Old 01-08-2010, 01:57 PM
El Toro J10's Avatar
El Toro J10 El Toro J10 is offline
Ammeter - To bypass or not to bypass...
I am gearing up to do a couple of upgrades this weekend. 1) I am upgrading to the TFI, 2) I am upgrading to the CS144. As I do these, I really need to know the truth about the following statement concerning the riskiness of the ammeter in the cab.
Originally Posted by joe
Make sure the connections to both ammeter terminals are clean and tight. Ammeters causing fires is an old wives tale. Losse dirty/corroded connections at the ampmeter cause heat in turn causing fires. Not the ampmeter. Keep it clean, keep it tight and live happy. Ammeter connections are part of normal maint that comes with owning, driving a vehicle.
If I clean my connections and resolder will this really reduce my risk of overrheat/fire. Especially since I have had voltage problems in the past I would like to leave the ammeter in operation, at least for the time being.
Thoughts???
1982 Jeep J10 - 360 5.9L V8 - Automatic Transmission, MC2150 Carb, MDS TFI Upgrade, CS144
Decatur, Georgia
"Do or do not. There is no try." Yoda
Old 01-08-2010, 02:24 PM
freeincolorado's Avatar
freeincolorado freeincolorado is offline
I suppose it all depends on how much you like bbq Jeep. If I had an ammeter and was doing a cs144 swap, I would do the bypass and install an aftermarket voltmeter.
Tom
1989 Grand Wagoneer:
One problem a time.
I aim to misbehave.
Old 01-08-2010, 02:29 PM
CHICOWAGGY's Avatar
CHICOWAGGY CHICOWAGGY is offline
I agree, the ammeter is designed for the stock alternator. I would definitly bypass it if I was upgrading my alternator. I have a voltmeter, so I don't have to worry .
1990 Grand Wagoneer
Stock 360/727/229
Restoration in progress.
Old 01-08-2010, 02:38 PM
710 Burner's Avatar
The stock system is not designed to handle more current. Note that your ammeter only reads to +/-60. Should you actually run more current through it, you could create problems.
The answer to your question is that the statement is generally considered correct, but only as it relates to the ammeter. There are other issues with that design that can get you the same result.
Mark B. Jones
Old 01-08-2010, 02:53 PM
janie's Avatar
janie janie is offline
Dexron Impaired
Do the bypass. You'll thank yourself and your rig will too.
Old 01-08-2010, 03:04 PM
Hankrod's Avatar
Hankrod Hankrod is offline
Banned
I say bypass. As a matter of fact, I would not even send the power into the dash at all. The Alt. wires are #10 awg. and they can get hot with 140 amps. Hankrod
Old 01-08-2010, 03:13 PM
yes,with the 144 you need to at least run a cable from the alternator output to the battery/solenoid,the guage can't run the potential of 140 amps through it.
Old 01-08-2010, 06:55 PM
91G-Dub's Avatar
91G-Dub 91G-Dub is offline
Soing the bypass in my J10 only took a minute or 2. I put in an aftermarket voltmeter and haven't looked back.
91G-Dub = Bill Houston
1979/1980 J-10 Junkyard Dog 258 4 speed D44 front AMC 20 rear 3.31 Lincoln Locker Status Running
1991 Grand Wagoneer Gray Ghost (bone stock) STATUS Gone but not forgotten
"The tree of liberty must be refreshed from time to time, with the blood of patriots and tyrants.
It is its natural manure."
Thomas Jefferson
Old 01-08-2010, 07:48 PM
littlebuck23's Avatar
littlebuck23 littlebuck23 is offline
Joe is correct. Clean connections to the amp meter is the important thing. StartIng currnt does not go thru the amp meter. In Order to get all 140 amps from your alternator you would have to ask for them in some way. Bad wirng is one way, powering an aerosmith concert would be another. Chaffig wiring against ground is the real reason rigs catch fire. Replacing/nspecting the wiring is a good idea. If you really wanted to protect your rig from fire you would fuse the output from the alternator. The shunt in the amp guage s good for whatever number is n the front of the guage. Just keep it clean to avoid heat.
If you see a huge negative draw on the guage you know ya got a problem. Think of whatever number of amps is getting taken out of the battery your making that lightbulb worth of heat somewhere.
That's my educated opinion on the matter. Doing nothing is cirtianly not the solution but simply elliminAting the guage is a false sense of security.
Thoughts???
Terry
1970 Kaiser Wagoneer -SOLD (currently getting built by new owner)
Build thread-http://www.ifsja.org/forums/vb/showthread.php?t=103447
1979 Cherokee Chief WT 360. SOLD
1977 Cherokee Chief WT Sport 401. SOLD
1975 International Scout II (My DD)
Old 01-09-2010, 08:06 AM
Thanks for all of the information and opinions. I will definitely bypass until I have the time to upgrade wiring or put an aftermarket voltmeter in the cab. I came across this how-to for an under the hood bypass. It looks simple enough.
http://www.ifsja.org/forums/vb/showt...ighlight=CS130
The temp dropped to 35 degrees today nixing my plans for the upgrades. That might not be cold to you "real men" up north but this Florida boy can't grip a ratchet when its like this.
Decatur, Georgia
