Old 05-15-2010, 10:04 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Cool Dyno numbers for junkyard 360
Ok so I built a junkyard motor so I could take my time building the 401. Never-been-rebuilt 1976 360 that I stabbed a used cam in (.480 lift 224 duration). Swapped the heads for a set with a little clean-up and good springs. RPM intake and holley 750. Just a spare parts engine I threw together in one evening for the price of gaskets. Well it ended up running a lot better than I expected so I threw it on a chassis dyno today.
255.6 hp / 364.1 tq on motor
290.9 hp / 406.4 tq on a 50 shot
Taking into account an estimated 25% drivetrain loss those numbers turn into
340.4 hp / 485.5 tq on motor
387.9 hp / 541.9 tq on a 50 shot
That's almost 1 hp per cube and 5800 RPM out of a motor that could be duplicated with any 360 for around $1000 in a weekend without having to pull the engine. Try that with a 350 chevy.
1976 Wagoneer - Just an 11 second street car
1983 Cherokee WT - IFS, trailing arm rear, full cage, turbocharged AMC 429
http://www.cardomain.com/id/Ghinmi
Old 05-16-2010, 05:46 AM
Ristow Ristow is online now
not bad.
i have an Offy Equaflow,P.A.W copy of a Performer cam with a 4180 holley on the 360 in my GW while the 391 gets corrected. been in it since last fall.
headers/dual exhaust and a 5600 rpm governor in the transmission.
it revs out good and hard. scoots along surprisingly well.
Old 05-16-2010, 08:38 AM
AMC-J/20's Avatar
AMC-J/20 AMC-J/20 is offline
Nicely done
Mike
1953 Studebaker M275.
1962 GMC 4500.
1969 AMC AMX-390 Resto.
1977 Ford F350.
1982 AMC Eagle project SX/290.
1982 AMC/Jeep project J5500.
1988 AMC/Jeep project MJ/343.
1992 GTA Trans AM.
A M C Means jeep to me
Old 05-16-2010, 08:45 AM
In my best Darth Vader voice "Impressive"
Originally Posted by AMC-J/20
Nicely done
No 390 comments?
Old 05-16-2010, 10:16 AM
AMC-J/20's Avatar
Well . . .
AMC-390:
490hp@6,000rpm & 492tq@4,500rpm
I may have to rethink those low compression AMC-V8's . . .Nicely done nicely done
Mike
1962 GMC 4500.
1977 Ford F350.
1992 GTA Trans AM.
Old 05-16-2010, 09:43 PM
Ghinmi's Avatar
What are the specs on that 390? Pretty sweet numbers! Just curious how my next 401 will compare.
Old 05-17-2010, 06:15 PM
Greg Taylor's Avatar
Greg Taylor Greg Taylor is offline
Pretty cool post! Nice numbers for both engines.
Sincerely,
Greg Taylor
Rochester Hills, MI
1989 Grand Wagoneer "Terminator 2" : 330" AMC stroker V8. NV3550 5-speed. 6" lift 33" BFG A/T's.
1983 Cherokee Chief "The Lowredo Project" : 78 Z28 front Subframe and Z28 rear axle. 385" SBC stroker V8. TH400 auto.
Eastwood Hotcoat powdercoating thread
Old 05-19-2010, 05:52 PM
zachandandy's Avatar
zachandandy zachandandy is offline
Those numbers look nice. Makes me wonder how the 360 was only rated at 129 hp in 77. What ignition system are you running? Stock compession ratio? Makes me want to throw my junk on the dyno.
Old 05-19-2010, 09:00 PM
AMC-J/20's Avatar
It's actually not all that altered form the factory specs really . . .
its slightly bored over, and has a slight bit less duration with a little more lift and Eddie performer head's
396Ci, 292*dur .580 lift, Eddie aluminum performer heads, High volume oil pump, Over sized oil pan, and HEI ignition.
The rest is all factory 12.5:1 AMC-390 Cross Ram parts
Mike
1962 GMC 4500.
1977 Ford F350.
1992 GTA Trans AM.
Old 05-19-2010, 09:11 PM
AMC-J/20's Avatar
AMC sand bagged a lot of there ratings to stay off the "high Risk" insurance lists
The 68'-69' AMX & Javelin AMC-390 4bbl 10.2:1 was rated for 315 gross horse power Hot rod magazine did a write up on it and found in 100% factory form it actually turned 332 Net horse power after a quick rejet of the carb and recurve of the spark it cranked out 347 N-HP Cost $25-35 Now back that with AMC's optional 3.91 & 4.44 gear's you got a screaming street machine
Mike
1962 GMC 4500.
1977 Ford F350.
1992 GTA Trans AM.
Old 05-19-2010, 11:22 PM
Ghinmi's Avatar
Ignition is a gutted HEI dizzy with a MSD 6al-2 and remote blaster 2 coil. Forgot to add that it's got shorty headers too. Stock compression, bottom end never been apart. Stock heads are good, just choked off by the stock intake, manifolds and cam. Fix them and you can pump more air = more power.
Mike
Cool build! I'm doing a 10.5:1 iron head engine with a similar cam and a torker intake. It may see some time on the engine dyno so it'll be interesting to see how they compare.
Old 05-20-2010, 12:08 AM
shackwrrr's Avatar
My stocker with a 4 barrel made 175 hp and 285 tq on a chassis dyno. That was in the dead of winter with 0% humidity. I later installed a melling cam and it made the exact numbers but at 100 percent humidity and it was about 90 degrees outside. I havent been back since.
Jeepless
In to Turbo crap now
Old 05-21-2010, 04:49 PM
AMC-J/20's Avatar
AMC-V8's
Mike
1962 GMC 4500.
1977 Ford F350.
1992 GTA Trans AM.
304 vs. 360 Heads MidnightBurn General FSJ Tech 4 11-23-2007 04:20 PM
POWER OF THE STOCK 360 V8 JERSEY JOE General FSJ Tech 18 11-07-2007 11:19 AM
Looking for mopar 360 answers. HOOT General FSJ Tech 4 01-10-2006 10:23 AM
The AMC 360 jeepsr4ever General FSJ Tech 17 12-15-2003 10:34 AM
360 Rebuild/Swap Questions/Suggestions The PIG Smith General FSJ Tech 0 04-11-2002 03:06 PM
