While I was in Las Cruces 2 weeks ago, I had electrical nightmares that killed the ignition on the trail. The orange "key on" power wire coming off the oil pressure switch for the electric choke was melted all the way to the firewall. This fried a coil and at least 2 ignition modules. It appears the melted wire had shorted to the yellow wire that goes to the coil and the light blue wire that goes between the dizzy and ignition module. The yellow coil wire uses a stretch of resistor wire for it's power feed (older models used a ballast resistor) that drops the voltage down for the coil. So the coil got full battery power during the melt down causing the coil failure and the light blue wire between the dizzy and ignition module causing module failure. So, the problem was twofold and was a PITA to trouble shoot on the trail without a wiring diagram.
During the trail fix, we got the offensive orange wire removed up to the firewall since none of the accessories it powered are being used any more and pulled the melted wires apart. The oil pressure switch the orange wire was attached to is shorted causing the whole problem. I was able to drive home 540 miles after that mess.
Today I confirmed this orange wire is indeed melted all the way to the ignition switch and the wire bundle under the dash is compromised. The ignition switch is burnt inside as well. I am darn glad I did not have a dash or engine fire from the short. Looks like I will have to drop the steering column to get to the wiring for closer inspection and repair.
what a deal...
what a deal...
