Old 12-30-2009, 02:03 PM
wranglertexan wranglertexan is offline
Fast Ammeter Bypass
Hallo, for my 1980 Chief I would like to do the fast ammeter bypass described at the end of this page:
http://www.drbob.tqhosting.com/tech/ammeter.htm
It says to relocate the ring-terminal from one of the studs to the other stud.
But which one do I move?
1) do I move the yellow wire to the black one?
2) do I move the black wire to the yellow one?
Thanks a lot
Federico
Old 12-30-2009, 02:30 PM
CHICOWAGGY's Avatar
CHICOWAGGY CHICOWAGGY is offline
I don't think it matters, either way you're bypassing the ammeter.
1990 Grand Wagoneer
Stock 360/727/229
Restoration in progress.
Old 12-30-2009, 03:14 PM
FSJ Guy FSJ Guy is offline
Move either one, but you're only bypassing the ammeter. All that current from your alternator is still going through the 20 year old wiring.
Ethan Brady
www.bigscaryjeep.com
Old 12-30-2009, 03:32 PM
ok, so what is the best solution instead of ammeter bypass?
Old 12-30-2009, 05:52 PM
Make sure the connections to both ammeter terminals are clean and tight. Ammeters causing fires is an old wives tale. Losse dirty/corroded connections at the ampmeter cause heat in turn causing fires. Not the ampmeter. Keep it clean, keep it tight and live happy. Ammeter connections are part of normal maint that comes with owning, driving a vehicle.
Old 12-30-2009, 06:47 PM
will e's Avatar
will e will e is offline
Always Broke
you could put in a shunt. The amp meter would only show half of the actual amps.
Old 12-30-2009, 06:56 PM
Pavementsux91XJ Pavementsux91XJ is offline
Whatever you do, don't just cut the wires and run one from the alternator to battery cable, you will have no power to the cab. Ask me how I know. Oops!
Note to self: Don't drink so much beer while working on Jeep.
Trail Rig: 1991 XJ on 3/4 tons and 38's
Tow Rig: 2002 Dodge 2500 CTD 4x4
And the only one anybody here cares about:
Huntin Rig/ Mild Trail Rig: 1973(must be late because it has all 74 parts) Jeep J10, 360/t18/d20. 3" lift on 33's. Runnin Great! Awaiting body work and flatbed!
Old 12-30-2009, 07:19 PM
Blue & Gray's Avatar
Blue & Gray Blue & Gray is offline
Cut both and splice them back into each other with a connector and wrap with electrical tape, sure beats trying to run that little nut down while all the blood is running to your head, or loosing the nut or whatever. You'll spend more time messing with those little nuts in an awkward position when the effect is the same and you remove all the 30 year old hard ware from use. A voltmeter wires in anywhere and keeps you notified of any charging oddities.
1976 J10 258/T15/D20 , Dana44's w/4.09's 31x10.50 Super Swampers BP's. HEI an otherwise stock. Runs Great. SOA/SF and 2brl soon
1976 Cherokee NT 232/SM465/NP205, Dana44's, w/3.54. 35x12.50 Mud Chain Saws, SOA/SF, HEI. MSD, 2 brl, Wag seats etc. Hard Spanked but in work now.
Old 12-30-2009, 08:19 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
go to www.oljeep.com and click on alternator theory by Joe Guilbeau. Or, search here for big splice by user Joe Guilbeau. Talks about how to take full alternator power through a wire to the battery, then take power through ANL Fuses and route a 12v source to the Big Splice (where all the power wires meet under the dash) and connect there. Then, remove the ammeter circuit altogether, and add in a volt-meter (which you connect anywhere along the 12v source).
BJ's Off-Road
ryan@bjsoffroad.com
