Old 01-30-2010, 01:57 PM
ricdiculous's Avatar
ricdiculous ricdiculous is offline
Alternator charging @ 18 Volts
my alternator is charging my battery at just under 18 Volts. In fact, acid bubbles out of the vents on top of the battery.
after driving a while it seems to level out and go back to a normal charge. (reading 0 on the ammeter).
think it'll blow up the battery?
the battery doesn't get hot, nor do the cables?
I'ma rock it around in the snow here in a bit and see if something heinous happens.
i hope not, don't feel like cleaning up an exploded battery.
Old 01-30-2010, 02:01 PM
Unless you want to replace your battery, I'd fix the problem.
Overcharging the battery will kill it in a pretty short time frame.
1994 Caprice wagon
Old 01-30-2010, 02:21 PM
Tornado230's Avatar
Chrysler mini-vans were notorious for overcharging, resulting in exploding battery.
Fix the problem ASAP.
You will probably find that the battery case is bulged.
Don't stand over it (the battery) while the motor is running.
Old 01-30-2010, 02:23 PM
Shut it down. Prolly regulator is kaput.
Old 01-30-2010, 03:25 PM
yeah, i plan on replacing the battery anyway. is the regulator built in to the alternator on grand wags? it's an 84 by the way. it really only over charges after start up but that's too much in my opinion.
thanks.
Old 01-30-2010, 03:32 PM
In 84 it's prolly an internal regulator but not sure.
Old 01-30-2010, 06:29 PM
FSJ Guy FSJ Guy is offline
An 84 should have the internal regulator.
You can get a simple rebuild kit, too, for about $20-$30.
I'd have the alternator checked first. There could be something wrong with your wiring that is causing the alternator to put out too much voltage.
Ethan Brady
www.bigscaryjeep.com
Old 01-30-2010, 10:30 PM
i think it might be a problem with the wire that's a 15 ohm resistor or whatever the heck it is. i'm going to check that out first. i did see the rebuild kits for 15 bux. i have two extra 94 amp alternators so even a rebuild would cost more than just throwing on one of the others. but if it is that wire throwing on another alt won't fix it.
gonna read the service manual about that wire when i sober up enough.
Old 01-30-2010, 10:36 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
A battery that is beginning to short between the plates will cause this as well.
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
Old 01-31-2010, 10:50 AM
andy d andy d is offline
Shade Tree Shaman
dont mess around. If you are fiddling under the hood and a spark touches off the battery , you will get a bath in sulphuric acid. I knew a guy who lost an eye from this.
\'88 gwag,pure stock
Old 01-31-2010, 10:55 AM
cocurtiss's Avatar
cocurtiss cocurtiss is offline
could I possibly pick one of those extra alternators off of you?
1981 J20
soa/sf
36x12.5x16.5 Goodyear Military oz
no rust!
Status: Top end tore apart
Old 01-31-2010, 11:06 AM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
just hook a 6 volt battery up to the 12 volt battery =18 volts yea that should do it thast the ticket
Old 01-31-2010, 02:44 PM
it was a bad alternator.
replaced it, all good.
i have another 94 amp alt i'll sell for 30 bux to whomever was asking about it. pm me and we'll do it up.
Old 02-03-2010, 07:24 AM
so the new alternator did great for about a day and a half, then it started overcharging like crazy too.
turned out i had the field wires reversed.
yeah, i'm a jackass.
