Old 06-07-2009, 05:56 PM
jMedia's Avatar
jMedia jMedia is offline
AX15 or AW4 swap Help
As the title reads I have a few questions before I dive into a swap
Money and difficulty of swap aside, what do you guys think would be the best for a DD 88 GW v8?
Also how would I need to change my 3.31 ratio to best take advantage of the transmissions?
Thanks
Joshua
Cosntantly changing, never done
Originally Posted by joe
Point #1. Do this for love. Get any crazy ideas like I'll sell it when done out of your head right now.
Old 06-07-2009, 08:29 PM
addicted's Avatar
addicted addicted is offline
The AW4 is going to be your cheapest and easiest way. It will keep it auto and require less parts to find and pay for.
The best ratio IMO for it would be 3.73:1, it will keep the engine in it's power band better, allow you to tow stuff and get decent mileage.
Old 06-07-2009, 08:30 PM
mattmopar440's Avatar
T-5 would be the easiest just fine a 80 j20/j10
91' Grand Wagoneer
401/727/229, HEI, Edel 2131 Intake,8600, Holley Truck Avenger, Dual Exhaust, Flowmaster 70. Edelbrock shorty headers.4" BJS 31 BFG Mud-Terrains
Currently:Down for Body Work
80's J10 258/T-5/208
90' Jeep GrandWagoneer
SOLD
Inferior Chevy
Old 06-07-2009, 09:41 PM
jMedia's Avatar
If I don't tow ever(no other goodies to tow yet) is that still the best ratio? Looking for best mileage
Joshua
Old 06-07-2009, 11:02 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
One step at a time. Swap in the transmission of choice and see how it works with your engine and axles. Run a few tanks of gas through it to see what mileage you get and plan a gear swap if needed. 3.31s are good for highway cruising so run with them for a while and see how you like it.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
http://s726.photobucket.com/albums/ww267/lkmarsh/
Old 06-08-2009, 07:56 AM
Chevelleguy's Avatar
I agree. I had 3.36's in my Chevelle with a 700R4 and it was perfect for what I wanted, 3.73 made first gear too short. This was with 275/60/15 tires, which are 28" tall.
If you are running taller tires, 3.55's or 3.73's will be needed. My wife's XJ with 31" tries didn't like hills much with overdrive and the stock 3.55's.
Old 06-08-2009, 08:31 AM
addicted's Avatar
The vehicles main use will dictate what gears will be better. If it is going to see a lot of highway use then the 3.31's might just be perfect but if it is going to be used for a lot of stop and go a deeper gear will get things in the power band and keep the engine from lugging all the time and if stop and go is it's main use then putting an OD trans in it will be a waste of time and money since you will rarely see speeds high enough for long enough to utilize OD and it's benefits.
Old 06-08-2009, 09:04 AM
jMedia's Avatar
Its used for some stop and go around town, but i do go a longer road trips quite often so it'll see highway use a lot
Joshua
Old 06-08-2009, 09:12 AM
addicted's Avatar
Then yeah I would say go for the swap, drive it for a while and if you find the performance is just awful or at least not up to your standards swap the gears out for some 3.54's
Old 06-08-2009, 12:04 PM
jMedia's Avatar
If driven correctly, could I get better mileage out of the manual?
Joshua
Old 06-08-2009, 12:08 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
AX-15 is a great tranny but I have heard horror stories about guys gernading them with mildly built AMC V-8's. I dunno if it's true or not but like others have said an AW4 would be the best and easiest swap to do.
Old 06-08-2009, 12:11 PM
Yes! I had a 90 XJ with a 4.0, AX-15, NP231 and 3.05 gearing. On a trip from PA to NC I averaged 32MPG. I was never able to do it again after that but my mileage was typically above 22MPG and my buddy's XJ would manage 17MPG and the only thing different was the tranny and gearing.
