Old 03-02-2010, 08:31 PM
automan2164 automan2164 is offline
Tow rig, does it have what it takes?
Hey guys. Just want to say hello again, and I have found another potential truck. As some may remember, I was looking for a tow rig with some style, and recently considered an '89 GW, but gracefully bowed out at the advice from you guys on the price. Just recently, I found another FSJ. This time its an '84 J10, 4.2L, 4 speed, 4x4. Don't know too much about it at the moment. This is what I got from the current owner.
North Carolina truck, he flew down there, and drove it back to Milwaukee, WI ten years ago. Immediately got a "Professional undercoating and bedliner" on the return, and DD'd it except for when the snow flew... Recently, it has a rough idle with the choke off, but smooths out with the choke applied (Vacuum leak?). I haven't gotten the miles yet, but he sent some pics. He isn't sure what he wants at the moment, but thinks its going to be in the "$1000-1500" range.
Basically, I know a 360 would fit the bill a little better, but this thing is pretty clean, and might be a good deal. I might tow a vehicle from time to time, on a dolly more than a trailer, and only to shoot a project here and there (XJ's, MJ's... nothing full sized). Does this have what it takes? Or should I keep my eyes out for a 360 J20? I don't care about speed. What I do care about is taxing a vehicle, and overworking the drivetrain. So good deal? Pass? Keep looking?
Thanks in advance fellas.
Rob L.
'98 ZJ Limited
'87 Comanche Metric Ton
'86 Comanche Factory Diesel
Moderator, www.ComancheClub.com
Old 03-02-2010, 08:44 PM
Long&Low's Avatar
Long&Low Long&Low is offline
IMHO, the six cylinders are not geared low enough for decent power for towing.
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
'68 CJ5
'92 YJ
'06 Commander
Old 03-02-2010, 08:45 PM
rockin wagoneer's Avatar
rockin wagoneer rockin wagoneer is offline
It would depened on the motor is it the 304 or 358? if it the 304 it should b ok but your right the 360 prob would be better and also check the cabs.
love it,live it,be it JEEP!!!!
79 cherokee- dd on 36s
78 wagoneer-rebuilding
Old 03-02-2010, 10:19 PM
mdill's Avatar
mdill mdill is offline
Flat land towing a dune-buggy around my 77 J-10 (258 T-18 D-20) of yore, was OK.
not fast and I did not pull any hills, it had a hard enough time pulling Parley's canyon out of SLC Ut. with a snow mobile in the back.
But it had 4.11's and I don't think the later ones went that low.
I guess if you have short flat pulls to do it might be OK, but it won't
be a very robust tow rig.
Mike D.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 03-03-2010, 07:13 AM
jason44406 jason44406 is offline
I don't think a 258 could pull a car+trailer without strain. It could probably do it, but sure wouldn't be happy about it.
The second pic looks like the bedside is bowing out?
Old 03-03-2010, 07:21 AM
The 81 shortbed J10 I owned back in the 80s was a 258 with 31s and I flat towed a Wagoneer a couple hundred miles behind it. Also towed a 65 Marlin 1600 miles behind it. I would hate to pull many hills that way but it got the job done. If I were looking for a tow rig, it would have to have a V8. We prefer to use our J20 w/401 for towing. Outside of age and potential for something to go wrong with a 33 year old Jeep, it gets the job done pretty well.
Old 03-03-2010, 07:31 AM
My PO flat-towed his CJ-5 all over New England with my J-10. He said it was fine, if a little slow to get to speed. Just FYI, with a 1/2 ton truck, U-Haul will not rent a car trailer to you because the tongue weight will be too high with any car larger than, say, a Fiat 850.
Axle ratio in my truck is 3.54, and an '84 will be 3.31? The T-176 in an '84 is not as strong as my T-15, but first gear is lower (3.52 or 3.82 v. 3.00 with the T-15).
Old 03-03-2010, 07:43 AM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
Like I said in another topic on this forum, the 258 is best pulling cars and early 80s Ford pickups with bigger engines that don't run and have a flat tire around the house. It's best to find those V8s with the 4 barrel carburetor factory installed. They were built for the job.
CJ
-1987 Grand Wagoneer "Nodoka" - 360/727/NP208 (SOA/ft Lincoln Locker/rr Lincoln Locker)
-1985 Ford LTD Country Squire "Rarity" - Con car/DD
-2008 Saturn Astra XR "Mighty Mouse" - Daily driver
Old 03-03-2010, 10:53 AM
threepiece188 threepiece188 is offline
Like many posters said, the 258 will do what you want but you will have to be patient at times. I have towed other FSJ's many thousands of miles with my J10 and Wagoneer, both are equiped with the 258. Entering busy freeways when traffic is moving over 50 mph and maintaing speed up hills are my biggest concerns as far as power goes. I don't like towing with the Wagoneer. I think the wheel base is too short for such a heavy load. Setting the weight distribution on the trailer properly when towing with a Wagoneer is an important part of maintaining control of the trailer. It likes to have a little more tounge weight than the springs care to support.
