Project Humpty '74 J20 Diesel Build UPDATED!
  • jaber
    • Oct 17, 2003
    • 8105
    Originally posted by Redwookie
    Hello all. New around these parts but just wanted to say nice truck! Awesome build! I'm getting ready to convert my '89 Blazer from the 5.7 to the 6.2 diesel myself
    Welcome from up the hill. You should put that Diesel into a Jeep!
    Zack, That is looking awesome. I have a '77 J-20 that I want to do the same with so I have a good strong work truck. Thanks for the pics, they worked first time for me.
    '43 cj2a
    '51 Willys p/u
    '51 Willys Parkway Conversion
    '68 Panel Delivery
    '74 CJ5
    '75 J-20 Wrecker
    '75 J-20 Cummins service bed
    '77 J-10 p/u
    '79 Cherokee
    '88 Grand Wagoneer
    '98 Grand Cherokee
    • red mistress
      • Sep 13, 2007
      • 2293
      Nice project
      Subscribed...
      recognize that dual battery tray for a CJ.
      Vintage Air A/C ?
      LMK if I can help.
      69 Jeepster 8701 convertible
      80 Honcho Sportside
      82 CJ-8 75K org SR decals
      82 Cheroeke Laredo 24K
      84 CJ-8 mud Scrambler
      • zmjeeps
        • Jun 14, 2000
        • 1662
        Originally posted by red mistress
        Subscribed...
        Vintage Air A/C ?
        Yes, Vintage Air/Hot Rod Air. I put it over in the pass area instead of in the middle. Fits behind the dash nicely and doesn't hang down as far as a stock AC unit. Part of the battery tray for a CJ. Had to modify the inner fender for the third mount.
        Z.
        Zack Heisey
        Z&M Jeeps
        419.893.4JEEP (4533)
        www.zmjeeps.com
        [email protected]
        • babywag
          • Jun 08, 2005
          • 10286
          Nice!!
          Wanna sell me a set of the custom motor mounts so I can ship them to my dad for his 4BT swap?
          • zmjeeps
            • Jun 14, 2000
            • 1662
            Originally posted by babywag
            Nice!!
            It depends which type of mounts you want to use. I used the hydro mounts and am taking a bunch of flack from some of the diesel guys that they can't be mounted past 4 degrees or they don't work. I don't get it, the forces work out, but whatever. I can make you a pair of plates like the ones I started with to bolt to the motor. Its a great starting point for making your own...
            Zack
            Zack Heisey
            Z&M Jeeps
            www.zmjeeps.com
            [email protected]
            • babywag
              • Jun 08, 2005
              • 10286
              Zack
              I'll email you about it...
              • joe
                • Apr 28, 2000
                • 22392
                Great project Zack!
                • Mikel
                  • Aug 09, 2000
                  • 6330
                  Zack
                  The Lord isolators are not designed for a side load. Let us know how it works
                  1969 M715 6x6
                  1963 J300 Swivel frame
                  • zmjeeps
                    • Jun 14, 2000
                    • 1662
                    Which is what I keep hearing. But no one can explain WHY. Do a force diagram and see how they are are loaded, direct pressure along the axis of the mount. Someone tells me WHY it won't work, I'll redo it.
                    Z.
                    Zack Heisey
                    Z&M Jeeps
                    www.zmjeeps.com
                    [email protected]
                    • The PIG Smith
                      King Browless
                      • Nov 30, 2001
                      • 6538
                      80's browless cab
                      Best part of the whole project! HAHAHAHA
                      Bryan Smith
                      2017 Jeep Grand Cherokee Limited
                      - 75th Anniversary Edition - 1941 Trim Package - Recon Green
                      1986 Jeep J20
                      - Super clean rig from the AZ/CA state line
                      1982 Jeep J10
                      - Has become a Long Term Project.
                      1981 Jeep J20
                      - Commercial flat bed - Lost in a Divorce --gone
                      1987 Jeep J20 Pioneer
                      - Former Rick Bielec aka Ricbee plow rig. Major rust!! --gone
                      IFSJA Member #1933 Joined November 30, 2001
                      Originally posted by Jayrodoh
                      Originally posted by Lindel
                      • zmjeeps
                        • Jun 14, 2000
                        • 1662
                        I wondered how long it would take you to chime in on that...
                        Z.
                        Zack Heisey
                        Z&M Jeeps
                        www.zmjeeps.com
                        [email protected]
                        • Mikel
                          • Aug 09, 2000
                          • 6330
                          Z.
                          Zach,
                          You are right - In theory. The problem is that those things compress quite a bit under load, so unless you have factored that compression in your engine mount geometry, the mounts are going to flex in non-axial ways. The angling also causes higher loading of the mounts, affecting the damping rates. I'm not saying they are going to fail, just that you are sailing uncharted waters. Good luck with your awesome build
                          Mikel
                          1969 M715 6x6
                          • zmjeeps
                            • Jun 14, 2000
                            • 1662
                            Zach,
                            Mikel
                            http://www.lord.com/Home/ProductsSer...3/Default.aspx
                            Thank you. While I could not predict how much it would compress under load, I did slot the holes in the engine mounts to allow the stud to settle where it wanted and I haven't bolted it down yet, so as not to trap it before it is settled.
                            Zack Heisey
                            Z&M Jeeps
                            www.zmjeeps.com
                            [email protected]
                            • zmjeeps
                              • Jun 14, 2000
                              • 1662
                              Thanks Dusty!!
                              Big thanks on this project goes out to Dusty (a member here) who put up with a bunch of dumb questions from me (where does the fuel line go?) Dusty REALLY knows his stuff when it comes to diesels and 4bts. I was sending him pictures so I could ask him questions and he would ask about the Jeep parts of the build and I was asking him about the Diesel parts of the build. Good thing we are on opposite sides of the country, we'd be dangerous together
                              Zack
                              Zack Heisey
                              Z&M Jeeps
                              www.zmjeeps.com
                              [email protected]
                              • zmjeeps
                                • Jun 14, 2000
                                • 1662
                                Added a few more early photos of the cab being prepped.
                                www.photobucket.com/humpty
                                Zack
                                Zack Heisey
                                Z&M Jeeps
                                www.zmjeeps.com
                                [email protected]
