Old 01-31-2012, 09:23 AM
CoastGuardTruck's Avatar
CoastGuardTruck CoastGuardTruck is offline
Dash pad - what years will work?
Replacing the windshield in my 1980 J10 soon and seems like the perfect time to fix my HORRIBLY cracked dash. What years will work with my truck? Mine is so shattered I'm pretty sure it's beyond repair so I need a donor.
Old 01-31-2012, 09:42 AM
addicted's Avatar
addicted addicted is offline
Big Meanie
'73 or '74-'86 will work.
Originally posted by Ristow
i bet it was Simon....
Old 01-31-2012, 10:02 AM
Logans Run's Avatar
Logans Run Logans Run is offline
replacing a dash looks like a daunting task.
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
P.S. those are some beeftastic bumpers!
My Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Old 01-31-2012, 10:04 AM
addicted's Avatar
Big Meanie
it's not too bad after you pull the windshield.
Old 01-31-2012, 11:55 AM
Just jtrucks or will wagoneers work too?
Old 01-31-2012, 01:37 PM
addicted's Avatar
Big Meanie
Wagoneers and Cherokees.
Old 01-31-2012, 03:20 PM
chrisnsarah's Avatar
Cherokees are slightly different. They don't wrap the passenger side like wags and trucks do. They will fit, but you may have some holes to fill.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 02-03-2012, 08:03 AM
Mine doesn't wrap the passenger side. It has that handle thing. BUT I found one that does wrap the passenger side. Question is can you make one that wraps the passenger side fit on a truck that had one that didn't. Is it as simple as taking the handle off??
Old 02-03-2012, 08:38 AM
addicted's Avatar
Big Meanie
It should be. You might need to drill a few more holes for the padded drop section that covers where the handle goes.
Old 02-03-2012, 08:58 AM
thanks! I'll probably put it in then
Dim dash lighting caionneach General FSJ Tech 10 02-19-2010 12:40 PM
Exterior/interior lighting intermittent and dash lighting not working palexand General FSJ Tech 5 10-02-2009 10:20 AM
Pics of dash without dash pad? toyjeep General FSJ Tech 8 09-28-2009 01:27 PM
J10 Maiden Voyage to Work The PIG Smith General FSJ Tech 10 05-08-2009 08:52 PM
will a 87 dash gague set work in an 85? gmarblestone General FSJ Tech 2 05-11-2007 07:50 AM
