Well I haven't actually done anything to the jeep yet, but I hope to get it in the garage today or tomorrow. I have decided to put my 78 ford one ton axles under it, with plans of running 35" tires. I flopped back and forth with using the stock axles or these, but figured I would have to regear the stockers to use them. So if I'm going to put all that work into it I might as well do it once. I had built a set of links for another project that is going in a different direction now, and I will be using them in cunjunction with the fabtech coilovers.
Hillbilly Deluxe
Just a side note, I find that whenever I start a project I completely immerse myself in it. That is I can't stop thinking about it. I have been looking around here, and have found some really cool jeeps. Seeing what my jeep could look like is inspiring, and really helps to motivate me.
Originally posted by Voodoochiled445Sounds awesome, your right you wont want to go with the stock axles if you plan to run 35s. I have 31s with a 3.07 gearing and its acceptable.
I'm running 31's on stock axles and 2.72 gears. If the engine was not beefed up, it would be a dog.Jeff
'43 cj2a
'51 Willys p/u
'51 Willys Parkway Conversion
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
My one tons have 4.10's, which should be perfect for the 35's. I have been collecting parts for a while now so I should have most everything I need.
Some parts I already have:
-Fabtech dirt logic coilovers
-stainless steel braided brake hoses
-suspension links (chromoly w/ballistic joints)
-Rugged trail rear shocks
-Warn m12000 winch (craigslist find $300)
-Front winch bumper (started building, needs finishing)
-Pioneer cd player ($15 junkyard find)
I'm still going to need some tires, I have a set of hummer 37's, but they are just a little too big.
I got the fron axle out, only to find a bad spot in the frame behind the drivers side shock mount. It kinda sucks, but i was going to reinforce the frame here anyway for the coilover mounting.Attached Files
Originally posted by BillygoatYou just had to go and take the name of my next project that I don't know when I am ever going to start, nor do I own the starter truck for....so I guess by first come first server - you win .
Sounds like heavy duty beast1999 Chevy Express 3500 cargo van
1997 Mercury Mountaineer
AIM: derektjeep
[email protected]
224 805 0773 text message is the king!!!
Find me on facebook under Derek Troy
Thanks, I'm pretty excited to get it together. For now I just want to get the suspension/axles in it so I can drive it. Then I am going to tackle one small project at a time to keep it under control. I find that if I bite off too much at a time i get overwhelmed and don't want to work on the project.
