Old 09-17-2009, 08:01 PM
vintagetrks's Avatar
Ammeter Bypass
Alright I need some answers about this ammeter bypass thing please. Why and how do I bypass the ammeter in my 76 waggy. The ammeter in my rig works good and I actually prefer it over a volt meter because I can tell how much my alt is actually working. But I keep hearing bypass your ammeter ASAP. So whats the deal why do I need to bypass it. Also how do I bypass it? I really would like to keep it working if possible.
New Full Size Jeep Nut
90 Grand Wagoneer "Big Mama"
Old 09-17-2009, 09:20 PM
maccj5's Avatar
maccj5 maccj5 is offline
if i remember right since the amperage is going through the meter if any connection gets loose---and they do it has a habit of melting down frying wires and sometimes taking the whole jeep with it--- just disconnect the two leads and solder them together
big alternators and loose connections ---very bad combo
mac
its a jeep thing i dont understand either
69 m715
87 gw
73 cj5
94 yj
69 j 3000-- dennis got it
81 cj7
66 j truck
78 cherokee cheif
Old 09-17-2009, 09:30 PM
littlebuck23's Avatar
littlebuck23 littlebuck23 is offline
I didn't bypass mine. I, like you mentioned, like seeing witch way the current is flowing or if the alt is doing its job and keeping the batt voltage level so the current flow is 0.
There is a write up to replace the amp meter with a disassembled volt meter and it turned out really well. its in the archived i believe.
I could see it being a problem if you had a high resistance connection to the studs across the shunt of the meter. Also if one had a problem and was doing lots of cranking and finally got her to fire there would be lots of charging current going thu the meter. That could get pretty hot. And as mentioned above Iv read some stories about rigs catching on fire. Keeping the connections clean of dirt and corrosion is the best defense. I scrubbed mine up so all surfaces were nice and shiny to provide the lowest resistance connection possible.
Terry
1970 Kaiser Wagoneer -SOLD (currently getting built by new owner)
Build thread-http://www.ifsja.org/forums/vb/showthread.php?t=103447
1979 Cherokee Chief WT 360. SOLD
1977 Cherokee Chief WT Sport 401. SOLD
1975 International Scout II (My DD)
Old 09-17-2009, 09:35 PM
asphaltrockdweller's Avatar
So is it just those crappy little speed nuts that come loose?
If so.................... Why not just install locking nuts instead, and problem fixed?
I am with the OP, I like seeing what way my current is flowing.
Old 09-17-2009, 09:39 PM
loose are defiantly no good but having dirty connections is going to generate heat for sure.
Terry
Old 09-17-2009, 11:24 PM
letank's Avatar
letank letank is offline
The main issue is that the ammeter is getting old: 30 to 24 year old for most of those riggs, most parts are designed to survive past the warranty period... Remember that all the current is going thru that device... so 30 amps on charge .... after a while the device will fail. You crank.. the engine start.... then dies..... Some FSJ did not even come with fusible links.... so this is preventive..... the easy way is to connect both wires to the same post on the ammeter.... make sure that you disconnect the battery before playing w the wires. the nicer way is to add a big fuse called a ANL fuse... at any marine shop.
for more details
http://www.ifsja.org/forums/vb/archi...p/t-32823.html
Michel
Old 09-18-2009, 05:07 AM
http://www.ifsja.org/forums/vb/showthread.php?t=101061&page=2&highlight=Ammeter+b ypass
Old 09-18-2009, 02:05 PM
for more details
Mine is old. I just wonder why I'm not hearing about getting a new ammeter from BJ's which is what I think I'm going to do. I really like the ammeter so if it's just an age thing I think I'll get the new one from BJ's and clean up my connections real good. That should make my ammeter worry free would'nt ya say?
Old 09-18-2009, 02:10 PM
ricdiculous's Avatar
ricdiculous ricdiculous is offline
is the ammeter the gauge that powers the rest of the cluster? i forget.