I am currently building a J20 (which wasn't available for civilians with a 6 cyl. eng.) for work and towing duty. A 258 will be powering this truck too but my sense of paitence isn't lost when I get behind the wheel.
Dan
I blow my horn before it happens, not after.
A good mechanic can fix their own mistakes.
Waste not war not.
Ignorant is blist.
When you're in a hurry... slow down.
Measure once... cut twice.
Old 03-03-2010, 01:10 PM
I agree with the Wagoneer wheel base comment. Both of these trips were slow and tedious coming down from north of here.
Old 03-03-2010, 02:49 PM
What's going to hurt you in an 84 J10 is the crappy axle gearing std is 2.73 or opt 3.31's Neither are tow gears by any stretch of the imagination.
-Geoff Hill
Old 03-03-2010, 03:20 PM
INDEED! My 81 J10 mentioned above was 2.73. It hated the short ramps to the expressway.
The GW and J20 have 3.73 gears and 32/33" tires which work pretty good for the pull. The brakes on the GW are not suited for stopping the load coming off 10,000 mountain passes though.
Old 03-03-2010, 03:57 PM
The PIG Smith's Avatar
King Browless
IMHO, a great tow has a Diesel drivetrain!
HAHAHAHAHA (just kidding)
Here is Nathan and my Diesel Tow Rig Van ready to haul a J Truck Bed to Detroit, MI
My 3500 series van has the weight and long wheel base for a great tow rig.
It's 6.2L Diesel is not a powerhouse, but is thrifty on fuel.
The 14 bolt FF rear axle with its 4:10 gears helps a lot with towing.
Bryan Smith
1982 J10: Replacement engine now sitting in the truck! No Cab Brow! Future DD
Originally Posted by Jayrodoh
Originally Posted by Lindel
because Ristow sez so
When the IFSJA forum has a problem go here:
www.fsjnetwork.com
Old 03-03-2010, 04:30 PM
AMC-J/20's Avatar
AMC-J/20 AMC-J/20 is offline
6.2L Diesel . . .
Mike
1953 Studebaker M275.
1962 GMC 4500.
1969 AMC AMX-390 Resto.
1977 Ford F350.
1982 AMC Eagle project SX/290.
1982 AMC/Jeep project J5500.
1988 AMC/Jeep project MJ/343.
1992 GTA Trans AM.
A M C Means jeep to me
Old 03-03-2010, 05:02 PM
Artisan's Avatar
Artisan Artisan is offline
I drove a GMC C-4500 4X4 Kodiak pulling a 22' trailer from Los Angeles to the Texas Panhandle and back via every state park inbetween and I will NEVER be the same...some day, some day the money gods will find me in good and accepting health.
Regards,
Artisan Copyright 2010 ©
1979 Jeep J-10 (Soon to be J-30)
J-30 Theme Tune
UNDER CONSTRUCTION
Old 03-04-2010, 12:52 AM
Wait, did pickups come with muscle grills and rims with gold inserts?
CJ
Old 03-04-2010, 02:01 PM
mdill's Avatar
Jeep Pickups and Cherokees shared grills, Wagoneer/Grand_Wagoneer's got the High brow grill(s) to set them a part from the pedestrian Cherokee/J-truck crowd.
Old 03-04-2010, 04:01 PM
Ok then. What are the brows lol
CJ
Old 03-07-2010, 01:11 PM
Thanks for the input guys. I might go take a look at it just because its decent looking, but pass because of the 258. He figured out that he needed a carb to get it going right, and I know someone who has a stock carb off of a '70 something CJ-5. I am going to pick up the carb and run it up to him while I look at the truck.
Question though:
The guy with the stock carb also has a complete intake, and 4 barrel carb setup to convert a 258 to a 500 CFM 4 barrel for $450. If I bought that, and the j-10, assuming it has the optional 3.31's, could this be a viable option for occasional towing/trips around town? I guess what I should be asking is will it suck-less? Ha. Anyone else running a 4 barrel on their 258 with input?
Again, thanks guys, your knowlege always helps, and educates myself.
Rob L.
'98 ZJ Limited
Old 03-07-2010, 01:29 PM
letank's Avatar
letank letank is offline
Originally Posted by AMC-J/20
6.2L Diesel . . .
Mike
2X, for a tow rig, if going above 4000' altitude, a turbo is needed
Michel
74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to Moab without a rebuilt? Status: debugging a few electricals.
85 Gwag, 210 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
my jeep aid images
http://picasaweb.google.com/jeepmr/FSJ
front tow gtgphd General FSJ Tech 10 07-13-2006 10:26 PM
Flat Tow vs. Tow Dolly Slick Willie General FSJ Tech 16 11-13-2005 11:11 PM
tow hooks: where/how to bolt on stock GWag ? GED General FSJ Tech 9 06-20-2002 11:08 PM
what makes a tow package a tow package? Paul General FSJ Tech 10 02-09-2002 01:42 PM
To flat tow, dolly, or not at all? K-Centre General FSJ Tech 5 11-15-2001 05:36 AM
