Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Old 02-24-2010, 12:48 PM
mdill's Avatar
mdill mdill is offline
AMC/Jeep V8 alternator (CS144) bracket (in stock !)
Lower tension brackets that make swapping in a CS144 alt. a little easier and cleaner.
Front view installed
Back view
Why you want this for doing a conversion: (If your AMC/Jeep had the standard SI-10 or SI-12 Alt)
Slot radius is correct for the CS144 larger frame.
Slot hole is 10mm for the tension bolt
Slot placement allows for more adjustment range, with the larger frame CS144.
Bracket clears the oil pump housing
They are avalible in stock,
$35.00 (single) $60.00 (pair) Total price shipped in the lower 48 (USA)
Either Postal Money order
Or pay-pal from a verified account.
PM for address.
Thanks Mike D.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 04-25-2010, 09:30 PM
j10jim's Avatar
j10jim j10jim is offline
Still available?
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 04-29-2010, 07:02 PM
j10jim's Avatar
Payment?
Old 11-14-2010, 08:55 PM
effstien's Avatar
effstien effstien is offline
Good Product
Shipped fast and worked great. Great Quality.
Thanks.
Addicted!!!
Old 11-15-2010, 02:00 PM
The PIG Smith's Avatar
King Browless
X2
With this excellent bracket, the CS144 upgrade has to be in the Top 5 Easiest FSJ upgrades.
Bryan Smith
1982 J10: Replacement engine now sitting in the truck! No Cab Brow! Future DD
Originally Posted by Jayrodoh
Originally Posted by Lindel
because Ristow sez so
When the IFSJA forum has a problem go here:
www.fsjnetwork.com
Old 11-18-2010, 11:08 AM
mdill's Avatar
Good to see them out there being used by happy Jeepers
Mike D.
Old 11-22-2010, 03:01 AM
TugNchug78's Avatar
TugNchug78 TugNchug78 is offline
gonna need one.
i will need one of these brackets in the next week or so. i do hope you have some still available.
This is the only part of the mounting bracket that had to be modded correct?
Thanks!
1984 GWaggy - BJ's 6" spring lift, 360/TF727/208. emission deleted, Hydroboost, Taurus fan, Hedmen headers, edelbrock intake and carb, Magnaflow exhaust.. AMC 20 W/ Detroit out back and Vac disco D44 upfront W/ poor mans ARB mod, York compresser converted for OBA. 35" BFGs on cheby rims.
Status: Under the knife for drive line repair
Old 02-22-2011, 11:42 PM
mdill's Avatar
Couple notes from common questions:
Are the brackets available ?
There are ~0 of them left.
Parts needed :
Bracket (Duh, look what section this is in )
Though many have had success modifying the stock SI-10/SI-12, but they have limited belt adjustment range, and the stock bracket may hit/rub interfere with the oil pump housing. YMMV
CS-144:
"1996 Cadillac Deville 4.6L 1994-1997 (Without Heated Windshield defroster)
Cadillac Deville Concours 4.6L 1994-1997 Cadillac Eldorado 4.6L 1993 Cadillac
Eldorado Sport Coupe 4.6L 1994-1997 Cadillac Seville SLS 4.6L 1993-1997 Cadillac Seville STS 4.6L"
Is the easiest to use for clocking/mounting, other version can be run but might
require some messing around (re clocking, adding threaded insert in the tension
ear ...)
Belts:
Stock are a little on the short side Gates 7516/Napa NBH 257516, work well with this bracket.
Matched sets seem to be a thing of the past, so compare them, match lot numbers, in a pinch measure them and go though the parts store inventory to find the best possable match.
Harness adapter:
NAPA ECH82 (Summit, Delco .. also sell these) adapts your current alternator harness plug (All FSJ's with Delco alt. , all after ~1977ish) to the CS-144, and has a in-line resistor)
Tension bolt:
10mm-1.50 flange or washer bolt.
Installation and wiring:
There are many threads (sorry if I missed one or two) do a search, know your goals and keep it simple.
General theory of operation (Know what you are doing, read this)
http://oljeep.com/AltTheory17/AlternatorTheoryVersion17R1.htm
Serpentine belt pulley removal from the CS144:
http://www.ifsja.org/forums/vb/showthread.php?t=131960&highlight=cs144+pulley
General mounting (OEM Delco SI-12/SI-10 rigs)
Check the pulley alignment, you may need to add a washer or to to the long tube spacer, some need to be shimmed out a hair some don't.
The CS-144 is going to be more picky with loose or glazed belts, it can require as much as 2X the torque to turn at full load vs. the smaller alt. at the same RPM. ( 140 amps requires ~twice the torque/belt load vs. 70amps, at any given RPM)
Wiring:
In general: Do not expect your current output wire to handle the 140 amps a CS-144 can output, without creating a fire hazard. A larger gauge wire directly back to the battery, is pretty much mandatory. (fuse or fusible link in this wire is highly recommended)
If you jump start someone, the CS144, will attempt to provide full current (140 amps if at high idle) to your battery connection, you do not want a small gauge wire trying to carry this current back to your battery, (GM used a 6ga wire for the output, many have gone larger 4+ga. )
There is a couple diagrams in this thread, on possible way's to power the current fuse box, http://www.ifsja.org/forums/vb/showthread.php?t=115116&page=4&highlight=CS144
I think most users use the current 10ga Yellow (has a fusible link) as the feed, some use the Red old alt output line (now unused but still hot)(you would need to add a fusible link as there is none, if you use the Red), either is fine IMHO, I would not use both, and using both would IMHO create a hazard, due to the added short circuit current from two parallel fusible links. If you use the Yellow feed, be sure to isolate and secure or eliminate the unused old output wire it is still going to be hot, and could make a mess if left floating around waiting to short out, similar note for the Yellow if you use the Red wire.
