Old 04-25-2009, 05:18 AM
Charlie_B's Avatar
Charlie_B Charlie_B is offline
My Project "Goldie" (lots of pics)
I guess making a "build thread" is the thing to do these days. So here I go. This summer is the summer to get my rig up to par. Its always needed some lovin in almost every place. And I feel like Ive just been polishing the turd for the last few years. The 1 yr old flexplate and starter gave up on me last fall. And instead of pulling off the slush box just to put it back on, the project list began. Things are getting slighty more serious with the g/f and I imagine that my ability to pull off a major project like this wont be around too much longer.
The list
Done:
-rebuild qtrac (OEM)
-rebuild tranny
In Progress:
prepping/painting backside of front clip and hood.
To Do:
-fix floor pans
-fix quarter panels
-fix flares
-strip/undercoat
-body rust repair/new sealer
-paint
The realistic wishes:
-4" lift (which I could higher, but trying to stay road legal)
-33x12.5 M/T? A/T? (see above)
-rebuild front end (tie rods, steering box, etc)
-u-joints
-rebuild at least top end of the motor (8600, Edel, T/A, Bulltear, fresh heads)
The pics (in order of appearance)
spare tranny/t-case
My SWEET (haha) work bench I built to practice some more welding
Some of the goodies
t-case damage (from other thread)
rust reconnaissance
Last night I pulled the rear seat and cargo carpet out. I was pleasantly surprised at the lack of rust on the rest of the truck compared to the passenger side. The inside of the body panels around the flares and rear quarters arent pretty. But I think I can clean it up and convert it well enough to stop the spread of rust. The fellow member (supercheif79) that I bought the spare tranny/t-case from stopped by last night with another t-case and tranny along with an old starter (ill use as a spare). So now I can pull apart spare t-case #2 and see what Ive got.
The plan is to pull out the drive train (minus motor, I dont have a hoist). And then get at the floor pans, and repaint the entire interior. Im still not anywhere near certain on paint. Part of me wants to keep the Golden Eagle stuff and do a nice spray job. I have no spray stuff or a good place to spray. The other part says screw it, rub it up against a tree and smile because I have less than $100 in paint. Either rattle can or roll on. I really dig the 2 tone Cherokees Ive seen.
So Ill try to keep this update as a help to get me motivated.
Thanks for looking.
Until next time, keep on
'79 Cherokee "Goldie" - under the knife Part I; Part II
Currently: body is on, now finishing undercarriage
'92 Cherokee "Rusty" - 3" lift, 31s
'05 Evo MR "Eve"
Old 04-25-2009, 07:20 AM
krek's Avatar
krek krek is offline
Perpetually Perplexed
Subscribed!
Old 04-25-2009, 07:26 AM
bg2pres's Avatar
bg2pres bg2pres is offline
whatever you do, don't get rid of those seats! If you do, call me first. I am needed the buttons and good front seat frames...
I have a brown Golden Eagle and I have rebuilt it. Very important is to reset your front and rear diffs. This is what causes most of the "clunk" in your transfer case. I have rebuild from radiator to rear bumper. Finishing up body now.
I put the new 40 gallon tank underneath from aerotanks and it was a perfect fit and I can do long runs now.
The only thing I have to complete on the engine is the cruise control and I can't figure out what I am missing.
Old 04-25-2009, 07:42 AM
Well like brother krek Subscribed!
Old 05-16-2009, 02:42 PM
Charlie_B's Avatar
Finally made some progress. I wound up using the case, diff and yokes from t-case #2 and the low range and input gear from #1. The needle bearing being trashed was likely related to the side gear in the diff being crooked nad wearing into the pin. So I bagged the complete diff, even though it was nicer looking.
I tore into the transmission this morning. With GSmikie right by my side! Got it mostly cleaned up and had to order some new parts. The low roller clutch and the 2-3? accumilator piston. But they are on the way, along with a deep sump aluminum pan .
Got a question about something. When gsmike talks about steel seals being better than the teflon, is he talking about the 6 needed (2 for pump, or something like that)? I cant seem to find anything online for steel and my rebuild kit has neither.
thanks for looking
'05 Evo MR "Eve"
Old 05-16-2009, 10:33 PM
Carleysjeep's Avatar
Carleysjeep Carleysjeep is offline
Dude you need some Evaporust!! Only joking , I just finished reading that thread. Seriously nice project, sounds like fun. Good luck.
Dan Rowe
I don't think an apology is needed. Most of us are pretty opinionated even when we are wrong.
84 Wagoneer 4" lift 32x11.5
77 J 20 Chevy 350 35x12.5
89 Cherokee 3" lift 31x10.5
Old 05-17-2009, 09:39 AM
newtojeeps's Avatar
Are we having fun yet? Looks great so far. Keep up the good work
Old 05-17-2009, 11:44 AM
COLOFIREMAN's Avatar
Gone,But not Forgotten.
Well good luck but your bench won't stay that nice for long.
Man thats alot of RTV on that TH400 pan!!!!
Old 05-17-2009, 12:02 PM
Charlie_B's Avatar
Definitely having fun..or at least trying to. My wallet isnt though.
The bench has at least fulfilled its expectations to this point. It hasnt fallen over and has given me a place to put a vise. The plywood was originally intended to be temporary until I could find a suitable work bench counter top.
