remove and replace a TH400. No shop...driveway only and working with hand tools. My main concern is knowing if the engine needs to be moved forward and connecting/disconnecting the QT transfer case.
Any tips/tricks?
Thanks -- Bob
79 Cherokee S
Old 05-28-2010, 01:07 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
Location: La Crosse,Wisconsin formely of Wichita,Kansas
def, disconnect the transfer case IMHO
1979 Cherokee Dodge CTD with running Gear Build thread:
MoPaR
Old 05-28-2010, 01:35 PM
I remove the QT low range, then the QT, then drop cross member, then the T400. Drain T400 and QT first and put support under the tranny. Two Words: Tranny Jack. This will make life much easier. If you are not careful with QT removal and re-install, the 2 front seals will get crimped on the tranny tailshaft. I use two long bolts screwed in from the front on the driver side of the QT adapter to help support the weight as I remove or replace QT.
Old 05-28-2010, 01:38 PM
Gambler68's Avatar
Rabble Rouser
See it's not hard at all if you have Flint come over and do it!
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 05-28-2010, 04:52 PM
trellis8's Avatar
trellis8 trellis8 is offline
Bring 'er up Bob! I've taken enough of them out, just do it backwards this time! Seriously, I have a trans jack at work, let's get 'er done. Besides, I'd rather wreck yours than mine.
1981 Wagoneer Limited , 1984 Grand Wagoneer, 1985 Grand Wagoneer, 1973 J4000, 1982 Mustang GT, 1999 Chevy C2500 xcab, 2001 Chevy Van, 2000 Ford Expedition and 2003 Ford Explorer Eddie Bauer.
Old 05-28-2010, 05:11 PM
agree, remove the tcase first and get a trans jack.
-Geoff Hill
Old 05-28-2010, 05:39 PM
Green Giant's Avatar
Green Giant Green Giant is offline
El Cheapo Tranny Jack that works fine
Had one of these for years. I use an extension, a swivel joint, and a 1/2 impact set on low, makes it easier
Oh, and be sure get a HF 20% off coupon in the back of just about any national magazine or Sunday paper coupon insert, makes it $63.99.
One other thing to remember is the TH400 is clocked slightly to the right when you go back together, as the jack is only adjustable fore and aft, I use a wooden shim for the side tilt.
Todd Moon
78 Cherokee Chief
78 Chief
66 J-3600
69 J-3500
67 CJ-5
67 J-100 w/BARN DOORS
48 CJ2-A
Proud member of Carolina Full Size Jeep Club
cfsjc.com
No part of this post, written or pictured, may be re-used by any individual or organization or publication without my express written permission.
(Thanks, Flint!)
Old 05-28-2010, 10:59 PM
rmorit01's Avatar
So tempting...I will PM you -- perhaps you can sell me a TH400 setup that hasn't lost reverse for the QT?
If it breaks...it is a long hitchhike home from your place!
79 Cherokee S
Old 05-28-2010, 11:00 PM
rmorit01's Avatar
Thanks for the tip and the link --
79 Cherokee S
Old 05-28-2010, 11:52 PM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
[quote=rmorit01] lost reverse
sounds like the rear clutch pack
Old 05-29-2010, 07:10 AM
trellis8's Avatar
Do I have a TH400 for QT? That's a rhetorical question, right? Of course I do! Bring it! Worst case, I give you something else to drive home, Lord knows I have enough laying around.
Old 05-29-2010, 08:26 AM
mt pokitz's Avatar
mt pokitz mt pokitz is offline
you can usually find a tranny jack on cl for cheap. if this turns into a wot, i can bring some cold beverages and a video camera. need to pull tran/tc on 78 parts truck, wouldn't mind hands-on tutorial. have worked on gm muscle cars so i know a li'l bit, still trying to learn about these jeeps/4wds
Old 05-29-2010, 08:43 AM
trellis8's Avatar
Now we have a full blown FSJ event! C'mon down!
Old 05-29-2010, 09:48 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Bob, get a tranny jack from harbor freight. Cheap and it's a fairly decent one. I did mine in the driveway on my J-10 with HB's jack. The only issues I had was that the QT was RTV'd to the tranny, and I HAD to take them out together. Jack worked just fine that way.
I did have to take the tranny/QT off the Jack to get them out from under the Jeep.
It really made re-installing everything a lot easier too. Took me about an hour to get the tranny and QT installed, including the lines and all.
How far is Grayslake from Elgin?
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Best way to replace seals... FSJ Guy General FSJ Tech 15 03-22-2008 05:39 PM
remove & replace vent windows on 87GW eddiec General FSJ Tech 7 01-30-2007 07:45 PM
Do I have to remove the PS pump to replace the lines? Matthew W. Woodruff General FSJ Tech 4 04-25-2005 11:59 AM
How to remove cover for light replacement. kathokatho General FSJ Tech 7 08-06-2003 03:31 PM
which gaskets to replace at the same time dweezle General FSJ Tech 2 02-02-2001 10:17 AM
