Old 04-27-2010, 05:08 PM
cavicatz24's Avatar
cavicatz24 cavicatz24 is offline
Zinc substitute!
Hello!
I was perusing the forums and remember coming across some discussions about zinc for flat-tappet cams. Hyper Lube makes a zinc substitute that is supposed to do the same job as zinc. Costs about 14 bux a bottle and hasn't seemed to cause any harm so far...
Found it at O'reilley's.
Old 04-27-2010, 05:39 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
For $14 + oil I'll stick to the high zinc Amsoil (AMO1G-EA) I've been running.
aa
Anthony
1983 J-10 - 4.6L(MPFI)/CS130D/NV3550/D300/44/44/3.54/32s/42 gallon 'burb tank
Old 04-27-2010, 05:43 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
aa
X2
Originally posted by Ristow
i bet it was Simon....
Old 04-27-2010, 06:19 PM
jeepjerry's Avatar
There are a few flat tappet friendly oils that end up being cheaper than buying regular oil plus additive. Valvoline VR-1 oil has a good zinc content, theres brad penn racing oil and joe gibbs hotrod oil.....have to find a local distributor for those though.
It is good to know that zinc additive can be found though.
1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 04-27-2010, 06:26 PM
cavicatz24's Avatar
Just figured I'd let y'all know. I'm not sure what oils have what kind of zinc content so I figured the additive was a sure thing. Aside from the few oils listed here (wish I knew where to find Amsoil around here) what others are good?
And just to refresh my memory, what exactly is a flat tappet design? Is it where a flat bottomed hydraulic lifter rides directly on the cam?
Old 04-27-2010, 06:28 PM
Cecil14's Avatar
No shot at your find, for sure. Always good to know we have options. The Bulltear oil is designed to run in our engines as well and has had lots of good feedback.
As far as Amsoil just sign up to be a preferred customer...think it's $20/year? All the oil you can want is just an order form away. lol
Yes, a flat tappet cam is when there are no moving parts between the cam lobes and the lifters (ie: no rollers, etc.). I don't know of any modern engines that are still flat tappet...everything is either roller or overhead cam. Though my experience with modern stuff is rather limited.
aa
Anthony
Old 04-27-2010, 07:02 PM
STP sells an additive (with ZDDP) WAY WAY cheaper than $14 it's in a blue bottle.
Available @ just about any parts store....
I'd also agree that it's better/cheaper to just use a quality oil in the first place.
1994 Caprice wagon
86j10's Avatar
86j10 86j10 is offline
i use rotella t from shell. works good. some old timers turned me on to that
Old 04-27-2010, 07:18 PM
Cecil14's Avatar
I believe rotella has changed their oil lately too...check the bottle next time to be sure.
aa
Anthony
Old 04-27-2010, 08:07 PM
86j10's Avatar
it has a slightly lower level of zinc. still by far 1 of the better of the oils out there
Old 04-27-2010, 08:11 PM
The Colonel's Avatar
Be careful with the STP, I've heard it take 2 bottles to equal the Amsoil or GM EOS.
Where is everyone buying the Amsoil ZDDP?
Old 04-27-2010, 08:51 PM
Dello 15-40 along with probably any other of the major brand dsl specific motor oils.
Old 04-27-2010, 09:08 PM
Careful in what way? This isn't engine break-in...
I don't use any additives, just good quality oil, haven't had any issues with older engines.
1994 Caprice wagon
Old 04-27-2010, 09:47 PM
whowey whowey is offline
They are using Amsoil oil. Amsoil doesn't sell a ZDDP additive.
1990 GW cruiser/tow rig
CS-130 coversion
Old 04-28-2010, 06:57 AM
addicted's Avatar
Big Meanie
This is the Amsoil I run in my 4.0's; http://www.amsoil.com/storefront/amo.aspx
Old 04-28-2010, 07:35 AM
rixcj's Avatar
rixcj rixcj is offline
I buy ZDDP from Eastwood...
http://search.eastwood.com/search?asug=zddp&w=zddp+plus+oil+additive&p=Q&ts=c ustom
It frequently goes on sale, plus, if you join their members Club ( I did, I buy a lot from them...) you get free shipping.
Rich
1979 CJ5 with a 401...it goes a short way on a lot of fuel...
401, t-18/d20 twin stick, dana 30, amc20, D.U.I. HEI, Edelbrock Performer intake, Holley 600, ps/pb, 'glass tub, 1 pc tilt nose.
There's a fine line between "hobby" and "mental illness".
Old 04-28-2010, 08:48 AM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
http://i88.photobucket.com/albums/k168/mxmikie/ZDDP/dsc_133.jpg
Old 04-28-2010, 09:39 AM
Billygoat's Avatar
X2 - $2.29 bottle locally
I put a 2000 4.3 in a buddy's blazer and was surprised to see it was flat tappet - so what is a "newer" Engine???
"Thumper" - 1981 J-20 Extended Cab/sportside - REBOOTING.....
Old 04-28-2010, 09:54 AM
Cecil14's Avatar
The 4.3L (like the 4.0L) is a pretty old engine design, originating somewhere in the '80s. If I'm not mistaken the Atlas engines are DOHC now.
aa
Anthony
Old 04-28-2010, 09:56 AM
Josh D's Avatar
Josh D Josh D is offline
I'm using the Comp Cams break in additive from Summit. I just went ahead and bought 3 bottles. One for break in and two for the next consecutive oil changes. They recommend using it after break in, and since I'm running their cam and lifters it only makes sense. I'll probably be doing only 2 oil changes a year so the cost is negligible.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
OEM substitute ThisGuyUKnow General FSJ Discussion 3 05-12-2008 07:15 PM
What Do I Substitute for an '87 GW Starter Solenoid? 88sunroof General FSJ Tech 9 07-03-2006 08:02 PM
Lead substitute HectorHeadgear General FSJ Tech 2 06-12-2006 01:57 PM
Gasgacinch sealant substitute? hogwagon General FSJ Tech 7 05-13-2006 10:31 AM
Lead Substitute for my 327? Gambler68 General FSJ Tech 2 03-03-2004 06:22 AM
