Old 07-21-2009, 05:41 PM
V8 timing cover/Oil pump refresher. pic heavy.
oil pump rebuild. off the engine. you can put new gears,midplate in with it on the engine,but anything more like i'll be doing requires removal of the cover,and then removal of the fuel and water pumps.
here's the victim. 9 bolts hold the cover on. the big plug is the pressure relief valve assembly.
if off the engine,before dis-assembly,pull up and down on the pump drive shaft to feel the freeplay. this one had a lot.
that will be remedied in a bit. remove the pressure relief plug first,withdrawing rthe assembly,as shown. it is in correct order for re-assembly in pic as well.
remove the 7 bolts holding the pump cover to the housing. 7/16" bolt heads.cover may need a tap or so to dislodge. if on the vehicle the gears will spill out. note typical score marks on cover.
after cleaning,you can measure the end gap of the gears to housing. the gears should stand out of the housing a few thou or more.you slide feeler guages between straight edge and timing cover to find amount. but don't be surprised if they don't. some are even flush. this one was.
so,here's how we fix that. get a flat pane of automotive glass. pull the side window out of your GW if you need one,lol!
get a tub of valve grinding paste,smear it over the glass. i'll first get the score marks out of the cover. big circles,or even straight line is fine,but either way you want to keep central pressure on the piece,and turn it 1/4 turn every 25 laps or so. add compound as you go.
the finished cover. the fine scratches are from trial fitting the cover.
next we do the cover,and remedy those flush gears. but first. the typical gaskets for these pump kits are about .010" thick,compress a couple thou upon tightening. thinner are available from Bulltear.com,and are a viable way to tighten clearances. but the thinner the gasket,the greater the chance for leaks.
so,we do the same lapping treatment to the cover. it is a little cumbersome,but once you try it you'll see there are ways to hold it squarely on the glass. remember to rotate it now and then,checking often. it's a pain constantly cleaning for checking but has to be done.
this may take a while,especially if it's a flush cover like this. you want to go till you have about .004-.005" clearance. then trial fit the cover with gasket installed.the gears must turn freely.
finished product.
now,the gears turn freely,yet end play is nearly nil. perfect.
also. all but the late engines came with a bypass in the cover. a little spring loaded piston next to the filter mounting stud. a real joke,it was eliminated on the very late engines. it can allow dirty oil to bypass the filter and go straight to the motor. the valve is seen on the upper cover. i highly recommend getting a plug for that valve,as shown on the lower cover, from Bulltear.com. they fit very nicely,easy to install.
also,if you have a very late model without the bypass valve,it'll likely take the later,smaller metric oil filter. the filter stud can be removed,and substituted with an earlier stud,to fit the earlier bigger filter. the cover threads were unchanged with the switch to the late filter.
the oil pump inlet necked down pretty small,i opened it up with the dremel.
i also enlarged the outlet hole in the pump,which is very small. i used a rasp.
here's the inlet and outlet together after the work was done.
here's a stock cover,same as what i started with.
that should move a little more oil.
i'll go into the final reassembly and pump prep for start-up later. it's the reverse of the take-apart process. also,MY engines don't get vaseline run through them.
Old 07-21-2009, 05:46 PM
mattmopar440's Avatar
nice Write up mike is that the 3903/4
91' Grand Wagoneer
401/727/229, Currently:Down for Body Work
77' Wagoneer 401 Parts rig
80's J10 258/T-5/208
89' Jeep GrandWagoneer
New Project
Inferior Chevy
Old 07-21-2009, 06:34 PM
RED-85-Z51 RED-85-Z51 is offline
I got my pump kit and midplate kit in from BJ's and Ill be doing this, along with an exh. manifold pull, with the engine still installed on the chassis. Looks like....fun
1989 Jeep Grand Wagoneer SOLD
1998 Ram 1500
5.9 Magnum
4 speed auto
Quad Cab
1985 Corvette Z51
350 Tuned Port Injection
*restoring now*
1976 Corvette L48 Stingray
-restoring-
1989 Cadillac Fleetwood Sedan
4.5 Liter V8
all Options
Old 07-22-2009, 10:11 AM
red mistress's Avatar
Wax on..wax off
Good write-up...Definately needs archive.
