  #101
Old 08-26-2010, 08:36 PM
j20brett's Avatar
j20brett j20brett is offline
As soon as i wire them up ill have them. Give me a week
Busted my knuckled bad tuesday afternoon...to the bone, so i gotta watch what i do so i dont split it back open
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 08-27-2010, 05:06 AM
bill3's Avatar
bill3 bill3 is offline
Sweeeeet x2 on flat black. Did you make your own bumper? Try some lock tite, or neopreem lock nuts.
1981 J10 4X4 STEP SIDE
ENGINE: CHEVY 427
TRANNY: TURBO 400
T-CASE: NP208
FRONT END: DANA 44
REAR END: 10 BOLT
GEAR: 3.73/LOCKER
LIFT: ROUGH COUNTRY 3 or 4"
TIRE: BF GOODWRENCH 33X12.50X15
RIMS: STEEL
Old 08-27-2010, 06:42 AM
j20brett's Avatar
Yeah built the bumper a couple of years ago. I need to get some of those nylock nuts on there.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 09-10-2010, 07:10 AM
j20brett's Avatar
Well, im as ready as ill ever be for our run next weekend. Plus, you can see how the lights turned out.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 09-10-2010, 10:09 AM
Alleneoc's Avatar
Alleneoc Alleneoc is offline
NO WAY!!!!!! SO AM I! Fellow HOOSIER I lived out on the north side past T.H. North. I moved to Houston about 8 yrs ago now. WOW, what a small world.
I was a Brave lived south of town down by the TSC. And join the Navy and now somehow got to Oklahoma (wife thing)
Like you truck my son and I are going to do something like that to ours.
Old 09-10-2010, 11:21 AM
jode's Avatar
jode jode is offline
JB Welder
Warning - there appears to be something majorly wrong with your J20 - there are no oil spots under it. You might need to check your fluids.
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 09-10-2010, 11:41 AM
j20brett's Avatar
HAAAAAAAAA! Thats cause i just took it outta the garage. Its a pint low due to leakage at the trans lol.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 09-13-2010, 07:17 AM
j20brett's Avatar
Retimed the ignition and adjusted the idle mix screws on the carb. This thing gets it now! And i have a new respect for anyone who has changed out bushings on the shackles on these rigs. 2 hours of beating with a hammer and socket and it was done. I completely flattened the head of a 1/2" bolt in the process. And my hand is sore today from gripping it so Great Googley MoogleyGreat Googley MoogleyGreat Googley MoogleyGreat Googley Moogley hard. Glad thats over. O and pics of the lights...
Both on
Just hid's
Highs only
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 09-13-2010, 04:29 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
WAAAAAH DUUUUDE!! Those are crazy bright as the sun! I wonder if they could be made to fit in the open holes instead of pie plates with a rhino.
Originally Posted by will e
Old 09-13-2010, 11:56 PM
jepj2000's Avatar
jepj2000 jepj2000 is offline
Very nice on the lights, they seem to pruduce just a tad more light over stock high beams. I really want some cheap HIDs now, dang it.
I know what you mean on those dang shackle bushings, I started doing the same thing and said screw it and bought beefy shackles and RS44044s with new bushings already installed in both.
1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
Old 09-14-2010, 07:36 AM
j20brett's Avatar
Lol good call. Would have saved me quite the headache
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 10-25-2010, 06:54 AM
j20brett's Avatar
A little progress. The neighbors in the apartment dont like it when i crank up the grinder at 8pm
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 10-25-2010, 07:20 AM
duncanstives's Avatar
duncanstives duncanstives is offline
I cheated... Drilled a few holes in the rubber for air flow and lighted them on fire... When they threatened to go out and let a little oxygen from the torch flow on them... About a half hour of nasty smelling smoke and they are pretty much gone... Its a dull orange flame and is not hot enough to damage the metal of the shackles...
EDIT: Oh yeah... I did this in the city so I can't imagine the neighbors were thrilled but I went in to eat dinner and get away from the smell while they burned
88 Waggy
Resting in peace... Um... In piece... Er... IN PIECES
Current Status: Under construction. Phase 2.
86 Pathfinder Conversions "K-Van"
Current Status: Broke
Volkswagen rail buggy
Current status: Broke
95 Jeep ZJ V8
Current status: DDing
Old 10-25-2010, 08:07 AM
j20brett's Avatar
I would have done that, but i still had to get the steel sleeve out also. So a BFH was in order lol
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 10-26-2010, 04:27 AM
jeeping1974's Avatar
Maybe it's just the angle but your front axle looks further back than it should be. How did the wheeling go (maybe I missed that post)?
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 10-26-2010, 06:02 AM
alwomac's Avatar
alwomac alwomac is offline
I use a 1/2" carriage bolt (use carriage bolts because they are fully threaded) about 6" long run through the bolt hole on the bushing with washers that are smaller than the bushing at the head and on the nut end run the bolt through a piece of PVC pipe and put washers behind the pvc pipe that are bigger than than the pipe and tighten it all down. Important notes, make sure the piece of pvc is longer than the bushing so the bushing can be completely extracted into the pipe and make sure the the pvc pipe is the same size as the spring eye. I want to say I used 2", but don't remember that completely. If you get multiple size bolts in 1" increments you don't even have to turn a wrench, just put the impact on the nut and let it rip. Wear safety glasses and gloves because PVC pipe will shatter occasionally !!! You can do both ends in about 5 minutes with no nasty smell or smoke. Then you just have to find other things to piss the neighbors off . Hope this helps.
Aaron Womack
1978 Cherokee 360, 400/QT, HD44, Dana 60, 4.88's, locked, 36s on H1s, SOA/SF, high steer, Rancho RS5000's (14" front/11" rear travel) lots of dents
Old 10-26-2010, 08:02 AM
j20brett's Avatar
Nah thats where its always been. Eventually ill flip the springs around to stretch the front out some. Wheeling sucked at shiloh. Half the park was closed for motorcycle races that we never saw happen.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 10-26-2010, 04:25 PM
Michael's Avatar
Michael Michael is offline
That is strange, from your other picture of your front springs, are those 44044's? Because from the other pic looks like you have the 3/4 miliary wrap at the front. Which would give you the extended wheel base. If those are 44044's and installed that way than I am darn confused.
Rigs looking good. Mine is going to be parted soon.....know anyone that wants a fsj? I am starting another project.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 10-26-2010, 05:16 PM
Sorry to side track here but is this project also FSJ?
88 GW, 401/727/208, 5" lift, D44s/4.10s/locked up, 35s and a few Evil Twin mods, http://eviltwinfab.com
Old 10-26-2010, 05:58 PM
ColeTrickle ColeTrickle is offline
Well, tell him Mike.
J-trucks with Brows RULE!!!