With fuel injection maybe you can get 15 or 16 with a GW
Old 06-08-2009, 12:52 PM
I remember 19-21mpg out of our 2WD XJ with the AX-15. Our 4WD with the AW4 got 17 also.
Old 06-08-2009, 01:00 PM
Must have been a fun Jeep assuming it had the 4.0
Old 06-08-2009, 01:32 PM
jMedia's Avatar
Everyone keeps pushing me away from the ax15 swap, is it really difficult? Is there an easier OD manual to put in?
Joshua
Old 06-08-2009, 01:50 PM
Your Jeep has an automatic now? The V8 Wagoneers with a manual transmission use a funny setup with a long spacer between the bellhousing and the transmission, and a very long input shaft. This moves the shifter rearward, into the cabin. The shifter of a top-shift manual like a Ford T-18 with the usual short input shaft will come up under the dash of a Wagoneer. If you are wiling to bend the shift stalk so you can reach it, that might not be a problem for you. However, I'm not certain what the shifter setup is on an AX15 - I think it's a short shifter stalk, so you may not be able to bend it to fit. Best thing to do would be get out the tape and measure.
Additionally, you'll want to find a manual transmission FSJ donor for all the clutch-related pieces like the pedal, linkage, plain steering column, etc.
This is aside from any durability issues that might arise with the V8 + AX15 + heavy vehicle combo. You could go with a NV4500 if you were worried about this ... but I expect it would be very expensive.
No personal experience, but the folks at the Novak site seem to think rather highly of the AX15.
Old 06-08-2009, 02:11 PM
skeletor's Avatar
skeletor skeletor is offline
did the zj ax15 have a different shifter than the xj version? i remember hearing something like that, but there isnt a whole bunch of factory manual zj's floating around.
-bryan
1984 j10
http://www.youtube.com/watch?v=NgpZ9c8prug
GO BILLS!
Old 06-08-2009, 05:50 PM
Al Johnson Al Johnson is offline
I'm going to vote for an AX-15. I have one in my baby Jeep (87 Wrangler) behind a torquey mildly built 360, and have not babied it. Works fine. Be sure to use good synthetic lube such as Redline in the AX-15. I like mine.
That said, I think the AW4 is also a good choice. I had one in an XJ, and it was a real good tranny.
Either way, have fun.
Now running! a 360 GW engine in my Wrangler. Former owner of \'78 Wag with 401 and \'84 GW engine donor, RIP.
Old 06-08-2009, 06:55 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I run the NV3550 and have had no problems with it. I run 3.55 gears and 32-33" tires (depending on season). I have towed with mine (worn out 4.0L and 32s) and it did alright, not spectacular but sufficient. That was in 4th all the way, though. I suspect with a stock 360 and more factory sized tires 3.31s would be fine. Plus the GW is considerably more aerodynamic than my J-truck.
Either will probably work ok for you assuming average street driving. I see a TON of people running the AX15 with strokers, and most of those strokers have to be pushing similar #s to a stock 360, especially a smogged one. Weight and abuse will certainly be your enemy with either transmission. If you don't drive like a fool you should be good with either.
If you're worried about durability, think about this: the AW4 was run in 320+ hp twin turbo Toyota Supras. Granted the weight is less, but abuse certainly wasn't. lol
aa
Anthony
1983 J-10 - 4.6L(MPFI)/CS144/NV3550/D300/44/44/3.54/32
1983 Honda CB1100F
1983 Honda CB1000C
Old 06-08-2009, 07:19 PM
jMedia's Avatar
I do have an automatic now. I dont think Ill have durability issues, I've heard its pretty strong, especially since I will not be offroading. As for the shifter coming up under the dash...
You referenced the t18 coming up under the dash, its 11.9" where as the AX15 is 16.5" long. Not a huge difference but is it enough?
Also by the pictures it looks like the shifter on the t18 is further forward than the ax15
t18:
and here is the AX15:
Joshua
