Old 03-21-2010, 03:32 PM
Pakistan Jeep Guy Pakistan Jeep Guy is offline
Project SOA in Pakistan - Help needed
Hello there
I have always wanted some bigger tires on my Cherokee.. Now I am getting down to (at least trying to ) doing it.. What will follow in this thread will be pictures and some explanation about what we are doing and what the progress is. We would need a lot of support and lots of knowlege and guidance from all the Gurus out there. The plan is as follows.. Time left is about 10 days till the upcoming Mud Rally in Lahore..
Spring Over Axel up front, Shakle reversal at the rear. Work on the stearing and brake lines after that. Traction bars if needed and drive shaft mods if needed. Loonger shocks as required (I hope I can find these). Tune up of engine. Battery boxes. Maybe a custom header plus a new high flow exhaust system. Some body work (just 'some'. Don't get excited guys. ). And a roof-top light bars with a couple of more lights.
I would need all the help regarding expertise from you all. I have seen a lot of builds here on IFSJA that have inspired me to go ahead with this now. I would appreciate all comments and suggestions on this.
Thank you
Ehsan
http://www.ijc.com.pk/forum/download/file.php?id=2449
Old 03-21-2010, 03:34 PM
Cant seem to link the pictures directly from the other site.. Here is the link to the thread with all the pictures..
http://www.ijc.com.pk/forum/viewtopi...6&p=2051#p2051
Old 03-21-2010, 03:39 PM
This may sound stupid but what axle is that?
http://www.ijc.com.pk/forum/download/file.php?id=2440
Closed knuckle something with disc brakes?
Old 03-21-2010, 03:40 PM
Old 03-21-2010, 03:42 PM
The front and rear
Old 03-21-2010, 03:44 PM
The front gets a spring over and the rear a shakle reversal only. Will that be needing any traction bars?
Old 03-21-2010, 03:47 PM
The brackets for the front SOA and the rear shackle reversal. These are 2/8" MS plates that were Oxy-Acetylene cut and bent on a press brake.
This is a 6/8" MS plate again oxy-acetylene cut that I plan to use for a set of custom headers for the Toyota 4 Cylender Deisel engine that runs the Cherokee.
Old 03-21-2010, 03:48 PM
Till now we have been able to get the front diff out to do work on.
Old 03-22-2010, 05:05 AM
Suhaib Kiani Suhaib Kiani is offline
The 35s...
http://www.ijc.com.pk/forum/download/file.php?id=2456
Found the right tires finally...
BTW those are Toyota BJ60/62 axles with 4.11 gear ratios.
Old 03-22-2010, 06:33 AM
Gambler68's Avatar
Rabble Rouser
I love those rims!! Not the best for wheeling, but sure look cool! Need some good old steel rockcrawler rims man. Aluminium ones like to crack and break (steel bends as you know, aluminium doesn't)
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 03-22-2010, 06:41 AM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
Looks like a Toyota Land Cruiser unit.
Perhaps I should pay better attention. duh
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 03-24-2010, 09:25 AM
Project Status as of March 24, 2010
Guys thanks for your feedback, Ehsan asked me to do a quick update with pics so to discuss some specific points and way forward.
We managed to do a mock SOA on the front and put in the tires. At the back we are waiting for the shackles which should be in by tomorrow. Here's what it looks like at the moment:
http://www.ijc.com.pk/forum/download/file.php?id=2457
We did a bit of playing around with the angle on the front axles (before any cutting), these photos are with the shaft/pinion angle aligned which left the steering hanging forward at a terrible angle:
http://www.ijc.com.pk/forum/download/file.php?id=2458
http://www.ijc.com.pk/forum/download/file.php?id=2459
http://www.ijc.com.pk/forum/download/file.php?id=2466
We are somewhat undecided on whether to re-arch the springs to get them a bit flatter and take away the extra arching from the earlier SUA position.
