I know this has been covered before, but I did not find all of the information that I needed in one place, so here is my experience swapping the Ford ignition module to the GM HEI ignition module:
Pretty simple swap. Gutting the old module is time consuming, but pretty straightforward; I didn't bother heating it up in the oven as others suggested. The sandy goop inside was really not all that hard to remove at room tempterature. There are two screws holding the aluminum plate burried in the goop that are not obvious and were not mentioned in the other write-ups I found. Dig around and find them on the edge opposite the wiring inlet before trying to pry the plate out.
I cut the wires as long as possible, crimped terminals on the ends and then screwed the HEI module to the inside of the original module's housing as a heatsink. The wires are not quite long enough for the blue strain relief block to be secured in its intended location, so I just left the wires hanging out the bottom between the box and fender instead of grafting extensions to the wires.
The other write-ups were a little confusing to me because they would sometimes reference the wire colors on the module (ford) and sometimes the colors in the jeep harness, but never the two together.
Here's a breakdown of the wiring connections with respect to a 1990 wiring harness referenced from the wire colors on the Duraspark Module:
In the two-wire plug:
In the four wire plug:
I was always confused about distributor pickup pos and neg. How can you tell which is which? My distributor plug disintegrated a long time ago and I always wondered if I had it hooked up right. I tried it the other way once and the coil got smoking hot so apparently it does matter... Well, the wires on my distributor are Black w/ Orange Stripe, Black w/ Purple Stripe and Solid Black, which correlate with the Ford wiring colors of Orange=Pos and Purple=Neg.
Some said that TFI conversion was prerequisite, but I'm not convinced that it is. The HEI system was designed to work without the resistance wire to the coil, but that resistance wire only effects the voltage at the coil, the ignition module gets its power upstream of the resistance wire. I had already done TFI, so my coil could run 12v, but I did not dig out the resistance wire so I'm not getting as much spark as I could. I will probably take it out eventually, but I'm not in a big hurry.
The new HEI module changed the timing considerably and I had to advance the timing to get it back to spec.
If I were doing it again I'm not sure I wouldn't just get a generic ford duraspark module and graft the jeep plugs onto it. The regular ford module is a lot cheaper than the jeep specific module. The only difference is the type of plug connecting it to the wiring harness.
Check the attachment for a diagram with jeep and ford colors.
Here are some resources I found useful:
A nice concise wiring diagram with the ford colors on it:
Concise diagram with Jeep colors:
A bit more detailed write-up, but not jeep specific:
This is a pretty common ford mod; google "duraspark hei" and you'll get a lot more references.
- White on the original module is for the duraspark cranking retard and is the one that is not used on the HEI. It corresponds to Green in the harness.
- Red on the original module is power coming in, corresponds to yellow in the harness. Connect to B on the HEI.
- Orange on the original module is Distributor Pickup Pos. Corresponds Light Blue in the harness. Connect to W on the HEI.
- Purple on the original module is Distributor Pickup Neg. Corresponds to White in the harness. Connect to G on the HEI.
- Green on the original module is Coil Neg. Corresponds to Green w/ White Stripe in the harness. Connect to C on the HEI.
- Black on the original module is Distributor Ground. Corresponds to Black in the harness. Connect to Grounding Terminal on HEI.
