10-02-2009, 04:07 PM
Axle Identification
How do I know what set of gears are in the axles on my J-2000? I know that it is a Dana 44 and it was made in 1970.
Thanks and Gig 'Em
Lincoln Tucker
Fightin' Texas Aggie Class of 2015
2nd Wing, Squadron 21
Gig 'Em Frogs
Logs0012@windstream.net
1970 J-2000, 4bt, NV4500, NP208 - Moving but not stopping
Coffee, Whiskey and Women... Always straight
10-02-2009, 04:23 PM
From easiest to hardest -
1) look at tag on axle, read ratio and/or tooth count
2) rotate driveshaft and count number of revs to roate both rear wheels 1 turn (only approximate - you have to know what the likely ratios are)
3) remove cover and read tooth count stamped into ring gear. ie "41 10" is 41/10 = 4.10s.
10-02-2009, 04:25 PM
where is the tag?
Thanks and Gig 'Em
Lincoln Tucker
Gig 'Em Frogs
10-02-2009, 04:26 PM
Under one of the cover bolts.
10-02-2009, 04:30 PM
what cover bolts?
Thanks and Gig 'Em
Lincoln Tucker
Gig 'Em Frogs
10-02-2009, 04:32 PM
what cover bolts?
The axle has a cover over the gears that's held on with bolts. When you remove the cover, the gears are exposed. If you look at the axle, it should be obvious.
10-02-2009, 04:40 PM
Thanks!
Thanks and Gig 'Em
Lincoln Tucker
Gig 'Em Frogs
10-02-2009, 05:33 PM
Don't count on that tag still being there though after 39 years
Dean
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
'06 XL1200C HD Sportster
10-15-2009, 11:06 AM
Trying to find what gears are in my 72 J2000 , can i find this out the same way
10-15-2009, 11:09 AM
Yes
