Old 12-03-2009, 01:23 PM
Metal Twister's Avatar
Metal Twister Metal Twister is offline
Post your Build Thread Link Here...
Maybe this is a way to get it done and still be within the frame work of the IFSJA, and what the Mod's can work with? If not Feel free to remove this.
Thinking a listing of links of your build threads posted here would at least make it easier to find. Lets put the model, year, and what the build thread is on. ie. Full build, Body lifts/Mods, etc. And one poser pic.
Post um up here until things change. Lets also keep the Thread as clean as possible and just post your links... No comments posts please, otherwise it just turns back into the same problem... Finding the Links.
74 FSJ Body Swap to a K5 Jimmy Frame W/Pics (The Desert Rhino)
http://www.ifsja.org/forums/vb/showthread.php?t=125622
1974 Cherokee, Mostly body mods to this point.
http://www.socalultimate4x4.com/inde...pic,1414.0.htm
Front bumper build with winch...
http://www.ifsja.org/forums/vb/showthread.php?t=109731
Tj Fender Flairs on the cheap...
http://www.ifsja.org/forums/vb/showthread.php?t=97465&highlight=fender+flairs+on+ the+cheap
Trimming the rear quarters...
http://www.ifsja.org/forums/vb/showthread.php?t=112805&highlight=fender+flairs+on +the+cheap
Build Your Own Muffler w/pics
http://www.ifsja.org/forums/vb/showt...=1#post1078691
Floor Rust Repair Job... California Rig?
http://www.ifsja.org/forums/vb/showthread.php?t=126428
Second Battery Tray added...
http://www.ifsja.org/forums/vb/showthread.php?t=126659
Exhaust Exits through the Body...
http://www.ifsja.org/forums/vb/showt...21#post1161921
The Rivet Thread... Dare to be different
http://www.ifsja.org/forums/vb/showthread.php?t=135144
Cut in a new Fuel Filler Door and Spout
http://www.ifsja.org/forums/vb/showthread.php?t=159562
Old 12-03-2009, 01:46 PM
Our build or maintenance stuff is on a web site Krista and I pay for.
That way, we do not rely on this free forum for it.
Phoebe: http://jubileejeeps.org/ourfsjs/phoebe/index3.htm
Luna: http://jubileejeeps.org/ourfsjs/luna/index2.htm
Artemis: http://jubileejeeps.org/ourfsjs/artemis/index2.htm
Wally: http://jubileejeeps.org/ourfsjs/wally/index2.htm
All of our Heeps are here:
Old 12-03-2009, 02:02 PM
krek's Avatar
krek krek is offline
Perpetually Perplexed
My builds are linked in my signature.
Old 12-03-2009, 02:05 PM
Ok, I'll sticky this for a bit and let's see if we can pull together some useful builds/links.
Let's hope it works better than the salvage yard thread that's been dead for almost a moth.
I mean month
BTW:
It's not about what the Mod's/Admin's want.
It's about what's best for the board, what can be accomplished with limited resources and wether or not it can be a real asset (meaning not just text with dead pic's down the road).
Old 12-03-2009, 03:16 PM
Gambler68's Avatar
Rabble Rouser
http://www.ifsja.org/forums/vb/showthread.php?t=97476
That's my only real ongoing build thread of any current interest..68 J3000, rebuilt and modified 327, cab and bed swap, currently undergoing 3/4 ton conversion.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 12-03-2009, 03:27 PM
Dr Teeth Dr Teeth is offline
The build is linked in my sig.
This isn't a bad idea to keep them together, but should a mod maybe delete all comments that aren't actually listing a build so it doesn't get 400 pages long with only 20 builds?
Todd
Old 12-03-2009, 05:53 PM
ne715 ne715 is offline
Daughter's Jeep Build
http://www.ifsja.org/forums/vb/showthread.php?t=72983
Pam
Old 12-03-2009, 06:13 PM
Todd
Yes we will deal with that.
That is the biggest problem with the whole BB thing.
A build thread should not be a question and answer session.
It's your build, right or wrong.
I don't mean you are wrong, but much misinformation exists, this is part of the problem with having them here. We can't get away from that, but the IFSJA forum/team can not assume any responsiblity for what you post.
