Old 06-12-2009, 10:57 PM
PlasticBoob's Avatar
All Makes Combined
Cold air intake I'm throwing together
Well here we are. I haven't figured out the best way to mount it yet, but things are coming along nicely! Excuse the wiring mess, I'm still messing with fuel injection.
Incomplete list of parts:
4" Air intake plenum: Spectre 9843
4" Intake hose: Spectre 9751
4" Air box with conical filter: Spectre 9831
4" Coupler that goes to the grill: Spectre 9148
The air temperature sensor will be mounted in the black plenum - I'm going to attempt to drill and tap it; if that doesn't work then an interior nut will. The memory flex hose is very close to the master cylinder - this is going to be a very tight fit. A 3" system will work just fine for a 360, and there will be more room.
This coupler....
...is to be mounted on the drilled radiator core support, drawing in cool air from just behind the razor grill. I don't plan on doing any crazy water obstacles, so it should work well until I decide on what to do for a snorkel.
And just for fun, the ECU:
Rob
Click for video
All Makes Combined
Whoops, wrong forum. Will someone please move this to tech?
Rob
Click for video
Old 06-13-2009, 09:46 AM
del's Avatar
del del is offline
intake
Dude, if you're not happy with that set-up, try welding/riveting an additional snorkel onto an existing low clearance air cleaner. Two should give you the air you need for the 401. Cool factor too. The setup you have now looks pretty cool also. Have you run the motor yet? Interested how the F/I runs....Del
Old 06-13-2009, 09:55 AM
that'll work nicely. lessee that air filter element.
Old 06-13-2009, 04:39 PM
FSJ Guy FSJ Guy is offline
Did you get mad at your coolant overflow bottle and your windshield washer reservoir?
Looks nice except for where to put the air filter.
Ethan Brady
www.bigscaryjeep.com
Old 06-13-2009, 06:09 PM
Subic Jeep's Avatar
Subic Jeep Subic Jeep is offline
Looks good!
I was looking for a intake plenum to attach to a snorkel and I found K&N at $169 and thats a bit much. ...
Lars
I am in the five bananas category!
Cherokee 1981 officially 1974 huh local irony
Gen 1 GM-SB 350 V8 TBI - TH400 - Klune V - Twin stick NP205 w. Nippon shifter
Dana 60 w. ARB locker, hydraulic assist + GM 14FF w. Detroit locker.4-link rear on LC80 19mm coils
Rancho 5036 Shocks 14 inch travel. 39.5x15.5x15 TSL
Old 06-13-2009, 06:41 PM
jMedia's Avatar
jMedia jMedia is offline
Thanks for the post! How come you move it to the other side? And like FSJ Guy said what happened to the coolant overflow bottle and your windshield washer reservoir?
thanks again
Joshua
Constantly changing, never done
