Old 03-15-2010, 03:29 PM
tjmackey1's Avatar
tjmackey1 tjmackey1 is offline
Rear tailgate window hand crank kit
Has anyone tried installing a rear tailgate window hand crank kit?
How did it go?
Does it work well?
Will it last?
Thanks for letting me know.
Old 03-15-2010, 03:53 PM
freeincolorado's Avatar
freeincolorado freeincolorado is offline
Lots of people swap manual tailgate guts into their power tailgate. I don't know if there is a kit, however.
Tom
1989 Grand Wagoneer:
One problem a time.
I aim to misbehave.
Old 03-15-2010, 04:03 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
Short answers:
Yes
Ok
No
NO
I was super careful installing mine & making sure it was aligned correctly. The crank was pretty notchy and just didn't seem to work that well. Sure enough, after a few cranks up and down the gears showed visible wear and slop. I thought it was just a bad unit & tried a second one. Same junk so I just rolled it up and I haven't used the rear window since. I'm going to find an electric one to put in this summer so I can actually use the tailgate. Moral of the story, be happy with your electric window.
Old 03-15-2010, 04:04 PM
tjmackey1's Avatar
Yeah there is a kit, they sell one at TeamGrandWagoneer.
http://www.teamgrandwagoneer.com/par...iled/2703.html
Old 03-15-2010, 04:06 PM
BamaDrew's Avatar
BamaDrew BamaDrew is offline
Last time I checked BJ's Offroad has the tailgate handle part. Do you have manual tailgate already? If so, basically all you have to do is take the screws out that are on the outside of the vehicle under the cover on the handle. The lock cylinder and handle are all together as one piece when they are screwed together. I can't remember if there is anything on the other side behind the access panel...having a senior moment right now and I just took my manual tailgate assembly out a few weeks ago to prep for paint. I don't believe there is. It should slide off then.
If you are looking for a manual tailgate regulator and want OEM be sure that you don't wind up like me and get one that has a tooth worn down and binds up. There is an aftermarket regulator/handle kit that Team GrandWagonner sells...manufactured by Crown. Lots of people say that they aren't any good because the handles strip out but I haven't had an experience with one to say for myself. I'm probably going to give one a try. I didn't pay much less for an old OEM one.
As to if I recommend manual, for me I prefer it because my electric regulator was garbage when I got this Jeep and I dislike wiring/electrical nightmares more than anything...present and future. If you have a working electrical regulator with no issues stick with it as long as you can and plan to swap to manual when it croaks if you want to go that route. Just my two cents worth...
Good luck!
Old 03-15-2010, 04:07 PM
Ghinmi's Avatar
Super Moderator
If you can find an original you're all good. The new ones are junk, junk, junk.
Old 03-15-2010, 06:11 PM
TPICherokee's Avatar
DON'T BUY THIS KIT! IT IS CRAP, WE USED TO SELL THEM!! The manufacturer refused to fix the inherent problems so we quit selling them.
Old 03-15-2010, 06:57 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
they were based off the earlier model rigs, and the splined shaft won't extend out far enough. You'll use it a handful of times and the crank will strip, as will the splined shaft.
BJ's Off-Road
ryan@bjsoffroad.com
Old 03-16-2010, 06:31 AM
BamaDrew's Avatar
Wow that's pretty junky. You know, comparing the gears in the electric regulator and the manual regulator they appear to be the same...I wonder if you could change out the gear with the worn down tooth with a good one off from the electric regulator....might warrant some further investigation....
Old 03-16-2010, 07:43 AM
billyrb's Avatar
BJ's Off-Road
I'm talking about the splined shaft that protrudes through the gate, and not the regulator gears
BJ's Off-Road
ryan@bjsoffroad.com
Old 03-16-2010, 11:26 AM
tjmackey1's Avatar
Darned if I do, darned if I don't... times like this when GW owners start to drink more, if possible.
So I can't find a new switch to replace to one that is shot in the tailgate and the hand crank kits are junk. Any thoughts?
Old 03-16-2010, 02:16 PM
BamaDrew's Avatar
I know...I was talking about for my situation...since I have an old electrical regulator with decent gears and a manual regulator with a not so great gear then I could perhaps take a gear off the electric regulator and put on the manual instead of getting a Crown piece. I knew people talked about the handle stripping out on those but never knew about the spline shaft and that the part was modeled after early waggy setups.
Old 03-16-2010, 02:21 PM
BamaDrew's Avatar
Hand crank kits aren't junk...it's just finding a good one! You might look up Millerluck here on the forum...he was on a mission to get a few manual regulator kits to change out the electric regulators on all his rigs...he's a pretty big fan I think as am I....I've just got to make mine work by trying to change out some of the gears to take care of that worn down tooth.
Ryan provided us with good info on the spline shaft not being long enough on the aftermarket part so if I were you and was wanting to change out to manual I'd post for one in the Wanted forum. You just need to make sure that you have one that has no teeth worn down and doesn't bind up.
I am sure someone else will chime in on the electric switches.
Old 09-08-2014, 03:36 PM
caionneach's Avatar
caionneach caionneach is offline
The following link describes how this fellow scavanged a Blazer tailgate for the manual regulator & handle from a Blazer to fit into his Suburban. Looks like the Chevy boys are having similar problems.
http://coloradok5.com/forums/showthread.php?t=255667
So I wonder if the Blazer handles will fit our units with manual tailgate windows.
I just installed the manual kit from Z&M Jeeps, and for awhile, it worked ok. But the handle came off (the tailgate) in my hand yesterday: one of the washers behind the brass bushing on the handle fell off leaving the brass bushing on the regulator spline. I was able to ease the brass bushing off the regulator spline and put it back on the handle, but the washer is gone. Hopefully it is in the tailgate, and I can fish it out later then reassemble the handle kit.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 09-09-2014, 07:03 AM
serehill serehill is offline
Gone,Never Forgotten.
Fix your electric one.
You can rebuild the entire electrical system. check the homegrown vendors.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 09-10-2014, 12:06 PM
caionneach's Avatar
Gary Holmes, in a similar discussion here: Tailgate with manual rear window has the solution -->
I did the conversion on the CAMO COW just recently. Biggest PITA was the handle. The assembly is held together by pressing on a brass/bronze busing loooking piece that had a tendency to pop off and disassemble the whole handle. I drilled and pined the bushing in place and no problems since.
I have the stock handle that came with my vehicle. The internal of the handle which attaches to the regulator had stripped eventually, but the bushing and washer assembly never dissassembled. Looking closely at it the brass bushing has a deep indentation on either side which was pressed into the bushing under pressure. Any handle I have purchased from BJ's Offroad or Z&M did not have that indentation. I think this is the fix I've needed.
1982 Cherokee
rear window removal david barnes General FSJ Tech 6 07-12-2006 07:06 AM
Rear Tailgate Window greaser General FSJ Tech 3 07-27-2004 04:26 AM
Tailgate with manual rear window BIG BAD JON General FSJ Tech 7 02-03-2003 12:19 AM
#$!!@%$#!! Rear window! Narnian General FSJ Tech 7 05-30-2002 03:00 AM
