Old 02-18-2010, 08:09 PM
Ted21227 Ted21227 is offline
Tire Size
Can I run 31 x 10.5 tires with a stock rim on my 87 Grand Waggy or will they rub? Everything is stock with no lift.
Old 02-18-2010, 09:09 PM
freeincolorado's Avatar
freeincolorado freeincolorado is offline
I was running some Chinese built 31's on the stock wheels and they didn't rub to bad, only when the wheels were at full lock and the suspension was flexed. I switched to 31" Mtr Kevlars on 15x8 wheels and they rub like crazy.
Tom (Productive Member of Society)
1989 Grand Wagoneer:
Some stuff stock, some not.
Transmission Troubles
Old 02-19-2010, 07:33 AM
billyj7175's Avatar
What backspacing is on the new wheels?
Where does it rub? Those MTR's have a meaty tread that continues down the sidewall. That and the 8" rim makes the setup considerably wider than the setup you had on there before.
I see a lift in your future...don't ya hate it when you HAVE to put a lift on?...haha
83 J-10 Jeep "Oscar"
727 & 229 are rebuilt, but the 360 is in an incalculable number of pieces, sporadically disseminated all over the garage...
4" Rusty's with 33X12.50 Pro Comp MT's
Old 02-19-2010, 08:04 AM
FSJ Guy FSJ Guy is offline
31's rubbed on my stock wheels when I had no lift.
Ethan Brady
www.bigscaryjeep.com
Old 02-19-2010, 05:58 PM
I'm running 31's and they rub only when I turn all R o L.
Old 02-20-2010, 05:57 AM
Backspacing is 3.75" I believe. Probably going to put BJ's 4 inch kit on it later this year.
Old 02-20-2010, 06:27 AM
twmattox twmattox is offline
FYI, I am fully stock '88 GW. 30x9.5x15 BFG TA/KO do not rub...
