01-17-2010, 01:09 PM
The heated windshield version has more than one charge stud is what I have heard.
Some pics:
I used two washers to take up the space leftover from the bracket.
The belt adjustment is maxed out. I need shorter belts.
Tom (Productive Member of Society)
1989 Grand Wagoneer:
Some stuff stock, some not.
Transmission Troubles
01-17-2010, 01:34 PM
CS144 !? looks like a general purpose Garden variety GM alternator to me
Am i missing some thing
Mike
1953 Studebaker M275.
1962 GMC 4500.
1969 AMC AMX-390 Resto.
1977 Ford F350.
1982 AMC Eagle project SX/290.
1982 AMC/Jeep project J5500.
1988 AMC/Jeep project MJ/343.
1992 GTA Trans AM.
A M C Means jeep to me
01-17-2010, 01:47 PM
It is a general purpose, garden variety GM alternator. It just fits FSJ's without many modifications and puts out 140 amps.
01-17-2010, 01:56 PM
Direct bolt in ? . . . Now that is some thing to get excited about
Mostly gotta Modify some thing to swap a GM alt in
Mike
1962 GMC 4500.
1977 Ford F350.
1992 GTA Trans AM.
01-17-2010, 02:01 PM
The adjustment bracket needs to bent a little and the top/rear bracket gets removed. There is an harness that plugs in between the alternator and the stock wiring. I did not use the adapter. I pulled a plug from the junkyard and spliced it in. The alternator has been on for a week now and have had no issues.
EDIT: I wouldnt call it a direct bolt in... but still easy enough to do.
01-17-2010, 03:12 PM
Murphy's Law Poster Child
I'll have to do this on the J10
01-18-2010, 09:54 AM
Sean-
I'd highly recommend doing the swap.
Anybody try this on a 258?
01-18-2010, 11:56 AM
Just curious, why did you not run the second belt?
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
01-18-2010, 12:39 PM
Originally Posted by shackwrrr
whats the difference between the heated vs. non heated windsheild? Wouldnt the alternator be a higher output with the heated one?
I think the heated windshield runs directly off the 3 phase un-rectified stator winding output, so the alt has three extra output studs. (From memory)
If you guy's want some lower brackets, let me know I can bend up some more.
Another batch of brackets has been built: and are available (e-coated this time  )
Mike D.
01-18-2010, 01:02 PM
Here is a picture of a heated window one, notice the three extra studs on the back.
01-18-2010, 01:28 PM
These pics are from when I was testing everything out. I'll be replacing all of the belts this weekend.
01-18-2010, 02:48 PM
freeincolorado
Hey Freeincolorado,
When I did this swap I tried several different belts. many manufacturers claim different lengths etc. Anyway I settled on belts made by gates. The gates belts actually are slightly longer than some of the other brands out there and they fit perfectly and give you the extra length you need so that you actually have adjustment room and you dont need herculean strength to get the cs-144 on and adjusted. I have the part number for the gates brand belts if you want it. (Need to look under the hood I forgot the number.)
Upgrades
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
01-18-2010, 02:59 PM
I just did this swap yesterday, the factory length belts were almost right on for me.
~1/2" left on the adjustment arm.
I think a longer belt we be no good, in most cases a shorter belt would be ideal.
01-18-2010, 07:35 PM
Does anyone make a new rear bracket? Is it even needed? I'm o.k. with not using one. I think that the two remaining brackets are strong enough.
I'm just curious what others have done.
01-18-2010, 08:18 PM
Is there a quick and dirty version of this swap? I read Joe's article and my head was swimming. Very informative, but I was overwhelmed. I need something like:
"Get this alternator, hook up these wires,do this and that so your truck wont catch fire, test."
01-18-2010, 08:52 PM
You could say I did it quick and dirty.
01-19-2010, 05:47 AM
Originally Posted by will e
When I did the swap on my waggy, I had issues with the adjuster bracket and I needed a longer belt size.
Can you snap a pic of your install and how you lined up the bracket?
When I did mine ('83 Wagoneer Limited), I started with a CS-130, because I didn't feel like fiddling with the brackets. Turned out that my particular vehicle originally had an optional alternator (15-SI?), and the CS-130 wouldn't fit (not enough bracket travel inward). Got a CS-144 ($68 from local alternator shop) and that dropped right in with only the pigtail and a couple of different fasteners. The stock belts were a perfect fit.
S.J.
"Carpe Mañana".
'83 Wagoneer
01-19-2010, 12:12 PM
Mike D.
I'd like a lower bracket mdill
Geronimo!
1978 Widetrack Cherokee Chief
Motorcraft 4bbl 360/TH400/1339 QT, Dana 44's, 31x10.50 A/T's
status: for sale
01-19-2010, 05:54 PM
My uncle has a couple of junk caddies, and I am goin to try to locate one tomorrow. Are there any makings or numbers to identify one? CS144 maybe or ? I dont want to sweet talk him out of the wrong one, since he doent like to get rid of anything.
Jesus is the only way!
01-19-2010, 05:57 PM
I installed one the other day from a '91 Caddy Fleetwood
Years/models are in my thread...
http://www.ifsja.org/forums/vb/showthread.php?t=115527