http://www.ijc.com.pk/forum/download/file.php?id=2462
At the back we are waiting for the shackles and the rig is standing on jacks at the rear:
http://www.ijc.com.pk/forum/download/file.php?id=2464
http://www.ijc.com.pk/forum/download/file.php?id=2463
http://www.ijc.com.pk/forum/download/file.php?id=2465
Shock length remains somewhat of an issue as we are not sure as to what is the ideal length, tower height or availability.
http://www.ijc.com.pk/forum/download/file.php?id=2460
http://www.ijc.com.pk/forum/download/file.php?id=2461
Old 03-24-2010, 03:48 PM
azpackrat's Avatar
azpackrat azpackrat is offline
Hey! someones messing with you, while you weren't looking they moved your steering box to the wrong side.
I agree the steering geometry in the second photo is not good, Jeeps like about 6* positive Castor, as much as in the photo and the steering components, not to mention the handling will suffer dramatically.
How do you intend to address the drag link to spring clearance? Is there a crossover steering option for the Toyota axles? with the Danas there is a great deal of aftermarket support, but I am unfamiliar with the Toyo's.
As for the shocks, I always set-up the lift, put the truck on the ground under normal weight, then measure from mount to mount and choose the shock that gives me the most extension and compression. Sounds simple but you have to find a vendor that's willing to work with you instead of just looking up a number
Old 03-24-2010, 05:22 PM
Old 03-24-2010, 05:24 PM
Thats as the Jeep stands. Lots of work to be done still..
Old 03-24-2010, 05:27 PM
Thank you for the input. We dont get any aftermarket solutions to cater for steering geometry on SOAs here in Pakistan.. This is probably the first FSJ SOA in the country. .
As for the caster.. I intend to cut and turn the differentials enough to get about 6 degrees of caster.. I got a spare diff housing to start working on in this regard.
Old 03-24-2010, 05:29 PM
We are thinkning about de-arching the front spring packs. Would love to hear your thoughts about that. Is that a wise decision or will that reduce travel and increase axel wrap?
Ehsan
Old 03-24-2010, 07:00 PM
azpackrat's Avatar
Instead of changing the the arch, why not just remove some of the leaves? that would reduce the spring rate and should flatten them out some and it's much easier to return them to the original configuration if necessary.
You could also try to find some salvage springs from an OEM spring over, like a Chevy or Dodge and use your main leaf to build a new spring pack.
I can't imagine the difficulty you have modifying your Jeep in your part of the world, it's hard enough sometimes here in the states were they're still fairly common, I don't suppose Jeep's were ever very numerous in the near Eastern nations as compared to Rover's, Toyota's, etc. So if some of our suggestions sound a little impractical, you'll have to forgive us like the European and Pacific Jeepers do
Old 03-25-2010, 02:59 AM
For the record:
CJs and FSJs were very common in Pakistan during the late seventies / mid eighties as these were used by the United Nations missions, the Pakistan Army and also imported by a local company. After the mid seventies YJs and XJs never really caught on around here and both the Army and UN moved on to Toyotas
60s and 70s Dodge trucks are also common as these were used by the Pakistan Army. Chevys are very rare around here, except probably used by US embassies etc and later auctioned. Nevertheless, finding any Jeep parts in half decent shape remains a tall order.... there is a market for smuggled parts from Iran in South Eastern Pakistan where Jeeps remain more in vogue than here, though that market is not very easy to tap for us here in Islamabad/Rawalpindi.
Front Dana 60 swap....without SOA? Grimjaw Off-Road FSJ Tech 30 10-26-2006 01:56 PM
to SOA or not to SOA? that is the question... AlsChopShop Off-Road FSJ Tech 30 06-21-2006 11:32 PM
SOA options & opinions baja Off-Road FSJ Tech 14 10-21-2005 04:35 PM
SOA project for 86 GW-ALL ADVISE APPRECIATED!! Oracle General FSJ Tech 21 05-09-2002 04:23 AM
Need help w/ a SOA project. Crash General FSJ Tech 23 09-23-2001 08:37 AM
