Old 04-25-2009, 09:03 PM
Ristow Ristow is online now
Motorcraft 2150 rebuild. pic heavy.
the subject. about to be fully stripped for a carb dip. not all i'm doing is necessary for a general freshen up job. this one is going in the dip,so it sheds all it's clothes.
i'd like to start by saying DO NOT REMOVE ANY BUTTERFLY SCREWS! either throttle or choke. it ruins the threads in the shaft and the bolts cannot be properly tightened down again,risking engine damage! the throttle/choke shafts are rarely necessary to remove.
use 2 wrenches on the fuel line,one on the line,another on the fitting,or both will turn.
first,if you find what look like rivets holding the choke cap on,they are not. they are tamper proof screws. slot them with a dremel,and remove with a screwdriver.
pull the choke link arm off.
pull the top cover screws.
and the top will pop off.
pop the float retaing clip to pull the float.
note the little damper spring.
pulling the main jets is not mandatory. if you do remove,use a big enough screwdriver to span the jet,or you'll tear 'em up.
remove the booster cluster screw.
and gently wiggle it free.
remove the accelerator check weight,and the ball under it.
remove the accelerator pump screws and cover. negotiate the link rod from the cover arm.
and remove the diaphragm. rip out the red umbrella in the pump bore too.
remove the accelerator pump link from the throttle arm.
on the bottom of the main body,remove the power valve cover screws,un-screw the power valve from the main body.
remove the idle mixture screws.
remove the choke housing screws.
remove the circlip on the fast idle link. and separate the choke housing from the main body.
remove the thermostat arm screw.
remove the linkage assembly. there is a teflon bushing inside the bore to be removed as well.
remove the choke pull-off solenoid.
remove the aneroid bellows.
the idle solenoid.
remove the fuel inlet valve. again,wide screw driver.
and re-assemble all the main parts loosly for dunking. i left the aneroid bellows off because i don't know if it'd survive the bath chemcals.
Old 04-25-2009, 09:27 PM
red mistress's Avatar
carb overhaul thread
Great tech here...
Ought to put this in archives when finished.
Carb overhaul and tuning is a lost art...
69 Jeepster 8701 convertible
80 Honcho Sportside
82 CJ-8 75K org SR decals
82 Cheroeke Laredo 24K
84 CJ-8 mud Scrambler
Old 04-25-2009, 09:32 PM
chr1s's Avatar
chr1s chr1s is offline
Beach Bum - moderator
Originally Posted by red mistress
Great tech here...
I agree with everything you just said!
Nice write up Mr Ristow
87 Grand Wagoneer -(UNDER CONSTRUCTION)- "TROLL SMASHER II"
88 Grand Wagoneer- GONE
"many miles away, there's a shadow on the door, of a cottage on the shore, of a dark Scottish lake......many miles away..."
________________________________________
*** Current Jeep Status ***
JEEP IS : . . .
Old 04-25-2009, 09:34 PM
Cant wait for the second part,this will get bookmarked for sure. I will be puting it to use real soon also.
THANK YOU SIR!!!!!!!!
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 p/u
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 04-26-2009, 06:03 AM
andy d andy d is offline
Shade Tree Shaman
can't wait for the sequel , good job
\'88 gwag,pure stock
Old 04-26-2009, 06:22 AM
Great tech here...
big dittos...
It is also not that difficult.
Some think there is voodoo in there.
88 GW, 401/727/208, 5" lift, D44s/4.10s/locked up, 35s and a few Evil Twin mods, http://eviltwinfab.com
Old 04-26-2009, 06:41 AM
correct. simple carb,no reason to avoid rebuilding one. this is one i'm doing for a friend,thought some pics for the apprehensive would be helpful in saving some money over a rebuilt unit for some of us.
tuning these is easy too,as they're for a stock configuration,really all that's needed is to properly set the choke/fast idle up,and set the idle mixture. i'll be getting into both on reassembly. these carbs in fact rarely need a full rebuild,but the correct powervalve is the most expensive piece in the kit,and make up the biggest cost in the kit,so you may as well get the kit and make it all fresh and anew.
most faults are failed powervalve,accelerator pump diaphragm and/or choke cap,causing various operating problems. these are easy and inexpensive problems to fix.
Old 04-26-2009, 11:47 AM
AnnieL's Avatar
AnnieL AnnieL is offline
What a ROCKIN' POST!!!!!!