All that rtv And it had a cork gasket. Came off in one big peice. Ive never been inside an auto tranny before, but Im pretty surprised at how nice the inside of this one looked. $20 in unexpected broken parts aint too bad in my book.
Opportunities to work on it have been few and far between. but hopefully after this next week I can put more time into it and get it on the road soon.
bg2pres: send me a pic of what your stuff under the hood looks like. I stupidly pulled my functioning cuise control apart a couple years ago and still have some pics from back then.
'05 Evo MR "Eve"
Old 05-17-2009, 01:05 PM
X3 on the subscription, your doing a fine job and hope to do the same on a trans and t-case soon. I even have the vid from Mike and the Napa kits he suggests in the vid. I just dont have a shop big enough or the is clean enough to do it in yet. Dirt free is the word...
Cant wait to see your pics also. Sounds like a nice ride.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 05-17-2009, 01:29 PM
I know that feeling! Yesterday I changed the a/c compressor on the waggy. I was putting it back together and couldn't get the alternator bracket to fit on for squat! There are 4 wagoneer in town including mine. My buddy has his torn apart with an engine swap under way. So I grab my digital camera, go knock on a door of this guy I don't know. I explain what I am doing and ask to take pictures of the brackets. So with pics in hand, head to the house and finish the install. Today I have cold a/c and life is good!
Dan Rowe
Old 05-17-2009, 03:47 PM
elij10travis's Avatar
elij10travis elij10travis is offline
hey u need some flares
hey i gopt some mint flares for the fender if u need any jsut give me a call u got a cell ill send the pictures to it if you want. im looking to buy som new fenders anyways. 207 3192214
1980 jeep j10
360
motocraft
4 speed standard
1989 jeep grand wag 360 fully loaded auto
1997 jeep cherokee 4.0 fully loaded
i love my money pits
Old 05-18-2009, 05:46 AM
mighty fine!
Old 05-18-2009, 09:43 AM
Charlie_B's Avatar
never would have dug into my first QT without you Flint. Thanks. This is my second, and I feel like I can do them in my sleep now. Although, this was the first time I tore open a diff and R&R'd the shifting mechanism. And Im glad I did with how bad the diff pin looked in case #1. But those cones and brakes sure were purdy.
Case #2 had the rubber seal around the whole thing (as seen in the pic). My last one didnt. What is your preference? With or without the rubber seal? BTW, my last one is leaking, but most likely due to excessive sealant. I really tried to be practical with the sealant this time.
thanks for looking
-Charlie
'05 Evo MR "Eve"
Old 05-18-2009, 10:42 AM
I prefer the case halves with the rubber seal and usually junk the one's we get with no rubber seal groove. With the rubber seal you can go real light on the sealant. Glad the site has been helpful!
Old 06-01-2009, 05:26 AM
Charlie_B's Avatar
No new pics, but made a little more progress this past weekend. Im waiting on more parts for the tranny rebuild. So I started take care of "free" stuff I can do. She's in the garage now, so my motivation just grew. The tranny is almost ready to pull out, t-case is out. Pass door, pass fender, hood, and grille is off. Ive got to finish pulling the tranny, drop the gas tank, pull driver's fender and door, and finish taking apart the front clip. Then Im going to wire wheel the h&^* out of everything. And get it cleaned up for some POR action. I want to coat the inside of all panels, top/bottom of floor pans, and frame. I'll tackle the engine bay when the time comes. But with everything apart, Im starting to think I dont want to mount this nice tranny/t-case to this old and tired motor, so who knows what will happen.
Im hoping things will pick up speed with warm weather finally here. I just need to make a few purchases to keep things rolling.
'05 Evo MR "Eve"
Old 06-01-2009, 06:57 AM
OBX-AUTOMOTIVE's Avatar
OBX-AUTOMOTIVE OBX-AUTOMOTIVE is offline
GRUMPY
JUST GUESSING,FROM YOUR PIC, YOU COULD USE A REAR SECTION,AND YOU MAY NEED THE RIGHT AND LEFT REAR FLOOR CORNERS ALSO!
I'LL BRAKE A SECTION AND SEND IT WITH THE RIGHT FLOOR,YOU CAN ADD IT ON, IF YOU NEED TO,BUT YOU'LL HAVE TO WING IT AT THE TRANS HUMP.
Old 06-01-2009, 07:34 AM
Charlie_B's Avatar
What section are you referring to sending? The rear? Or peice in between front and rear? Thanks alot!
The driver's side is fine. The first floor pan pic shows it. Unless Im not seeing something??? The portion under the seat belt is carpet. I still need to get that huge torx bit for the seat belts.
'05 Evo MR "Eve"
Old 06-01-2009, 08:22 AM
GRUMPY
IT'S AN ADD ON TO THE REAR OF THE FRONT FLOOR PAN I'M SENDING,IF YOU NEED TO USE IT.
I'M SHIPPING YOUR FLOOR PARTS TODAY..
I WOULD STAY AND TALK,BUTS I GOTS TO GO!>>>>>>
Old 06-01-2009, 11:02 AM
GRUMPY
IF I REMEMBER RIGHT THIS IS A PIC OF BAYBILLYS CHEROKEE!
I ALSO SENT HIM A EXTRA SECTION, TO ADD TO THE SPACE,AT THE REAR PART OF THE FRONT FLOOR AND THE FRONT SECTION OF THE REAR FLOOR PAN.
AS YOU SEE HE ONLY CUT OUT HALF, OF THE CENTER OF THE FLOOR!
