Old 03-04-2010, 06:25 PM
holley2346 holley2346 is offline
Loud sound in the drivetrain
I can't figure what it is, and I know it could be a lot of things... so just throw out some suggestions. I basically am hearing a loud roaring sound and sometimes it sounds like when you cut metal with a band saw.... this only happens around 30 mph and up.
My mechanic said he thought it was the throwout bearings, but I'm not sure.... the carrier bearings, pinion bearings, and axle bearings looked good last time I took it all apart (about a week before this started).... also note I did run the rear end almost dry, and was pretty hot when I realized that it was leaking.
Thanks!
1974 Jeep j10 / AMC 360
Performer Intake / Edelbrock 650
Mallory HEI ignition / Comp Cams low end cam
6" Lift Spring / SOA / 1" Shackle Front
Shackle Flip / 4" Block / 3" AAL Rear
3" Body Lift
38.5x15 Super Swamper TSL Boggers
Corporate 14 Bolt Rear / D60 Front (4.88)
Build Log
http://www.ifsja.org/forums/vb/showthread.php?t=114629
Old 03-05-2010, 12:52 AM
onesunJ10's Avatar
onesunJ10 onesunJ10 is offline
More info.
So, it happens above 30mph? Only when you are in gear? Does it disappear when your foot is on the clutch? What about when you rev the motor? Does it change when you are in 4hi? Do you have a T18 4 speed? etc.
My throwout bearing went out last year and it sucked. It was a loud and obnoxious whirring sound, but it was related to the motor RPM, not so much overall speed . It blew up while i was driving and sounded like someone threw a bunch of BBs in my bellhousing all at once. I literally powershifted 240 miles back to my house.
My 1977 J10 on 1tons and Krawlers
If you wheel on the west coast or you hit the Hammers, look for my crew, the PolyGoats: www.polygoats.com
Poundcake!
Old 03-05-2010, 01:02 AM
BigGreenMonstaWagoneer's Avatar
BigGreenMonstaWagoneer BigGreenMonstaWagoneer is offline
Noisey
Yeah dude, sounds like clutch related. If it doesnt make the noise while sitting still but gets louder as you turn the engine, sounds like a clutch related deal. My Wag makes growls and such but i know when something isnt copesetic. When it makes the noise, can you feel it by resting your foot on the clutch?? It would kinda pulsate with the sound. Been there many times in my old 73 J-10 (RIP). Also, make sure your flywheel bolts are torqued..been there too. Let us know what you find out. Godspeed
Old 03-05-2010, 04:26 AM
couple questions on rear axle:
Did you flush out the axle tubes and housing after you had debris floating around in there?
Ran it dry - have the bearings and seals been replaced on the shafts since then?
Old 03-05-2010, 05:28 AM
It was only driven around 15 miles or so without being completely full, no I have not replaced anything.
3" Body Lift
Build Log
Old 03-05-2010, 05:30 AM
Originally Posted by onesunJ10
More info.
Yes, it is a 4 speed..... it really sounds like it is speed related and not rpm related.... I used to be able to let go of the gas and then push the gas again and it would stop for a while. Now it does it any time the gas petal is pushed.....
That's what makes me think that it's not bearings in the rear end, because it does NOT make the sound when the gas petal is not pushed down, and I'm coasting down the road.
3" Body Lift
Build Log
Strange Humming sound shadowfax101 General FSJ Tech 6 05-08-2006 11:09 AM
loud pop sound from rt frt axle... Sgt Rock General FSJ Tech 7 10-18-2005 04:45 AM
New carb and loud hissing sound JeepPhamilee General FSJ Tech 3 07-04-2005 01:59 PM
Loud 'ClunK' from front drivetrain when accelerate hard barillms General FSJ Tech 2 06-12-2002 02:18 AM
loud grinding sound from distributor JB General FSJ Tech 7 10-21-2001 06:22 AM
