05-14-2009, 11:39 AM
401 startup?
I bought a complete 401 that has been sitting for about 5 years what is the proper way to get this thing running again? The po said it ran great when he parked it because of a bad tranny (tf727) it came with another one that he said was freshly rebuilt about 5 years ago he just never got around to putting it in. Anyway I was thinking do an oil change on it and then prime the oil pump and pump oil throughout the engine then turn it over by hand a few times to make sure there isn't anything sticking. Does this sound like the proper way to do this?
J Just
E Empty
E Every
P Pocket
1, 77 wagon $200, amc 401 th400 quadratrack 4 in. lift 33-12.50x15
1984 cj-7 Soa w/401, t-18,dana 20 35-12.50x15 1974 j-10 304
05-14-2009, 11:51 AM
I would pull the plugs, and lubricate the cylinders VERY well before you turn it over, even if only turning by hand.
Use some lightweight oil like marvel mystery oil, tranny fluid, or the spray can fogger stuff (sold for seasonal/long term engine storage).
If there is any surface rust or anything in there you risk damaging the cylinder surface(s).
It'll smoke like **** on startup, but better than having an oil burner or having to re-ring it right away.
05-14-2009, 12:04 PM
Hey thanks for the tip I didn't think about that. do you think pb blaster would work also?
J Just
E Empty
E Every
P Pocket
05-14-2009, 12:46 PM
BJ's Off-Road
5 years, I'd take it down and check the bearings and replace them as well as all gaskets, and also check rings / etc. But that's me, and I like tearing down / rebuilding engines
BJ's Off-Road
ryan@bjsoffroad.com
05-14-2009, 12:48 PM
I like doing that too but the problem is I never get them back together again.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
05-14-2009, 12:52 PM
Jeep Polygamist
All good advice.
I'd pour gas in it and go. But that's just me.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
05-14-2009, 12:54 PM
Originally Posted by Casey
All good advice.
x2 Although I would check the plugs first.
JR
05-14-2009, 12:57 PM
If you pull the plugs as suggested, just replace them. My two cents.
Tucker
88 GW, AMC 360 with Doug Thorley headers, Howell TBI, NP229  , TF727, 3.31 gears and the tow package, Magnaflow muffler and cat, BJ's 4" lift kit and 1" body lift, 32" BFG's, aluminum rad, K20 front brake calipers.
____________________
Originally Posted by freeincolorado
Fixing PO stuff is lame.
05-14-2009, 04:04 PM
I would love to tear into it and replace everything but I was barely able to get the money out of the wives purse to be able to buy it in the first place!!!!
J Just
E Empty
E Every
P Pocket
05-14-2009, 04:16 PM
Jeep Polygamist
See post number 6.
Hey it's been working for me for thirty years! Yeah I like to rebuild 'em too. There just comes a time when you just have to say what the....
1994 YJ
1986 Comanche
'57 FC-150
www.cfsjc.com
05-14-2009, 04:47 PM
I'd do like you suggest, prime the oil pump, get oil moving, turn it over a few times, maybe pull the plugs and spray some lubricant in there, PB Blaster sounds good, turn it over a few times by hand, put the plugs in and give it a try.
05-14-2009, 05:41 PM
BJ's Off-Road
if it was a base model 360, I wouldn't care. But with a 401, they are at more of a premium and I'd take the extra time (only talking about a days worth of work, and about $50-$75 in gaskets / bearings). If the bearings are shot or have corroded / rusted, you'll score the crank and shoot the bearings in short order. But to each his own
BJ's Off-Road
ryan@bjsoffroad.com
