I bought a 1968 Wagoneer a while back I'm beginning to think it was a mistake. I can't seem to find anybody that makes a bolt on lift for it. I ordered one from BJ's off road but I got an email the other day saying they are no longer selling lifts for the early Wagoneers. What should I do? Sell it and get a newer Jeep?
Where can I find a lift for my 68 Wagoneer??
I have their 4" (hellcreek)on my 1975 Cherokee and it doesn't ride rough at all. I have a 4" super lift on my J10 and it's just now starting to loose its teeth rattling harshness and I bought it used (it was installed on a project that never got on the road). My only complaint is it looks a touch lower in the back than the front. I am running caster wedges though in the front. I think they have a 10% ifsja discount too.GreenMachine
This is a bummer to hear because I was probably close to purchasing one of their lifts for my '69 soon as well.
Originally posted by GreenMachineI have their 4" (hellcreek)on my 1975 Cherokee and it doesn't ride rough at all. I have a 4" super lift on my J10 and it's just now starting to loose its teeth rattling harshness and I bought it used (it was installed on a project that never got on the road). My only complaint is it looks a touch lower in the back than the front. I am running caster wedges though in the front. I think they have a 10% ifsja discount too.
What else are our options for the early rigs? Unless I can find a place to make me some nice riding 4-5" lift springs for a reasonable price, I'm leaning towards just ditching the stock spring mounts and running '74+ stuff so I can have some choices on lift springs.'69 Wagoneer, Empire Blue / rust, Buick 350, TH00, Dana 20, Dana 27/44, stock & original
'91 XJ Laredo 4dr, 4.0L/AW4, 4.5" lift, 31" BFG's, etc
'02 WJ Limited, 4.7L/QD, 2.5" lift, 31" BFG's, etc
here is an idea...
buy a 4 spring lift kit for 90s jeep wranglers. yes, I kno that their springs are shorter than the ones on your Kaiser FSJ, but they are 2.5" wide which is the same.
when you get them...cut off the bushing end of the wrangler main leaf and take apart the spring pack.
then take your Kaiser spring pack, remove it from the jeep or leave it attached to the jeep. and separate all the leafs. (remove the center pin)
keeping the MAIN LEAF of your Kaiser spring, add all the leafs from the wrangler pack to your Kaiser main leaf, and reinstall the center pin.Ken's:
1966 Super Wagoneer
5.7L 2BBl. Th700R4. NP-208. Opens. 3.31s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
(Soon to be TBI)
That may be an option, has anyone actually done that on one of these early Wagoneers? I wonder what height of Wrangler lift springs I'd need to get about 4" of lift on a Wagoneer. The Wrangler is obviously a lot lighter.'69 Wagoneer, Empire Blue / rust, Buick 350, TH00, Dana 20, Dana 27/44, stock & original
Originally posted by PNW69WaggyThat may be an option, has anyone actually done that on one of these early Wagoneers? I wonder what height of Wrangler lift springs I'd need to get about 4" of lift on a Wagoneer. The Wrangler is obviously a lot lighter.
Originally posted by rocklaurenceI know the older trucks front springs were 2" wide not 2.5" as the newer springs. I believe the old Wagons had the 2" springs also and wouldnt be compatable.
waggys from day one had 2.5" wide springs.Ken's:
1966 Super Wagoneer
(Soon to be TBI)
Older Chevy Blazers have the same spring lengths as the early Wagoneers, 22X22 in front and 26X26 in the rear. I've been thinking about using Skyjacker Softride springs designed for Blazers. The Chevys were spring over axle in the front though, so I think a spring with more arch would be needed for our spring under setups. Speciffically I was thinking the Skyjacker CR14S in the rear (4" lift) and the C280S (8" lift) for the front. Still not a cheap option though, as just those springs without bushings or shocks will run about $1000. Considering the Hell Creek kit is ready to go for just a bit more, it's likely a more convenient option.