Old 09-18-2009, 04:58 PM
Not as far as I know. On my 76 there is one large cluster of wires that plugs into a special plug that I believe powers the guges with the exception of the ammeter. I'm pretty sure the ammeter is seperate from the rest of the guages and gets it's power from the alt.
Old 09-18-2009, 05:05 PM
i know on my '84 the power comes into the cluster through one particular gauge and if it goes, every gauge on the cluster goes. i know because when i got the jeep, the cluster wasn't working and this was the reason.
pretty sure it was the ammeter. and i guess maybe the whole thing pulls power from the alt? not sure, but i can look in my shop book.
Old 09-19-2009, 08:05 AM
If the guage cluster was powered by the ammeter would'nt bypassing it make the rest of the cluster lose power?
Old 09-19-2009, 08:09 AM
it's the temp guage. has the volt regulator in it. powers the fuel and oil guage.
i think the ammeter scare is largely overrated. i like them. i've yet to see a fsj that had symptoms of heat around the amp guage.
i leave em hooked up,but make sure the connections are clean and tight.
Old 09-19-2009, 08:34 AM
I forget the details but the power to some other accessories goes through the amp gauge. That power line has nothing to do with the rest of the instrument cluster. I had never seen one that was burnt until I pulled the cluster out of the Cherokee 401 donor 2 weeks ago. A lot of the wiring under the hood had insulation melted off of it. This can be caused by a variety of things especially adding on high wattage lights and sound systems if they use power from that feed. You can also move one lug to the other post if you really want to bypass it. The circuit board is burnt and maybe some leads too. The brown at the bottom is from heat. The front of the gauge does not look burnt but is loose and flopping around in the cluster. I don't think this is common enough event to warrant bypassing the gauge but it would be ugly to have a dash fire from this. It may not be a bad idea to at least inspect the connections for peace of mind.
Old 09-19-2009, 02:10 PM
araknid75's Avatar
araknid75 araknid75 is offline
heres a writeup on the bypass with pics
Here is a write-up I did on the bypass with pics
http://www.ifsja.org/forums/vb/showt...hlight=ammeter
-1977 Cherokee Chief S, 401 mildly built, thorley headers, Magnaflow muffler with dual out exhaust, BJ's 4" offroad lift, 33X12.5R15 Goodyear Wrangler MTRk's, Front discos, offroad bumper and warn winch, Bumper hi-lift jack mount, KC offroad lights
-04 Rubicon, 4" Rubicon Express SA lift. 33" MTR's, Superwinch, misc. armor.
Old 09-19-2009, 03:46 PM
I'm in agreement with those who use the ammeters. I'll clean my connections very good. I don't have any funky wiring going on under the hood and I don't have a huge stereo system or High Voltage Headlights just a pretty stock wiring system thats in pretty good shape. So I should be fine running it. I like seeing how many amps are being put to my battery or are being drawn by my accesories. I'll take an ammeter over a volt meter any day.
Old 09-19-2009, 03:57 PM
try to avoid using the alternator to bring back a dead battery,like after a jump start. if you have to,keep the revs low. keeps excessive current from the ammeter.
i run a fusible link at the output of the alternator.
Old 09-19-2009, 04:11 PM
PlasticBoob's Avatar
All Makes Combined
Watch out! I've had it happen on two stock FSJs. When I bought my Cherokee, it was already too late - I had a ball of melted wire and plastic under the dash.
My friend's '78 J-10 had a meltdown while we were driving. After that, we realized that the dash had already been replaced with an early '80s model, and upon closer inspection, there was a previous fire and meltdown that almost took out the whole truck. Some dipwad didn't fix the problem, they just replaced the dash!
I say shunt it, ditch it, do whatever you have to do if you want to keep an ammeter...JUST DON'T LEAVE IT STOCK!
Rob
Click for video
[b][size=2]
Old 09-19-2009, 05:55 PM
I will at some point in the near future put a 100 amp breaker in the loop to prevent it getting overloaded.
Old 09-20-2009, 07:50 AM
fire by ammeter posts always make me so paranoid that my truck is burning to the ground as i read them.
