Old 08-04-2009, 07:54 PM
rustynuts rustynuts is offline
screams from the garage!
well over the last 3 weeks I have changed the rear main seal and pan gaskets 3 times on my 258 and it still leaks!!!
I used fel-pro seal/gasket sets......then dealer seals with a one piece pan gasket and lastly a combination of felpro and a healthy application of rtv.
So its destined to be a leaker and to think I could have bought 3-4 cases of oil for what I spent in time and mtls.
83 j10
78 cherokee S
57 pontiac gasser
46 chevy 1 ton
34 Plymouth 5W coupe
Old 08-04-2009, 07:56 PM
KyooMac's Avatar
KyooMac KyooMac is offline
grab a beer
Old 08-04-2009, 08:37 PM
Stuka's Avatar
Stuka Stuka is offline
How well are you cleaning the gasket surface? What are you using to clean the surface? Which RTV are you using? And lastly, only apply a TINY amount of rtf, too much and you are more likely to cause a leak then stop it.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 08-04-2009, 08:39 PM
carlisle_jeeps's Avatar
carlisle_jeeps carlisle_jeeps is offline
Rear main seal
Don't take this wrong but did you follow the TSM directions exactly? I had a friend help me rebuild a 258 once and he did the rear main himself using an "old school method" and said it'll never leak. Yeah right! Famous last words. Two weeks later I had to re do it and I did it exactly as the TSM indicated soapy water and all. It never leaked again for the three years I still had it. This is just my experience and I would think as long as there is nothing wrong with your crank, oil pan or rear main cap it should work for you.
If you need the directions from the TSM let me know.
BTW I used felpro gaskets both times.
79 J10 Frame up restoration finally in progress!
Old 08-04-2009, 08:41 PM
Chevelleguy's Avatar
Did you inspect the pan real good in the back corners? I had one leak after a gasket & seal replacement. Turned out that the pan was cracked in the corner where the 'U' bend met the pan rail.
Old 08-04-2009, 09:03 PM
letank's Avatar
letank letank is offline
Valve cover leaking.
Or thrust bearing out of whack and the crankshaft if moving fore and aft destroying your rear seal. Grab the harmonic balancer and if you can pull or push it more than 1/4 inch.... you need to have the crankshaft out.
Michel
74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to Moab without a rebuilt? Status: debugging a few electricals.
85 Gwag, 210 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
my jeep aid images
http://picasaweb.google.com/jeepmr/FSJ
Old 08-04-2009, 09:08 PM
aallison aallison is offline
Jeeps just want to leak. If you stop it there, it will start someplace else.
Do something else. Then give it another shot and try to stop it. Clean it real good and following the directions.........
Old 08-04-2009, 09:16 PM
gotmike's Avatar
gotmike gotmike is offline
put some UV dye in there to spot exactly where the leak is coming from... that way you've got a better idea of what needs fixing...
J.E.E.P
Just Everyone Elses Parts!
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Dana 70-HD Rear axle
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=90702
trailer build thread: http://www.ifsja.org/forums/vb/showthread.php?p=1314880&posted=1#post1314880
Old 08-04-2009, 11:17 PM
drlocke's Avatar
drlocke drlocke is offline
Roadside Mechanic
All good advice from what I see thus far--especially dye-tracking.
You need to make sure there's now imperfection in the pin of the crank that might be admitting oil leakage, or abrading the seal....
Old 08-04-2009, 11:25 PM
drlocke's Avatar
Roadside Mechanic
I should say that there have been many screams from the general direction of my garage over the years. Spit happens....
Old 09-03-2009, 12:52 PM
well I did the UV dye trick , got it from NAPA here in Canada for around $50.00, and found that there was a leak half way along the oil pan to block . So the oil was running along the oil pan lip and hitting the bell housing then running down the access plate making it appear as though the RMS was leaking.
So I then used some Seal-All over the leak, covered that with some foil I got from a cigarette package ( paper burned off) then another coat of S-A covered with more foil till I had 3 layers . Let it cure over night and guess what..........no leaks!
83 j10
78 cherokee S
57 pontiac gasser
46 chevy 1 ton
Old 09-03-2009, 01:18 PM
asphaltrockdweller's Avatar
We say this about our Porsche's but I guess it will work on Jeeps too?
Do you know how to tell when your Porsche has burned through all it's oil?
When it stops leaking
Old 09-03-2009, 01:56 PM
Sambo's Avatar
Sambo Sambo is offline
lol my garage(ok carport) has heard many of choice words!
like toby keith says"fits gonna hit the shan"
what kinda oil psi do you have? are you letting it "setup" for a while before starting it back up? maybe the pressure is blowing it out.
77Chero,360/t400/231/d300,d60,c14bolt 5.13's 42"rockerz
84wag,360/tf727/208,hp d60,d60,4.10's,37"goodyears(old style mtr)
Old 09-03-2009, 03:34 PM
BamaDrew's Avatar
BamaDrew BamaDrew is offline
My 86 GW refuses to stop leaking too after rear main, pan gasket, etc but it's receiving a freshly built 360 from my 91 in a few weeks so it'll be all good. My solution for the time being....making sure it's parked in the garage with an oil-resistant coating on the floor and not out on my concrete driveway.
I agree, seems as though Jeeps just like to leak. We had an 86 Chero V6 that leaked for at least 7 or 8 of the 11 years we owned it. And that was with dealer maintenance always.
1986 Jeep Grand Wagoneer
A Labor of Love
Old 09-03-2009, 06:11 PM
YellowJeep's Avatar
YellowJeep YellowJeep is offline
Somewhat off topice, but for stubborn leaks and for things I have no interest in taking apart again, I always use "The Right Stuff". Its made by permatex, doesn't mind a dirty mating stuff and is very reliable. Beats regular RTV by a mile!
Chad-
88 Wrangler - TBI350 SM465 Ford 8.8
79 Cherokee Golden Eagle - AKA "The Screamin Eagle" - 5.3 Runs and Drives. TH400 and Q-Trac!
2006 Chrysler 300c - Cause sometimes you a need 350+hp daily driver.
1991 Corvette - Just another toy!
Carbs suck!
Old 09-03-2009, 07:19 PM
maccj5's Avatar
maccj5 maccj5 is offline
i'm glad i have dirt on the side of my house my 87 gw probably will never be house broken a rolled up jp magazine doesn't work it still wizzes on the ground
mac
its a jeep thing i dont understand either
69 m715
87 gw
73 cj5
94 yj
69 j 3000-- dennis got it
81 cj7
66 j truck
78 cherokee cheif
