Old 01-12-2012, 04:28 PM
chrisnsarah's Avatar
grayish white exhaust smoke-need opinions
Or a diagnosis.
Started belching very light gray smoke about a week ago. It's not condensation because its still there after its fully warmed up. It doesnt smell like burning oil. I see it mostly while idling and it dissipates within 10ft of exiting the tailpipe. Doesn't smell like coolant, but it does emit water for a few min. I've put 300 mi since last week and oil and coolant levels are unchanged and look clean.
Today, I did a compression check. Pulled all plugs. All were normal except #1 cyl was wet and dark. All cylinders tested good except #1 gave me 20 psi. Yikes.
I then used my compression tester hose to pump up the cylinders at tdc. 7 of them held pressure-enough to push the truck forward while in gear (I had wheels blocked). #1 cyl wouldn't move the piston down, instead, the air came out the exhaust.
I'm guessing burned or broken valve. Would this cause the smoke? I've also noticed a misfire and mileage is slightly down.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 01-12-2012, 04:34 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Yea, that sounds like an exhaust valve.
lots of white smoke and funny (bad kind of funny) noise 83 chif General FSJ Tech 6 12-07-2005 03:51 AM
smoke from exhaust manifold Fornesto General FSJ Tech 1 06-24-2004 03:40 PM
White Smoke... M1Garandfan General FSJ Tech 10 07-12-2003 04:12 PM
White smoke when pedal is mashed? Zack172 General FSJ Tech 17 06-01-2003 04:10 PM
"an exhaust system can also be too efficient." Jerk General FSJ Tech 25 09-12-2002 03:58 PM
