Hooking Up Factory Wiring On A Chevy 350 Swap
Picture #1 shows the connector for your windshield washer pump.
What you really need to do is lay the harness out of the ground and sort it out that way. Then many of the things will become obvious. There are distinct branches to the harness. For example, the windshield washer pump plug is nowhere near the starter solenoid plug (the dual plug with the short rubber piece between it in picture #6 of your original post).
Then take pictures of it. One wide shot and many CLOSE UP shots. LABEL each plug with a letter or number and then we can say "Plug D is for your choke", etc.Ethan Brady
www.bigscaryjeep.com
Originally posted by FSJ GuyPicture #1 shows the connector for your windshield washer pump.
I tried laying out the harness as best as possible under the hood but I don't want to take it out as I spent part of today putting it in. I'll play around with the photos in Paint and get some labels on them that way.
Since I'm not using the factory starter solenoid on the fender anymore, how does that part of the wiring get hooked up to the new solenoid on the starter? Just cut off both rubber boot connectors and splice both the wires into one new ring connector?Patrick
INNOVATIVE FABRICATIONS
Pic #3 goes to the cruise control governor.
Pic #4 looks like the plug that goes to the heater motor resistors on the heater core box.
Pic#5 Ring terminal on right hand side of pic goes the the battery side of starter solenoid.
Pic#6 The two joined connectors go to the starter solenoid.
Pic#7 Fat red wire goes to the alternator along with the white rectangle connector. The purple wire goes to either the temp or oil pressure sender.79 J10 Honcho 360/T-18/D20
Summit 8600 cam, GM TBI
78 Wagoneer 360/TH400/QT
Pic#7 Fat red wire goes to the alternator along with the white rectangle connector. The purple wire goes to either the temp or oil pressure sender.Patrick
I had a buddy of mine come over with a new meter toy and did some testing on the electical for me.
He says that the fat red wire in picture # 7 goes to the positive on the battery where as you were saying it hooks up to the post on the back of the alternator.
Also, he was saying the ring terminal wire in picture # 5 goes to the back of the alternator instead of the battery side of the starter solenoid. Anyway, I just wanted to get your input on it as I would like to see which way is correct.
Lastly, the small gauge black wire with the boot on the end in the upper part of picture # 7, where does it go? We applied power to it and couldn't see what it powers up.
Thanks again for all your help.
* Edit - Well, after spending a few minutes looking through the electrical diagram on www.oljeep.com , it looks like the original way you stated is correct. Any ideas with that last wire at the top of photo # 7 though? Thanks.Last edited by Rompn; 09-22-2010, 07:03 PM.Patrick
Originally posted by Chris P.What color is the wire?
One more thing, my buddy sniped off the double boot connector for the starter solenoid and I now only have one light blue wire going to it. You had mentioned both wires were supposed to go there. I looked around the engine bay and didn't see the other wire hanging anywhere so I'm confused with that as well. Thoughts?Patrick
It looks a lot like the A/C clutch wire. Are you sure its not brown?
The blue wire is what triggers the solenoid. The other one provided 12v to the coil during cranking on the stock ignition system. Now that you have HEI, you don't need it.79 J10 Honcho 360/T-18/D20
Originally posted by Chris P.It looks a lot like the A/C clutch wire. Are you sure its not brown?
Ok gotcha, thanks. So I take it the ignition wire now goes straight into the HEI port on the distributor? No relay?Patrick
