Has anyone here rebuilt a T15 Transmission Shift Top. I would like to rebuild mine but don’t really know where to start. Does anyone make a kit? What’s the procedure to get the shift top disassembled.
How to Rebuild T15 Shift Top
This is from the TSM manual which gives the run down of steps. Its a starting point.77' J10 w/ 360, T18, Dana 20 TC
Dang, I must have missed that page thinking it was part of the T18 info. Thanks for that!
Where can I get shift rail plugs?1977 Jeep J10
258 Engine
Weber 38 carb
T15 Trans
Dana 20 with Tera Low
Dana 44 Front and Rear axles
Custom 16 inch rims 235x85 R16 Duratrac tires
I just got everything for the shift top disassembled. It was tough getting the interlock plunger out but I got everything done and was able to save the end plugs by tapping them out from the back using the shift rails. It all looks straight forward but in the very top of the tower, where the shift handle ball rides there is a pin. My pin looks worn and spins in its bore. The pin rides in a groove on the side of the shift handle ball. Also looks like there might have been a small tit above the pin?
Anyone seen this? Anyone know of a fix. Looks like the pin might pop in or install from the inside of the tower.1977 Jeep J10
258 Engine
Weber 38 carb
T15 Trans