The large alt is not to feed more power to your current system, it is there to handle non-stock loads, (Winch, Plow pumps, jump-starting, ghetto-blaster sound systems, electric fans, off road lights ....) as such place you new loads on the output of the alt, do not hang large non-stock loads off you current fuse panel.
Since the stock ammeter is of no use, here is a neat solution to add a volt meter in it's place:
http://www.ifsja.org/forums/vb/showt...ight=voltmeter
Wiring Diagrams for many FSJ's are here
http://oljeep.com/gw/elec/GW_wiring.html
I am sure I am forgetting missing some good threads on converting to a CS-144.
Mike D.
Old 03-11-2011, 08:34 PM
Rudys78J10 Rudys78J10 is offline
Got my bracket today. Fast shipping. Good quality part. I will install it on Monday. Thanks Mike!
2007 Silverado - My DD
2008 XK - GF's DD
2000 TJ - GF's toy (soon to have 4" susp lift, 2" bl, 33's)
1978 J10 - My new toy
Old 07-13-2011, 03:53 PM
mdill's Avatar
bump.
Old 08-17-2011, 10:04 AM
bshoke's Avatar
bshoke bshoke is offline
I got mine in, they are really good better than what came with my engines
1982 Wagoneer, 360, cs-144, AC, 2 wheel drive soon to have a np219 like it started life with.
1981 Wagoneer, 360, np208, starts rolls around the yard in the process of getting back to running, stock tape player works radio tuning knob does not.
Old 08-19-2011, 06:52 PM
gotgas's Avatar
gotgas gotgas is offline
pm sent
86 Wagoneer,Hei,Flowkooler,Electric fan,Electric fuel pump,Bjs 6" lift
Old 08-23-2011, 07:46 PM
Myke Honcho's Avatar
Myke Honcho Myke Honcho is offline
I am having to completly rewire my truck so I'm planning on upgrading the alt. Will this bracket work on a 72 360? Also say I want to use a cs130 I think they have the same case and should b interchangible right?
72 J4500, 360 th400, d20, d44s
Old 08-23-2011, 10:14 PM
mdill's Avatar
Sorry, It is not any help for someone who wants to run a small frame CS-130.
The bracket is built for swapping a large frame alt (SI-15 or CS-144), in place of a small frame Delco SI-10, SI-12, and reusing the rest of the OEM Delco brackets.
Also around 72 ish AMC changed the accessory stuff around, I am not sure that later pulley offset's such are the same, and if a later bracket set by itself would would play with the 72 setup.
Wish I could help, but this is not the correct part for your application.
Mike D.
Old 08-28-2011, 09:45 AM
gotgas's Avatar
I received mine the other day. Haven't had a chance to put it on yet, but definately a quality piece.
Old 12-06-2011, 01:03 PM
adzam adzam is offline
Please let us know if you manufacture any more of these brackets. I might be interested as well...
Old 12-25-2011, 08:22 PM
aallison aallison is offline
Depending on price, I could use one.
Old 01-26-2012, 07:53 PM
I got one and it's a quality product. Nice work.
Old 01-26-2012, 09:35 PM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Mike, can you let me know when you have more in stock? What was the price on these, I forget.
Scott R.
'86 Wagoneer "Honey Badger" 360 / TBI / WT conversion / TT's Fabworks Shackle Flip and SOA / 35x12.5x16 BFG Mud-Terrains (Project Link)
'78 Cherokee Chief 360 / SOA / 35's (Son's Jeep)
Old 01-27-2012, 12:42 AM
MonsterZ's Avatar
MonsterZ MonsterZ is offline
x2, planning on doing this upgrade soon too, still available?
'75 Wagoneer, bone stock, about to be a whole garage of parts. Tear down starts 3 March, 2012,
see how long it takes to put it back together....
'91 XJ, 3 in Rough Country lift, 33's, Rattle can paint job, roof rack and cheapo off road lights. Diffs and winch next
Body Lift Bumper Bracket Mod Murphy General FSJ Tech 1 02-24-2008 12:02 AM
Rear Window Install -- what did you use to seal the window to the lower bracket rmorit01 General FSJ Tech 8 03-30-2007 05:37 PM
Alternator bracket spacer? 70sWagoneers General FSJ Tech 0 10-09-2006 09:03 PM
72 Wagoneer -- A/C Bracket broke -- ate bypass hose ! marmoset General FSJ Tech 2 06-23-2003 03:58 AM
Water Pump Woes + Alternator Bracket marmoset General FSJ Tech 5 03-24-2003 10:18 AM