Well done, I'm totally impressed!
~AnnieL ~
"I think, therefore I'm single.”
Director: Mojave Desert Animal Rescue
http://www.AnimalResQ.org
~'89 GW- "Harsh Mistress " BJ's 4 Inch Lift, 31" Bridgestone REVOS, Quick Disconnect Swaybars, Pro Comp shocks...and...crappy paint!
Old 04-26-2009, 08:23 PM
Sian09's Avatar
Sian09 Sian09 is offline
I agree! A very good and detailed write-up. These are pretty simple and basic to rebuild even for my skill level. I'm thinking about taking off the 4bl on my J10 to go with the 2bl 2100 just cause its a lot easier to work on than the 4350! Can't wait for the next steps! Thanks Ristow!
'78 J10 Stock for now. 360, 44's F&R, T18, D20, TFI, 5 Slots, 31" ATs, Copper like color.
Old 04-26-2009, 08:36 PM
twisted frame twisted frame is offline
This is awesome! Thank you. I'll be following along and hope to apply the knowledge to a 4bbl soon. I did my 2100 not long ago and benefited from threads like these here.
Mike
1973 J4000, 360 2bbl, T18, Model 20,
44, 60-2, 32x11.5x15" on 15x8" CJ wagon wheels.
Now in black primer.
Old 04-26-2009, 08:48 PM
DAHoyle's Avatar
DAHoyle DAHoyle is offline
Great post Ristow, I Had my laptop on the bench when I did my 4350, and kept switching between your rebuild, and the FSM.
I pulled the carburetor apart over a year ago, and had pretty much decided to trash it, so I wasn't even sure all the parts were there. I did have one last rebuild kit for it, so I figured what the He11. I'd have never got it back together without those resources.
Now I have 2 rebuilt 4350's, and a parts spare, and it's sort of like my old M16 rifle. Can throw 3 of them disassembled in a box with a bunch of other junk, and I can reassemble them.
Not that I'm admitting to doing that. That would say terrible things about the clutter on my work bench.
67 M715
Old 04-26-2009, 10:15 PM
j20brett's Avatar
j20brett j20brett is offline
What is the function of the idle solenoid? Great write up by the way!
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 04-26-2009, 11:01 PM
Murphy's Avatar
Murphy Murphy is offline
big dittos...
Tritto
Archive material for sure.
Old 04-27-2009, 07:32 AM
Belteshazzar's Avatar
Belteshazzar Belteshazzar is offline
great timing, this job is on my to-do list this week anyway.
mucho thanks for taking the time to chronicle the job.
2003 Maxima
2002 P71
1979 RX-7
1979 Wagoneer
Old 04-27-2009, 08:33 AM
NVJEEPER's Avatar
NVJEEPER NVJEEPER is offline
Oi right on Mike
now i gotta tear mine apart cuz i miss seen' it jk
Damon
'85 Grand Wagoneer
Old 04-27-2009, 08:45 AM
JeepBountyHunter's Avatar
GrimJeeperReaper
This is good Mike, being that your a moderator here also, you'll be able to clean up this post so it can be archived...
I'll be referring to this when I do both of mine..well and I have like four other's sitting around..
Thanks
Aaron
2005 Mustang Convertible...meh....
Too many hobbies! $$$
Old 04-27-2009, 11:01 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
One other thing, when you remove the idle mixture screws, look them over to make sure the tips aren't distorted because Bruno mistook them for head bolts.
No offense to any Bruno on the site intended...
If the tips are damaged, put new ones on your list.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 04-27-2009, 11:41 AM
mattmopar440's Avatar
What is that going on ???the Grand wag or you just doing it for fun
91' Grand Wagoneer
401/727/229, Currently:Down for Body Work
77' Wagoneer 401 Parts rig
80's J10 258/T-5/208
89' Jeep GrandWagoneer
New Project
Inferior Chevy
Old 04-27-2009, 12:08 PM
GWChris GWChris is offline
Very nice job - should be a big help, especially given the number of 2150 rebuild questions that have come up of late.
Old 04-27-2009, 02:22 PM
HellCreek HellCreek is offline
The idle solenoid is energized (pops out) when the ignition key is turned on. It is set for the proper idle RPM. When you turn the key off, the solenoid pops back in and closes the throttle plate to prevent the engine from dieseling (running on).
Nice write-up, Ristow.
