Old 11-28-2009, 08:58 PM
jeepjseries's Avatar
jeepjseries jeepjseries is offline
tail light question at the end of my rope!!
So I couldnt find my old thread to bring it back but I have a 1979 cherokee and the tail light worked except the parking light so i went to auto zone got a tail light pig tail because i suspected that was the culprit so long story short i replaced the old pig tail now nothing if i turn the turning signal on i get voltage but bulb dosent light up but the side marker does and the park light and brake light all work for the side marker light but not the tail light is it supose to do this and does anybody got an idea of how to fix this? really stumped at this point?
Old 11-28-2009, 10:20 PM
Mark Wilde's Avatar
Mark Wilde Mark Wilde is offline
I'm confused. While that's nothing new, could you re-post with some punctuation and sentence breaks? I just can't understand your original problem or what you're dealing with now.
A lot of times if someone can't understand a post they'll just pass it by. You might get more help if you describe it a little better.
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
Old 11-28-2009, 10:49 PM
Sorry about that, electrical issues really get under my skin. Ok so I fixed the park lights. Now the issue is everything works, but the bulb isn't very bright. when the park lights are on and I use the turning signal it dims alot. So I tried using a ground wire from the frame to the tail light socket and the park light is too bright it overcomes the turning signal. Also this might help the left side front and back are in sync but its not on the right side. Any ides?
Old 11-28-2009, 11:23 PM
Mark Wilde's Avatar
Do you have a trailer wiring module? If so, maybe something funky's with it.
I think I'd be looking for chafed/broken wires in the harness. See how much resistance there is from the ground contact in the socket to the frame, and try to find out why it's so high.
I don't have anything else off the top of my head.
Old 11-28-2009, 11:43 PM
no trailer module.
Old 11-29-2009, 09:24 AM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Sounds to me like you got the two hot leads on the right rear crosswired. Switch connections and see what happens.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
http://s726.photobucket.com/albums/ww267/lkmarsh/
Old 11-29-2009, 09:33 AM
There is a connector for the rear light harness just under where the loom exits the fire wall. Pull it apart and clean it well and reassemble with fresh dielectric compound and see if that helps with dimness....
