Old 06-13-2009, 09:23 PM
dajeeps's Avatar
dajeeps dajeeps is offline
carb spacer
i have a eddy perfomer intake and a eddy 1406 carb.i've been having trouble with warm starts. i have to hold the gas pedel to the floor before it starts.i also had this issue with a carter afb as well.
so i'm thinking about putting in a spacer in between the two,trying to reduce the heat transfer.witch spacer do i use?
all 2 in the pic's fit .which one?
any help would be appreaciated.
matt
http://i533.photobucket.com/albums/e...s/100_0469.jpg
http://i533.photobucket.com/albums/e...s/100_0471.jpg
82 wagoneer dd
73 j4000 crewcab project
77 cherokee s wide track (parts rig)
Old 06-13-2009, 10:31 PM
skeletor's Avatar
skeletor skeletor is offline
what you want is a 1/4 -1/2" phenolic spacer. edelbrocks hate the heat.
-bryan
1984 j10
http://www.youtube.com/watch?v=NgpZ9c8prug
GO BILLS!
Old 06-13-2009, 10:37 PM
dajeeps's Avatar
do you mean like in the first picture?it is 3\8'' thick.or do i get one that ha a square hole.
82 wagoneer dd
Old 06-13-2009, 10:59 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
My Edelbrock hated the heat and would not start when warm. The carb spacer, cheap $25 one from the parts store, did the trick. Remember to spray down the spacer on all sides with starter fluid to see if you're idle speed picks up.
Mine also grew some balls after the spacer was installed.
Old 06-14-2009, 10:07 AM
dajeeps's Avatar
on a limited buget would the spacer in the first picture work?it seems to fit when i matched to a carter afb and the eddy manifold.
82 wagoneer dd
Old 06-14-2009, 10:46 AM
skeletor's Avatar
if they both fit and you wont any vacuum leaks, use both.
-bryan
1984 j10
GO BILLS!
Old 06-14-2009, 10:55 AM
did you set the float level?
Old 06-14-2009, 11:50 AM
Johnny&Midge's Avatar
Johnny&Midge Johnny&Midge is offline
seeing how big the origional spacer was on the 4350 I didn't want to do anything less so when I made this very same swap I used the 1in spacer.
The Jeetus
'76 Wag
401
Edelbrock Lungs
Old 06-14-2009, 06:35 PM
dajeeps's Avatar
what do you mean?i wouldn't know how to do that.not yet anyways.
82 wagoneer dd
Old 06-15-2009, 08:25 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
go to Edelbrock's website, they have instructions for that carb.....it tells you how to disassemble, adjust, set the float heights, etc.
BJ's Off-Road
ryan@bjsoffroad.com
Old 06-15-2009, 09:06 AM
high float level will cause all kinds of trouble,including what you describe.
Old 06-15-2009, 09:32 AM
dajeeps's Avatar
ristow after you mentioned float level i went to edelbrock's website and read up on it.sounds easy enough.i'll have to read it agin to make sure i do it right.
82 wagoneer dd
