Old 02-18-2010, 12:05 AM
MischiefMan MischiefMan is offline
Little Gems
I saw this on an MJ forum and thought it would be a good idea here....
I'm not looking for a FAQ here, I'm looking for those warnings or little gems of knowledge that you want every owner to know, but they'll likely not ask about until it's too late.
So, whatcha got?
I've been told to check for rust above the gas tank skid area. What else?
'78 Cherokee
Old School Cool
Old 02-18-2010, 07:19 AM
twmattox twmattox is offline
Vacuum hoses...replace them
The charcoal canister (and vapor separator) are measured air bleeds for the carburetor
Charcoal canister...purge signal diaphragm gets rotten and leaks (causing fuel mixture issues)
The EGR requires back pressure to operate (it is a 2-stage EGR)
The stock gauges are not terribly accurate
Old 02-18-2010, 07:26 AM
dlowrance's Avatar
dlowrance dlowrance is offline
ammeter bypass - AKA how to prevent spontaneous combustion
keep your drain ports clean if you want to keep your floorboards
proper grounding of wiring will save you serious headaches...always check your ground
modern motor oil will eat your camshaft lobes
and finally...
...an ounce of prevention is worth a 5 mile walk to town...
Dale
80 W/T Cherokee - "Liz"....4bt??
69 J3000 DRA Dump - King Triton!!
Old 02-18-2010, 08:09 AM
Jeepstress's Avatar
Jeepstress Jeepstress is offline
Marchesa de 401
http://www.ifsja.org/tech/misc/buyfaq.html
Krista - High Priestess of Our Lady of Eternal Combustion
77 401 Wag "Phoebe" ~ 77 401 J20 "Artemis" ~ 76 401 SOA Wag "Luna"
The worst thing about rolling my jeep.....is trying to lick the paper...
Old 02-18-2010, 09:28 AM
Now, that's cheating!!!
And, besides, I was looking for something a bit different from what people normally find in FAQ's.
'78 Cherokee
Old School Cool
Old 02-18-2010, 09:39 AM
OK, I'll bite...
It is a whole lot easier to fix vacuum problems with the help of a MityVac hand vacuum pump w/gauge than with just guessing, replacing all the vacuum hoses, getting them connected wrong and screw it up worse.
Wake up and put the right juice in your QuadraTrac.
Don't ignore those funny sounds coming from the rear axle at 65 mph.
Old 02-18-2010, 09:40 AM
El_Diablo's Avatar
El_Diablo El_Diablo is offline
Originally Posted by twmattox
...back pressure...
not picking on you but your post sparked a little gem-
back pressure is a myth when it comes to exhaust design, its all about flow vs. velocity
that and you can rebuild your own 4wd vacuum actuator with some RTV an o-ring and a cotter pin, total cost is around $9 max if you have to buy a tube of RTV, but lets face it... if you own a jeep you already have about 5-6 laying around randomly, lol
Old 02-18-2010, 09:42 AM
back pressure is not a myth if your cat is clogged up
Old 02-18-2010, 09:45 AM
El_Diablo's Avatar
im not talking about the presence of pressure in the exhaust system, only it having an effect on power and or torque output, in truth, the less pressure in the exhaust, the better, no matter what
Old 02-18-2010, 09:48 AM
yep, yep, yep - let those cubes breath!
just sayin I was clarifying another back pressure point that is not myth
Old 02-18-2010, 09:52 AM
lodmccloud lodmccloud is offline
I do not know on a truck motor that turn 4000 rpm but on my 542ci mopar stroker I went from 3.5 inch exhaust on both sides running thru one chamber flowmasters with an x pipe to 3inch with and x pipe and 2 chamber flowmasters and picked up 12hp and 22 ft lbs of torque. It was scavenging so hard at 6000+ RPM it was pulling fuel out of the cylinder during valve over lap. So a little less velocity can help sometimes.
Old 02-18-2010, 09:55 AM
Suggestions for lil gems:
1. Bolt in (or requiring very little mods) parts from non-FSJ junk yard donors (like the S10 steering box)
2. Innovative fixes (like the vacuum actuator mentioned above)
3. Random bits of knowledge (likes currently being posted)
4. Anything else that anyone would think is useful to those of us just aquiring the addiction.
'78 Cherokee
Old School Cool
Old 02-18-2010, 11:33 AM
Billygoat's Avatar
Alwasy tinker with something on your FSJ, they are very needy beasts and if you don't play with them they will MAKE you work on them. Greese 1 fitting a week if you have too, because 1st week you skip - bang t-case explodes.
"Thumper" - 1981 J-20 Extended Cab/sportside, HB, Muscle Grill/round lights, Audiovox Cruise Ctrl, XCR-8000 winch/stk bumper
Extended Cab Build thread {click}
401-4L80E-242 conversion {click}
"Gonzo" - 1983 Cherokee WT 360/727/229 - DYI TBI w/TFI dizzy, HB, 3" SR/SF lift, Muscle Grill/round headlights
Build Thread {click}
Old 02-23-2010, 07:41 AM
KNOWPIE4U's Avatar
KNOWPIE4U KNOWPIE4U is offline
2000 Ford F-250 rear shocks are a perfect fit for SOA grand waggy's at all 4 corners
also for the front brake lines mid 80's 3/4 ton chevy van work great!
When they say reuse the old distributor gear there not kidding it will FAIL .
The alternator upgrade is really as easy as it sounds.
If your looking for a J truck on Craigslist and they say no rust, they are lying! LOL
65 PORSCHE 911
69 VW SQUAREBACK
71 J-4600 *traded*
73 VW THING
89 GRAND WAGONEER
92 YJ
95 FORD LIGHTNING
04 HEMI RAM
Old 02-23-2010, 08:15 AM
janie's Avatar
janie janie is offline
Dexron Impaired
Never, ever, ever overtighten the bolts on your trans pan.
Old 02-23-2010, 08:20 AM
El_Diablo's Avatar
2wd or 4wd?
Old 02-23-2010, 08:56 AM
Gary's Addiction's Avatar
Gary's Addiction Gary's Addiction is offline
Exclamation
OK, I'll bite...
do you mean the ones you hear right before one of your rear wheels bounces down the road beside you and then in front of you?
Been there and done that.
81 Cherokee - long gone
91 Grand Wagoneer - more recently gone
89 Grand Wagoneer - new ride currently sucking money out of my wallet.
91 Grand Wagoneer - Back again!!!
Old 02-23-2010, 10:44 AM
710 Burner's Avatar
Amen brother Flint.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
