Old 04-28-2009, 07:11 PM
TheJeeper's Avatar
TheJeeper TheJeeper is offline
If you had $1,000 to spend.......
On your FSJ, how would you spend it?
I'd buy,
Master cyl.
steering linkage parts,
New or good used tires and wheels,
waggy or cher seats and door panels,
front and rear bumpers,
winch of some sort,
4in. lift blocks for the front, (shackle flip in the rear)
and various other things I can't think of right now.
'65 J200: 230ci., T90, D20, D44s: 4.27s. 31x11.50x15s
'47 Willys CJ-2A: Chevy 153ci 4 cyl, T90, S18, D25, D41: 5.38s. 7.00-16s
Regarding a manual valve-bodied auto... "To me that's like trying to play a fiddle with a sawzall."
Nothing in written by me in ANY post can be used without my written consent.
~Eli's Jeep Supply~
Old 04-28-2009, 07:12 PM
Eric Flewelling Eric Flewelling is offline
I'd buy it in the first place...
Old 04-28-2009, 07:13 PM
orangebike's Avatar
orangebike orangebike is offline
blocks for the front?????? please tell me your joking???? more balls then me i guess
81 chief-straight six auto soa and 3 inch body lift 3/4 ton running gear...37 boggers...ready for 39s....Wheeler
74 401 t18 lifted 6" on 33s for now..soon to be firewood/tow rig
73 j4000 -360-th400 d20 on 33s....now the farm rig
Couple parts jeeps
66 chevelle ss-396
66 chevelle clone 396
Stuff for free.....is worth saving up for
Old 04-28-2009, 07:25 PM
TheJeeper's Avatar
I don't have the $$$ for lift springs, lol. Actually, I may run some lift shackles that I have laying around, but I'm not sure yet.
~Eli's Jeep Supply~
Old 04-28-2009, 07:26 PM
Clean RC's Avatar
Clean RC Clean RC is offline
Id buy a new windsheild, and some new wheels..
Old 04-28-2009, 07:30 PM
krek's Avatar
krek krek is offline
Perpetually Perplexed
Katzkin seat covers.
I'd buy you 4" lift springs for the front so you don't run scary (and illegal) block up front. Hint on the illegal part.
I'd spend it on paint supplies for the 71.
1971 Gladiator J2000 Custom-Cab Platform-Stake Dump
1970 Gladiator J3000 3407Z Camper Truck
1963 Gladiator J300 Thriftside
Visit the Land of Off Topic!
http://gwamp.com/offtopic/index.php
Old 04-28-2009, 07:31 PM
silvercert silvercert is offline
Paint,
Wood Grain
Carpet
The next 1K... BJ's 4" lift, and new front suspension, body bushings
Old 04-28-2009, 07:33 PM
orangebike's Avatar
run a one inch shackle and a add a leaf...total of about 80 bucks plus u bolts if u need them and gives u 3.75 inches of lift
Couple parts jeeps
66 chevelle ss-396
Old 04-28-2009, 07:41 PM
TheJeeper's Avatar
I may take you up on that, lol.
I think I'm going to run the lift shackles I have laying around. They are approx. 30 years old and they look a lot stronger than the stock ones.
~Eli's Jeep Supply~
Old 04-28-2009, 07:47 PM
You could run some zero rate aal's up front. They come in 3/4" and 1" heights and bolt to the springs packs with the center pin. The side (ORD) that makes/sells them say they can go on the front. They are basically just a thick leaf spring.
Add those and a shackle and you could get a bit of lift. IIRC they are around $50 a pair.
FSJ Guy FSJ Guy is offline
NO BLOCKS on the front!!!
First of all, they're illegal.
Second of all, in stock configuration, they would LOWER your front end.
Did I mention, NO BLOCKS IN THE FRONT ?
Ethan Brady
www.bigscaryjeep.com
Old 04-28-2009, 07:53 PM
Where can I get this deal?
Old 04-28-2009, 07:58 PM
orangebike's Avatar
the shackle out of a junk yard...just takes a bit of searching and i got my add a leaf from swabs on one of my jeeps or can get them from hellcreeksuspensions.com dont know if they have them for your later year thought
Couple parts jeeps
66 chevelle ss-396
Old 04-28-2009, 08:00 PM
Not on his 65. Stock SOA.
But yes, no blocks up front. I'm not even sure I would run the zero rate aal's. They are suppsoed to be safe to use up front (makes since as they are bolted to the spring pack like any other leaf). Edit. The u-bolts on a closed kuckle axle would hold them from twisting as well.
Old 04-28-2009, 08:03 PM
TheJeeper's Avatar
How much would the anti twist plates stiffen the springs? I have relatively good travel up front and I'd like to keep it that way.
~Eli's Jeep Supply~
Old 04-28-2009, 08:14 PM
Not at all. they are just little stamped thick sheet metal plates that sit between two leafs. All tey do is make it so the bottom overlaod leaf (that usually is not connected to the main pack by any means other then the center pin) can't twist out of alignment. Would work well for a zero rate as well.
But I deleted that after remembering that the stock u-bolts will hold that zero rate from twisting.
Old 04-28-2009, 08:17 PM
Picture the zero rate under the springpack. You can see the u-bolts would hold it in palce. You would have to make your own though (or notch the production ones) as they are not made for 2" wide springs. Very easy though. I made some 3/4"x2.5 zero rates for my cherokee.
Old 04-28-2009, 08:19 PM
TheJeeper's Avatar
Not a bad idea.
~Eli's Jeep Supply~
Old 04-28-2009, 08:27 PM
TheJeeper's Avatar
Oh. My springs are 2.5 in. wide. Yours are 2in?
~Eli's Jeep Supply~