Old 12-03-2009, 07:12 PM
dajeeps's Avatar
dajeeps dajeeps is offline
dajeeps crew cab build
still in progress about 75 percent done
http://www.ifsja.org/forums/vb/showt...hlight=dajeeps
82 wagoneer dd
73 j4000 crewcab project
77 cherokee s wide track (parts rig)
Old 12-03-2009, 07:31 PM
msh227's Avatar
msh227 msh227 is offline
Thanks for giving this a shot
Hopefully this sticky works if not thanks for giving it a shot.
Here is my build so far (see signature for build details)
http://www.ifsja.org/forums/vb/showthread.php?t=108566
Matt
1978 J10 5.3L/700r4/QT swap in progresss....
37x14.50R15 TOYO Open Country MT
4.56 Gears
6" Bjsoffroad Lift
3" Body Lift
Mile Marker Part-time 4wd Kit
1978 J10 Build Thread:
Old 12-03-2009, 07:52 PM
duncanstives's Avatar
duncanstives duncanstives is offline
My 88 Waggy.
Specs for greater searchability:
14 bolt rear
44 high pinion/heavy duty front
4.10 gears
Aussie locker in the front
Inboarded rear springs with shackle flip
Spring over conversion in the front
Poly bushings
Hydroboost
Extended brake lines
Heavy duty front lift shackles
360/727/np229
Link: http://www.ifsja.org/forums/vb/showthread.php?t=112491
88 Waggy
Resting in peace... Um... In piece... Er... IN PIECES
Current Status: Under construction. Phase 2.
86 Pathfinder Conversions "K-Van"
Current Status: Broke
Volkswagen rail buggy
Current status: Broke
95 Jeep ZJ V8
Current status: DDing
Old 12-03-2009, 08:09 PM
cu4whln's Avatar
cu4whln cu4whln is offline
Smile Hi Everybody
Check out my build .. linked in my sig.
1979 Chero: "Madness"
2001 XJ : Driver
TJ Rubicon
2010 JK - Islander "Wifes new ride"
"Madness" build here:
Old 12-03-2009, 10:01 PM
shackwrrr's Avatar
heres mine just started it.
http://www.ifsja.org/forums/vb/showthread.php?p=1023436
Jeepless
In to Turbo crap now
Old 12-04-2009, 10:03 AM
funhog funhog is offline
I'll post up. Maybe if enough people do this (and follow directions) there can be a folder for them.
http://www.ifsja.org/forums/vb/showt...t=sitting+blue
Don Martin
79 cherokee chief
2" Body Lift
33"X12.5"
79 Wagoneer limited
Restored
78,79, 82, 87 all rolled up into one.
Old 12-04-2009, 06:16 PM
Ok, We'll start with the star of my sickness
1975 J-20 Tow Truck
http://www.ifsja.org/forums/vb/showthread.php?t=106663
1977 J-10, currently my DD, soon to get restored
http://www.ifsja.org/forums/vb/showthread.php?t=72250
1975 J-20, I'm building a work truck to retire the J-10
http://www.ifsja.org/forums/vb/showthread.php?t=110126
1988 Grand Wagoneer, Wifes DD
http://www.ifsja.org/forums/vb/showthread.php?t=99769
Old 12-04-2009, 08:19 PM
Millerluck's Avatar
'89 "Mutt" engine
http://www.ifsja.org/forums/vb/showt...odywork+update
Body work and paint threads for '88.
Sorry can't find 401 build thread.
Larry
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
Old 12-05-2009, 06:42 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Jeep dually (Buick 455/NV4500/NP205) build thread:
http://www.ifsja.org/forums/vb/showthread.php?t=83955
Jeep/AMC V8 Dual Power Steering Pump Thread:
http://www.txfsja.org/forum/viewtopic.php?f=5&t=166
Hydroboost brakes for your Jeep:
http://www.ifsja.org/forums/vb/showthread.php?t=106056
New developements in hydroboost mounting assemblies and fitting HB to a Kaiser rig:
http://www.ifsja.org/forums/vb/showthread.php?t=99397
Wiring an engine test stand:
http://www.ifsja.org/forums/vb/showthread.php?t=110763
Old 01-05-2010, 03:09 PM
j20brett's Avatar
j20brett j20brett is offline
sure
http://www.ifsja.org/forums/vb/showthread.php?t=103954
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-d44hd front aussie/d60 rear welded - CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy, hp60, 14-bolt, NWF Black Box/NP205, 5.13's, SOA, 42's
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 01-06-2010, 04:45 PM
sappy76's Avatar
sappy76 sappy76 is offline
In my signature
Old 01-06-2010, 06:21 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
The Blair Jeep Project III
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
