Old 08-06-2009, 08:13 PM
skinnyD's Avatar
skinnyD skinnyD is offline
plugged a port, am I o.k.?
I have a leak coming from the air pump(?). Its located on the drivers side fender. The hose in question is the top one on the right side of the pump and goes into the black tuna can looking thing bolted right next to it on the fender. SO, I capped the port on the air pump and plugged the rubber hose. The hose is brand new but the connection on the air pump is cracked I think. Am I gonna blow my motor if I leave it like I have it and dont replace the air pump?
1988 GW
white,burgundy leather woody
360 V8 motorcraft 2150 2bbl
Optima Yellowtop battery
Pretty much all origional/stock and luvin' it
SOLD
Not All Who Wander Are Lost.
Old 08-07-2009, 06:35 AM
scotty1998's Avatar
scotty1998 scotty1998 is offline
I believe the tuna can is for your cruise control so if you block that tube off, no worky. Using or not using the air pump will have no effect on the operation of your vehicle. However, if you are in an emission nazi state, you'll need to have it hooked up and working the next time you're up for inspection.
1987 Jeep Grand Wagoneer
Stock Everything
AMC 360, 2-BBL Motorcraft
98K Original
TFI Upgrade
"The only difference between a developer and an environmentalist
is: A developer wants to build a house in the woods.
An environmentalist has a house in the woods. "
- Unknown
Old 08-07-2009, 12:16 PM
skinnyD's Avatar
ok thanks so much for the info and quick response!
1988 GW
SOLD
