Old 03-23-2010, 05:18 AM
twmattox twmattox is offline
Approximate cost for removal and reseal of windshield
I have a very small water leak along the sides of the windshield (driving for an hour in the pouring rain yesterday resulted in just a few drops accumulating at the corner base gasket). Not wanting rust to develop...but also don't have a lot of extra cash. Any idea what it would run to have the windshield removed and re-sealed? Also getting some ghosting along the outside edge of the windshield (assume from age)...anyone know about what a new windshield runs? Just looking for ballpark costs... Thanks
Old 03-23-2010, 05:50 AM
Wagonforever's Avatar
Wagonforever Wagonforever is offline
When I checked a few years ago I was quoted $180 to have a new windshield installed.
There are those that have and those that will.
1986 Grand Wagoneer, BONE STOCK just the way I like em!
The Aviation Forum
Fred 08
Old 03-23-2010, 06:02 AM
I had one FSJ windshield replaced in 08 and another in 09 at $285 each.
edit: Both of them taken to the shop.
88 GW, 401/727/208, 5" lift, D44s/4.10s/locked up, 35s and a few Evil Twin mods,
Old 03-23-2010, 06:59 AM
freeincolorado's Avatar
freeincolorado freeincolorado is offline
I got a quote of $200 for winshield and labor, $75 for the gasket if it couldn't be reused.
1989 Grand Wagoneer:
One problem a time.
I aim to misbehave.
Old 03-23-2010, 07:43 AM
Sian09's Avatar
Sian09 Sian09 is offline
Last fall I replaced mine and all together for the glass and new gasket was $225.
'78 J10 Stock for now. 360, 44's F&R, T18, D20, TFI, 5 Slots, 31" ATs, Copper like color.
Old 03-23-2010, 09:37 AM
dflocks80's Avatar
dflocks80 dflocks80 is offline
I did mine last summer for $250. You save a good deal of money if you go to the glass place to have it done, as opposed to having them come to you.
EDIT: By the way, mine was a new windshield, not a reseal.
1989 Grand Wagoneer "Waggs"
  • Stock 360 and 727
  • Single piped Flowmaster 40 (with plugged AIR holes on manifold and heat riser valve wired open)
Leaks oil, needs a lift, but is mechanically sound.
Old 03-23-2010, 10:27 AM
seventynine's Avatar
You can probably fix the leak with some windshield sealant...specifically a flowable silicone. Permatex make some that is available at pretty much any autoparts store for a bout $5. It's real thin in consistency so it wicks into the cracks between the gasket and the glass.
I had the same problem on my J-truck...this stuff stopped the leaks. It won't help with ghosting though ...but it's easy on the wallet
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
'13 FLSTN Softail Deluxe
Old 03-23-2010, 11:22 AM
janie's Avatar
janie janie is offline
Dexron Impaired
Last one I had done was $175.00
