Old 04-06-2010, 08:06 AM
TJDukit TJDukit is offline
Mounting pie plates
Ok so I have almost everything I need to finish my Rhino grill swap. I've already got the grill mounted up. Still need to figure out the headlight rings but I have some sheet metal I can make some brackets out of(metal from cutting out the hole for the hood release).
My next problem is how do I get the pie plates mounted up. If I set them up for the ribbing on the plates to go horizontal or vertical there is not a place for two screws on both sides.
Do I just need to weld in some metal to make it work? If needed I'll get some pictures up when I get home to show what I am talking about.
"And on the 8th day God created beer."
My J4000 build Thread http://www.ifsja.org/forums/vb/showt...=1#post1077331
Old 04-06-2010, 02:02 PM
cajun_lad's Avatar
cajun_lad cajun_lad is offline
Yes, IIRC that's how they did it on the Budget Beater project on Trucks. So, you can either weld on some tabs to have the ribs vertical/horizontal, or you can mount them slanted. Your choice.
Joey
Jeep-Less
CFSJC Vice President
Old 04-06-2010, 02:17 PM
Cool I figured as much. Since my pie plates aren't in that great of shape I might just put some lights in them, I've seen a couple pics with them and they look pretty sweet.
Old 04-06-2010, 05:13 PM
Does this thread help any?
http://www.ifsja.org/forums/vb/showthread.php?t=65517
I've been thinking about finishing off my rhino conversion for a long time, just haven't jumped.
Old 04-06-2010, 07:29 PM
Don't know if originality matters to ya but from the factory the fake vents were mounted verticle.
-Geoff Hill
Mounting Third Row Seat Questions/Ideas BrianAg95 General FSJ Discussion 0 09-25-2007 06:00 PM
Mounting a winch, feet forward or down? JeepsAndGuns Off-Road FSJ Tech 13 09-27-2006 06:15 AM
VA Safety Inspection 68 J brokechump General FSJ Tech 17 05-15-2005 12:24 AM
Razor Grill mounting difficulties Driftwood General FSJ Tech 12 08-20-2003 06:41 AM
Winch Mounting Ideas???? 88GW Off-Road FSJ Tech 4 04-29-2003 01:25 AM
