Old 01-06-2010, 03:05 PM
rockin wagoneer's Avatar
rockin wagoneer rockin wagoneer is offline
lift kit
hey all i just got a 4 inch lift for my waggy does a 4 inch lift really give u the full 4 inches or no..... and wat size tires can i put under it/
love it,live it,be it JEEP!!!!
79 cherokee- dd on 36s
78 wagoneer-rebuilding
Old 01-06-2010, 03:24 PM
addicted's Avatar
addicted addicted is offline
You should get the advertised 4" and then some depending on how bady your current springs are sagging.
Old 01-06-2010, 05:10 PM
mattmopar440's Avatar
31" to 32" tire on a Narrow track wagoneer
91' Grand Wagoneer
401/727/229, HEI, Edel 2131 Intake,8600, Holley Truck Avenger, Dual Exhaust, Flowmaster 70. Edelbrock shorty headers.4" BJS 31 BFG Mud-Terrains
Currently:Down for Body Work
80's J10 258/T-5/208
90' Jeep GrandWagoneer
SOLD
Inferior Chevy
Old 01-06-2010, 05:53 PM
djongeward's Avatar
djongeward djongeward is offline
Is that 31's on a grand wag. I think any more you'll have to cut a bit. I like the look of the 4" best with 31 BFG's
89 Grandwagoneer, built 360, COMP cam set, port matched Edelbrock SP2P, 475 cfm Holley ORA, Thorleys, MSD6a, extra cooling and oiling.
76 Cherokee S Chief - rebuilt stock, Holley, Performer, MSD Dizzy.
89 GW parts waggy
Old 01-06-2010, 06:52 PM
ok cause im doing a 4 inch lift and a spring over on the front and moving the spints to under the frame in the back so just with the 4 inch i only can put 32s?
Old 01-06-2010, 07:01 PM
ThisGuyUKnow's Avatar
Im able to get away with 33's on my waggy with a 4'' spring lift they do hit the leafs upfront in tight turns.. I hear that can be corrected with bump stops but my long term plan is to go to Cherk W/T axles so I am just dealing with it for the time being.
77' Cherk Chief (Chief Many Moons)-Jasper 360,Motorcraft 4bb, TH400, QT(w/Low), 32" BFGs, 3.54 gears
Old 01-06-2010, 07:07 PM
ok cause i have a j 10 with a 4 inch lift and fit 35s easly so i didnt know im working on my 78 waggy so anything u think i might need to know just put on here thanks
Old 01-06-2010, 08:13 PM
will e's Avatar
will e will e is offline
Always Broke
you are doing 4" springs and a spring over on the front? That will net you about 10".
81 Wagoneer - 'WILL E' Retired
82 Cherokee WT - SOA/SF/cross over/high steer/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/awesome Rstep custom bumpers and roll bar/Tad steering brace
Old 01-06-2010, 08:20 PM
well i hope i do i`m looking to fit about 36s or so atleast i hope so but in the back im going to make a bracket to drop the springs below the frame to get another 3 or 4 from the back aswell. any ideas on that?
Old 01-06-2010, 09:04 PM
vintagetrks's Avatar
Anything bigger than 32's and you'll probably want to change you gearing. What gears are you currently running? My waggy has 3:08's I believe and I'm running 31's on a 3.5'' Rancho lift and down low she's kin of a dog but does well on the highway.
New Full Size Jeep Nut
90 Grand Wagoneer "Big Mama"
Old 01-06-2010, 09:20 PM
idk yet and i haven`t gotten into the axles much yet im more worried about getting my 327 running frist.
Old 01-06-2010, 09:35 PM
You might wanna check out some of the old engine threads. I have seen a couple regarding 327's.
Old 01-06-2010, 09:37 PM
i started one on the 327 to find some stuff out i have a runnign 360 that came with it but i want the 327 cause its just badass and u dont ver see them anymore.
Old 01-06-2010, 09:40 PM
I think Gambler68 had a thread on the 327 he's building IIRC. I have been told they are very good engines but nothing like the chevy 327's I'm used to.
Old 01-06-2010, 09:41 PM
c i know alot about the chevy 327 but they only made the 327 amc for 4 years so i want it cause its so rare
Old 01-06-2010, 10:37 PM
will e's Avatar
Always Broke
ok, so the plan is put the 4" spings on now, get it some tires and do the other mods later? If not, then forget the 31's and go with 35's if they will fit. You might need to trim a little.
Old 01-07-2010, 02:25 PM
no im doing all the mods at one go so i dont have to take the lift kit off and put it back on so im just doing it at one go.
Old 01-07-2010, 02:38 PM
skeletor's Avatar
skeletor skeletor is offline
the gen1 amc rambler v8 engines 250-287-327 where used from 1956-1967. the rambler 327 is amc's big block.
i dont know why you want to have 11" of lift especially on stock n/t axles. go soa only and cut till you can fit the tires you want.
-bryan
1984 j10
http://www.youtube.com/watch?v=NgpZ9c8prug
GO BILLS!
Old 01-07-2010, 02:55 PM
i have a 327 vigilant and im prob changing my gears out to 4:10s
Old 01-07-2010, 04:45 PM
billyj7175's Avatar
The J-trucks and Cherokees are wide-track and the rear wheelwells are larger than the wagoneers, therefore they can clear a much larger tire.
83 J-10 Jeep "Oscar"
727 & 229 are rebuilt, but the 360 is in an incalculable number of pieces, sporadically disseminated all over the garage...
4" Rusty's with 33X12.50 Pro Comp MT's
