09-26-2011, 02:13 PM
1980 J10 Front Clip Flip with Speedliner Exterior
10-17-2011, 08:27 PM
LC9 5.3L Conversion
78' J-9, 96 XJ
10-26-2011, 08:51 AM
91 Wagon aka Woodrow
10-26-2011, 10:15 AM
1979 Cherokee build and 5.3/4L60E/NP 241c swap
10-26-2011, 10:17 AM
 Click in the sig!
1990 GW:
360/727/229/D44F&R
Performer Intake/Holley TA 670/Hedmans/3" Exhaust.
SOA/SF New Springs. 4.10's, Locked Rear. Swingout Rear Bumper, Front Winch Bumper w/ 12k Winch. OBA, Cobra CB, and a bunch of other stuff that doesn't work quite right.
My Build Thread
11-02-2011, 02:38 PM
Link in sig
73 j-4000 crew cab project (in progress)
11-02-2011, 03:05 PM
1978 WT Cherokee 2door, 360, T18a, Dana 20. Currently under construction.
12-03-2011, 11:53 AM
64 J300 over F250 Drive Train/Chassis
FSJ Newb
01-15-2012, 01:57 AM
build thread links
1979 Cherokee
1983 Cherokee
02-06-2012, 09:01 PM
79 chief build
77 Chief,360,th400,BW w/ part time kit and low range,cold AC!
79 Chief, 360,T18,D20
79 Chief, th400, low range ( needs a 360)
89YJ,tons,4 link,360 V8,fuel injected,700R4,4:1,42's
70 Commando, 225 V6, 3spd, D20
84 XJ 2.5, T4/231, exo cage
03-31-2012, 05:26 PM
.. what happened to the "madness" thread? The link in the sig no longer works :\
04-25-2012, 09:21 PM
Fab/Tech Moderator
His feelings got hurt and he deleted it.
79 J-10 - The Money Badger!
304 /T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
04-26-2012, 04:25 PM
Murphy's Law Poster Child
M416 Expedition trailer that I need to get off my butt and finish
http://www.ifsja.org/forums/vb/showt...highlight=m416
04-28-2012, 11:02 PM
05-18-2012, 02:58 PM
Here's the link to my '82 J20 build starting from the day I got it, to now.
http://route66rambler.com/forum/inde...e=view&id=1745
1982 J-20
1965 AMC Rambler American 220
1979 AMC Concord DL
1973 Jeep DJ-5
1979 AMC Spirit/AMX
1962 AMC Rambler Classic 400
1975 AMC Matador Wagon
09-01-2012, 11:04 AM
Getting started
Here are pics of my 83 I dragged out to get started on. As you can see the floor is in pretty bad shape. Plan to cut out most of the rusted thru pieces and sheet over with aluminum. Don't have welder to weld in steel so will use what I have laying around. Will pop rivet plate on top and cover with peel and seal to keep out moisture. You will notice I have a pop up I am using as a cover to work under, Don't have a building but that never stopped my before. At least its dry most of the time. Will up date as work progresses.
09-01-2012, 11:06 AM
continued
more pics
10-26-2012, 02:42 PM
J10 Front-Clip Tilt
11-29-2012, 09:53 AM
1970 Jeep Gladiator 1 Ton 6BT 12V Cummins Build
http://www.ifsja.org/forums/vb/showthread.php?t=151930
24 June 2011
Then down to this
Back to this
As of 29 Nov 2012
Originally Posted by Resbum
