Old 10-23-2009, 08:17 PM
Metal Twister's Avatar
Metal Twister Metal Twister is offline
LS1 to Turbo 400...
I just did some Horse trading for a couple of LS1's. Curious who here has made the LS1 conversion and what the down falls were if any. Any advise? Do's or Dont's?
Old 10-24-2009, 09:18 AM
stangfather's Avatar
stangfather stangfather is offline
yank convertors makes a kit less than 200 bucks, is it a jeep bell 400 or a chevy bell 400?
It's 11:59 on Radio Free America; this is Uncle Sam, with music, and the truth until dawn. Right now I've got a few words for some of our brothers and sisters in the occupied zone:
current ride: 86 Wagoneer/06 Grand cherokee SRT8
former ride :77Wag-401/QT/44's-73k miles!
Old 10-24-2009, 10:47 AM
thomastenn thomastenn is offline
i would actually sell the ls1s to some drag racers and buy a truck 6.0 it would be alot more offroad suited with the cast iron block vs the all aluminum ls1. and i would go with a aod 3 speed autos are old tech. you can do a 4l80e and its basically a 400 with a od
1990 gw build in progressroject budget buster
got bjs offroad on my speed dial
Old 10-24-2009, 11:05 AM
El_Diablo's Avatar
El_Diablo El_Diablo is offline
700r4 is a lot easier than a 4l80e..... basically the same trans minus the electronic controls
Old 10-24-2009, 11:46 AM
YellowJeep's Avatar
YellowJeep YellowJeep is offline
700R4 is a 4l60e without the electronics. The 4l80e is much heavier duty than either the 700R4 or the 4l60e.
700r4, TH350, TH400, 2004r, glide, and basically anything that will bolt to a regular small block chevy can be used behind the LS motors. You will need to use a chevy bellhousing of course. 1 bolt will not be used and a small crank adaptor will be needed as well ($50).
You sure you have LS1s and not 5.3s or some other LS truck motor? LS1s are usually pretty pricey and harder to come by. LS1 would be aluminum block, and aluminum heads out of a passenger car....vette, firebird, camaro, GTO, Cadillac CTSv etc.
Chad-
88 Wrangler - TBI350 SM465 Ford 8.8
79 Cherokee Golden Eagle - AKA "The Screamin Eagle" - 5.3 Runs and Drives. TH400 and Q-Trac!
2006 Chrysler 300c - Cause sometimes you a need 350+hp daily driver.
1991 Corvette - Just another toy!
Carbs suck!
Old 10-24-2009, 12:41 PM
So what does the crank adapter do? Space out the flex plate for the starter or something?
Nope, they are LS1's... the 5.3 has a different intake and the pan is a lot deeper along with other subtle differences . Ive put allot of the ls1's in sand cars as well as the 5.3. All aluminum Ls1's with the Corvette plastics.
I already have a fresh TH350 and transfer case out of a K5 Blazer. Im thinking that running that for now and down the road I can throw a 700r if desired. I have a fab shop so changing a tranny mounts and drive shaft lengths is no problem.
Old 10-24-2009, 02:06 PM
YellowJeep's Avatar
Correct, the spacer is for the flexplate spacing. Do a google search for LS1 spacer and you can find them cheaper now.
Chad-
Carbs suck!
Old 10-24-2009, 02:11 PM
Sweet, Thanks for the tip!
Old 10-24-2009, 08:31 PM
El_Diablo's Avatar
You are correct, sorry i wasn't thinking and just blindly posting. I actually meant to post that its the same as a 60.
GM's are what i do but i was a bit tired (had jsut woken up).
Old 10-26-2009, 07:41 AM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
The spacer is available from GM, roughly $25. You will also need longer bolts, again from GM. Use a flexplate from a 6.0/4L80E combo. The spacer goes between the flexplate and crank. Your TH400 torque converter will then bolt up.
Pete
Isuzu 6BD1, NV4500, NP241
Old 10-26-2009, 02:44 PM
Desert Rat Desert Rat is offline
You can't beat an LS1 for smoooooth power.
The one in my Camaro is a treat to drive.
www.nissan4wheelers.com - we're the guys using up all the spare driver drop waggy axles!
Old 10-26-2009, 04:38 PM
Im told that one of these engines is out of a 99 and the other out of a 2000 Camaro. I have the serial numbers off the engines but Im not having any luck identifying them. I am curious if they are indeed those years. Doesn't the numbers mean anything like the old small blocks?
Im also thinking I want this to be as torque eeeee as possible, Any idea what stall speed I should shoot for?
Old 10-26-2009, 09:00 PM
El_Diablo's Avatar
on the front of the intake on 98-00 ls1's you will have an EGR pipe coming out of the top, if it does not have this it will have the "ls6" intake manifold which is better for power, these ran from 2000 until 02 in f-bodies
2000's have egr and cast manifolds.... later engines dont have the egr but have cast manifolds, prior to that they're basically like shorty headers
if it has perimeter valve cover bolts, its a 98, if not you can rule that year out... if it has perimeter bolts but no egr its a vette motor, 97/98
Old 10-26-2009, 09:28 PM
Thanks much! ... Its kind of like not finding what it is as much as what its not? When I get my hands on them I will post up some pics... I believe one is missing a intake manifold? why I dont know? Maybe I can make one good one out of the two or something? LOL I traded them for a days labor. So Im not out much if theres a problem.
Old 10-26-2009, 09:45 PM
El_Diablo's Avatar
be sure to post up the head casting and block casting numbers and i'll try my best
Old 10-26-2009, 10:02 PM
Thanks Man... I sure appreciate it. Give me a carbureted small block and im golden. Totally lost with this ecu stuff... But change is opportunity! Right?
Old 10-27-2009, 04:05 PM
Looking at one in the car doesn't help much. Yes, there really is an LS1 buried in there. This one is a 2000 Z28 (mine)
Old 11-01-2009, 12:11 PM
Well I went over to his place and snapped some shots... I guess one is missing a intake manifold. Neither have any of the accessories or exhaust manifolds. This might be imposible by pics? This is what I have though. Any help would be appreciated. Its not a done deal so maybe its not worth a days labor?
Old 11-01-2009, 12:15 PM
Thanks for trying here guys... Its appreciated.
Old 11-01-2009, 09:13 PM
El_Diablo's Avatar
casting numbers on the heads? numbers on the injectors?
gotta love the rags in the exhaust and nothing over the intake....