So how many strokes or how long to rub off few thou..?
69 Jeepster 8701 convertible
80 Honcho Sportside
82 CJ-8 75K org SR decals
82 Cheroeke Laredo 24K
84 CJ-8 mud Scrambler
Old 07-22-2009, 10:36 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Good as usual Mike.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 07-22-2009, 11:29 AM
Charlie_B's Avatar
Charlie_B Charlie_B is offline
nice write up. Doesnt look too bad.
'79 Cherokee "Goldie" - under the knife Part I; Part II
Currently: body is on, now finishing undercarriage
'92 Cherokee "Rusty" - 3" lift, 31s
'05 Evo MR "Eve"
Old 07-22-2009, 01:36 PM
twmattox twmattox is offline
Thank you very very much...
Old 07-22-2009, 07:32 PM
newtojeeps's Avatar
As usual, great work, and thanks
Old 07-22-2009, 09:35 PM
vintagetrks's Avatar
Very informative Thank You.
New Full Size Jeep Nut
90 Grand Wagoneer "Big Mama"
Old 01-21-2012, 11:08 AM
Bingo. Is this archived?
Old 01-21-2012, 11:39 AM
Tripwire's Avatar
Tripwire Tripwire is offline
what about the idler shaft for the other gear?
the rebuild kits come with them and i had to install it on my last rebuild because of a teeny leak in that area
also, are there different springs to improve pressure on a worn engine?
if the chamber inside is grooved up is it junk?
Thanks for the write up
Abort? Retry? Ignore? >
86 GrandWag. Howell fuel Injected 360. MSD Ignition + Dizzy. 727/228 BJ's 2" Lift and 31's
Old 01-21-2012, 12:54 PM
SC/397's Avatar
SC/397 SC/397 is offline
I use a flat file with different grades of sand paper wrapped around it. If the oil pump cover is scored as bad as yours is I start with 80 grit then 150 and down to 600 with WD40 as a lubricant. I don't use the mid plate. I also shoot for zero end clearance with the gasket in place.
Old 01-21-2012, 06:32 PM
The Colonel's Avatar
The spring is only for the max pressure relief- it won't improve a low oil pressure problem.
Old 01-21-2012, 07:46 PM
Stupified's Avatar
Stupified Stupified is offline
Thanks ! Great write up.
Just curious... what are your thoughts on clearancing the internals in the front cover. The last one I had off, the casting job in the oil flow galleys was horrible. I followed the majority of the mods as well as the zero clearance on the gear set, upgraded the pressure relief but did not use a midplate.
http://home.comcast.net/~amc_jeep/AM...ing%20mods.htm
73 Wagoneer 360 400/20 D40/D30 3.31
285/70R17 DuraGrapplers
post flipped rear, rough country 6110 chevy front AAL
Camo green Zombie Response Vehicle
Old 01-21-2012, 09:20 PM
I did clearance the oil pump cover & adapter oil passages like shown in the documents. I think it's worth-wild if you already have the cover off anyway.
Also like Mike shows here:
http://www.ifsja.org/forums/vb/showp...2&postcount=86
Old 02-27-2018, 11:33 AM
Hey Ristow, Anyway you can restore the photos? All I see are the Photobucket raped you logos.
79 Cherokee Chief Wide Track, In pieces
Old 02-27-2018, 11:44 AM
I don't think anyone can short of paying their 400 bucks a year. When I get home I'll post the link to my photo bucket dump and what page these are on, that should at least work.
Old 02-27-2018, 12:00 PM
rgr, thank you, sir. Sounds good to me.
Old 02-27-2018, 03:40 PM
Tried my laptop at home (has PB plugin) and I see the pictures now.
Old 02-27-2018, 09:14 PM
WrenchMonkey WrenchMonkey is offline
PB plugin??? Whaaaat? Black magic, sweet mother of god it works!
https://chrome.google.com/webstore/d...iaedg?hl=en-US
if not chrome then try your flavors extension store.
1977 J20 w/ the 360 V8 with 304 heads formerly known as "401"....
Edelbrock Performer, Street Demon Carb, HEI Distributor
